GN 613
Indexing Plungers
Steel / Stainless Steel
Non Lock-Out, with Fully Threaded Body
Metric
2
Type
A
AK
AN
With plastic knob, without lock nut
With plastic knob, with lock nut
With stainless steel knob,
without lock nut
AKN With stainless steel knob,
with lock nut
G
With threaded stem,
without lock nut
GK With threaded stem,
with lock nut
Metric table
Dimensions in: millimeters - inches
1
d1
Pin −0.02
−0.05
Bore H7
d2
Thread
d3
d4
Thread
l1 ≈
l2
l3
l4
l5
Spring load ≈
Steel
Part number
installation tool
Stainless steel
Initial
End
Initial
End
5
0.20
M 10 x 1
21
0.83
M5
45
1.77
5
0.20
22
0.87
6
0.24
4.5
0.18
7N
1.57 lbf
17 N
3.82 lbf
6N
1.35 lbf
15 N
3.37 lbf
GN 613.1-5
6
0.24
M 12 x 1.5
25
0.98
M6
54.5
2.15
6
0.24
26
1.02
10
0.39
8
0.31
9N
2.02 lbf
24 N
5.40 lbf
8N
1.80 lbf
21 N
4.72 lbf
GN 613.1-6
8
0.31
M 16 x 1.5
31
1.22
M8
69
2.72
8
0.31
34
1.34
12
0.47
10
0.39
11 N
2.47 lbf
30 N
6.74 lbf
9N
2.02 lbf
26 N
5.85 lbf
GN 613.1-8
10
0.39
M 20 x 1.5
31
1.22
M8
80
3.15
10
0.39
43
1.69
12
0.47
12
0.47
19 N
4.27 lbf
45 N
10.12 lbf
17 N
3.82 lbf
40 N
8.99 lbf
GN 613.1-10
Specification
3
Information
• Threaded body
-- Steel, blackened finish —
Plunger pin hardened
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Plunger pin chemically nickel plated
GN 613 indexing plungers are a low cost alternative with reduced dimensions.
• Knob (Type A / AK)
Plastic
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
-- Not removable
GN 613.1 installation tools, available as accessory, reduce the installation time and make it easier to
counter hold the plunger during the assembly. The tool is inserted laterally between the knob and the
threaded body and engages in the slot provided.
• Knob (Type AN / AKN)
Stainless steel
Not removable
Accessory
Type G and GK with threaded stem are for applications where a special knob or attachment is required,
or for such cases where the spindle is linked directly to an operating mechanism.
The indexing plungers completely made of stainless steel parts are a good choice for use in corrosion
free environments.
see also...
• List of Indexing Plunger Types
• Installation tools GN 613.1
(Part number, see table)
• Lock nut
DIN 439 B / ISO 8675
-- Stainless steel (A2)
How to order (Steel, with plastic knob)
• RoHS compliant
How to order (Stainless steel, with stainless steel knob)
1
2
GN 613-8-G
1
2
3
GN 613-5-AKN-NI
12
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Type
1
Pin diameter d1
2
Type
3
Material
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“F91/G”相匹配的价格&库存,您可以联系我们找货
