GN 612.2
Cam Action Indexing Plungers
Steel, Lock-Out, with Mounting Flange
Metric
3 Type
A Without plastic sleeve
B With plastic sleeve
Metric table
Dimensions in: millimeters - inches
1
2
d1
d2
d3
h
k
l1
l2
l3
l4
s
Initial
End
6
.24
16
.63
35
1.38
16
.63
56
2.20
10
.39
32
1.26
42
1.65
12
.47
12 N
2.70 lbf
32 N
7.19 lbf
8
.31
16
.63
35
1.38
16
.63
56
2.20
10
.39
32
1.26
42
1.65
12
.47
12 N
2.70 lbf
32 N
7.19 lbf
8
.31
40
1.57
22
.87
69
2.72
12
.47
37
1.46
52
2.05
15
.59
21 N
4.72 lbf
58 N
13.04 lbf
10
.39
16
.63
35
1.38
16
.63
56
2.20
10
.39
32
1.26
42
1.65
12
.47
12 N
2.70 lbf
32 N
7.19 lbf
10
.39
40
1.57
22
.87
69
2.72
12
.47
37
1.46
52
2.05
15
.59
21 N
4.72 lbf
58 N
13.04 lbf
12
.47
40
1.57
22
.87
69
2.72
12
.47
37
1.46
52
2.05
15
.59
21 N
4.72 lbf
58 N
13.04 lbf
Pin −0.05
Bore H7
Spring load ≈
Specification
Information
• Body / lever arm
Steel, blackened finish
GN 612.2 cam action indexing plungers are best utilized in applications where the pin may need to be
retracted periodically. By rotating the lever arm 180° the plunger pin is withdrawn. The notch allows for
safe positioning while the plunger pin is held in the retracted position
• Plunger pin
Steel, nitrided
• Plastic sleeve
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
• RoHS compliant
These indexing plungers also feature a counterbored flange for surface mounting. The plastic ribbed
sleeve offers an aesthetically pleasing and comfortable finger grip.
see also...
• Product Range Standard Parts for Profile Systems
• List of Cam Action Indexing Plungers Types
• Locating Bushings GN 412.2 / GN 412.4
• Square Spring Latches GN 722.3
• T-Nut Assemblies GN 965 (for 30 / 40 mm T-Slot Profile Systems)
• T-Nut Assemblies GN 968 (for 30 / 40 / 45 mm T-Slot Profile Systems)
How to order
1
2
3
GN 612.2-8-16-B
80
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Outer diameter d 2
3
Type
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“10W12P83”相匹配的价格&库存,您可以联系我们找货
