GN 612
Cam Action Indexing Plungers
Steel / Stainless Steel
Lock-Out
Inch | Metric
3
Type
A
Without plastic sleeve,
without lock nut
AK Without plastic sleeve,
with lock nut
B With plastic sleeve,
without lock nut
BK With plastic sleeve,
with lock nut
Specification
4
• Threaded body / plunger pin / lever arm
-- Steel, blackened finish —
Plunger pin nitrided
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
(only available in metric sizes)
• Spring
Stainless steel
European Standard No. 1.4310 (AISI 301)
• Plastic sleeve
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
Information
GN 612 cam action indexing plungers are best utilized in applications where the pin may need to be
retracted periodically. By rotating the lever arm 180° the plunger pin is withdrawn. The notch allows for
safe positioning while the plunger pin is held in the retracted position.
The grooved lever arm provides the user with a better grip when operating the mechanism. In addition,
the snap-on plastic ribbed sleeve offers a more aesthetically pleasing and comfortable finger grip.
see also...
• List of Cam Action Indexing Plungers Types
• Mounting Blocks GN 412.1
• Mounting Blocks GN 612.1
• Inch size lock nut
ANSI/ASME B18.2.2
• Metric size lock nut
DIN 439 B / ISO 8675
-- Stainless steel (A2)
• RoHS compliant
How to order (Inch, steel)
1
2
3
GN 612-10-3/4X16-AK
How to order (Metric, stainless steel)
1
2
3
4
GN 612-12-M20x1.5-B-NI
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Thread d 2
3
Type
1
Pin diameter d1
2
Thread d 2
3
Type
4
Material
www.jwwinco.com | phone: 1-800-877-8351
GN 612 Cam Action Indexing Plungers continued
Inch table
1
2
d1
d2
Pin −0.001
−0.002
Bore +0.001
6
8
8
10
10
12
Dimensions in: inches - millimeters
Thread
.24
5/8 x 18
.31
5/8 x 18
.31
3/4 x 16
.39
5/8 x 18
.39
.47
d3
l1
l2
.63
2.20
56
10
.63
2.20
56
10
.79
69
12
.63
2.20
56
10
3/4 x 16
.79
69
12
3/4 x 16
.79
69
12
16
16
16
l 3 +0.06
l4
l5
Spring load ≈
Initial
End
.39
1.18
30
1.26
32
1.65
42
2.47 lbf
11 N
6.52 lbf
29 N
.39
1.18
30
1.26
32
1.65
42
2.47 lbf
11 N
6.52 lbf
29 N
.47
1.42
36
1.46
37
2.05
52
4.72 lbf
21 N
12.81 lbf
57 N
.39
1.18
30
1.26
32
1.65
42
2.47 lbf
11 N
6.52 lbf
29 N
.47
1.42
36
1.46
37
2.05
52
4.72 lbf
21 N
12.81 lbf
57 N
.47
1.42
36
1.46
37
2.05
52
4.72 lbf
21 N
12.81 lbf
57 N
Metric table
1
2
d1
d2
Steel pin −0.02
−0.04
Stainless steel pin −0.06
−0.08
Bore H7
Dimensions in: millimeters - inches
d3
Thread
M 10
M 10 x 1
10
5*
.20
5
.20
M 10
M 10 x 1
10
M 12
M 12 x 1.5
12
M 10
M 10 x 1
10
M 12
M 12 x 1.5
12
M 16
M 16 x 1.5
16
M 12
M 12 x 1.5
12
M 16
M 16 x 1.5
16
M 20
M 20 x 1.5
M 16
M 16 x 1.5
16
M 20
M 20 x 1.5
M 20
M 20 x 1.5
8
8
8
10
10
12
.24
.31
.31
.31
.39
.39
.47
l2
l 3 +1.5
l4
l5
Spring load ≈
Initial
4*
.16
6*
.24
6
.24
l1
.39
37.5
1.48
6
.39
37.5
1.48
6
.47
47
1.85
8
.39
37.5
1.48
6
.47
47
1.85
8
.63
56
2.20
10
.47
47
1.85
8
.63
56
2.20
10
.79
69
2.72
12
.63
56
2.20
10
.79
69
2.72
12
.79
69
2.72
12
.24
.24
.31
.24
19
19
.75
.75
21
21
.83
.83
End
7N
1.57 lbf
20 N
4.50 lbf
7N
1.57 lbf
20 N
4.50 lbf
26
1.02
26
1.02
32
1.26
8N
1.80 lbf
18 N
4.05 lbf
19
21
7N
1.57 lbf
20 N
4.50 lbf
.75
.83
.31
26
1.02
26
1.02
32
1.26
8N
1.80 lbf
18 N
4.05 lbf
.39
30
1.18
32
1.26
42
1.65
11 N
2.47 lbf
29 N
6.52 lbf
.31
26
1.02
26
1.02
32
1.26
8N
1.80 lbf
18 N
4.05 lbf
.39
30
1.18
32
1.26
42
1.65
11 N
2.47 lbf
29 N
6.52 lbf
.47
36
1.42
37
1.46
52
2.05
21 N
4.72 lbf
57 N
12.81 lbf
.39
30
1.18
32
1.26
42
1.65
11 N
2.47 lbf
29 N
6.52 lbf
.47
36
1.42
37
1.46
52
2.05
21 N
4.72 lbf
57 N
12.81 lbf
.47
36
1.42
37
1.46
52
2.05
21 N
4.72 lbf
57 N
12.81 lbf
* These sizes are only available in Type A and AK
3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements |
3
很抱歉,暂时无法提供与“612-8-M20X1.5-AK”相匹配的价格&库存,您可以联系我们找货
