20N98M84/DN
20N98M84/DN
    JWWINCO
    STEEL LEVELING FEET
20N98M84/DN 数据手册
GN 343.1 GN 343.2 Leveling Feet Tapped Socket Type Threaded Stud Type Steel, with or without Plastic / Rubber Cap Metric 4 Type OS KS KR KSE Without cap With plastic cap, gliding With rubber cap, non-skid With plastic cap, gliding, electrically conductive (antistatic) KRE With rubber cap, non-skid, electrically conductive (antistatic) Specification Information • Base / tapped socket Steel, zinc plated, blue passivated finish The static load capacity of GN 343.2 leveling feet results from the permissible load capacity of the threaded stud (property class 5.8). • Threaded stud Steel -- Property class 5.8 -- Zinc plated, blue passivated finish The values for static load capacity listed in the table (only valid for type OS, KS and KSE) refer to a purely vertical load to the ball socket. Under normal operating conditions, bending loads or angular loads are not uncommon and result in a reduction of the load capacity, which must be taken into consideration. • Type KS / KSE Plastic cap Technopolymer (Polyacetal POM) -- KS: White, RAL 9001, natural color -- KSE: Black, electrically conductive Surface resistivity
20N98M84/DN 价格&库存
很抱歉,暂时无法提供与“20N98M84/DN”相匹配的价格&库存,您可以联系我们找货
