LPSO
“Level-It”™ Leveling Mounts
Steel Tapped Socket Type
Inch
3
A1
A2
A3
A4
Type
Steel base, yellow zinc plated
Steel base, black oxide finish
Solid Delrin ® plastic base
Molded Delrin ® plastic base
Specification
Information
• Type A1 / A2
-- Base
Steel, yellow zinc plated or black oxide finish
-- Tapped socket
Steel, hardened
LPSO “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven
surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large
diameter base design assures a solid support.
• Type A3 / A4
-- Base
Delrin® plastic
Temperature resistant up to 180 °F (82 °C)
-- Tapped socket
Steel, hardened, yellow zinc plated
• RoHS compliant
These leveling mounts were developed for applications where the mount needs to be easily removed, a
longer than standard stud needs to be attached or the equipment already has a fixed stud on it.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
see also...
• ”Level-It”™ Leveling Mounts LPSO (Stainless Steel Tapped Socket Type)
• ”Level-It”™ Leveling Mounts MLPSO (Steel Tapped Socket Type, Metric Thread)
• ”Level-It”™ Leveling Mounts LPST (Steel Threaded Stud Type)
• ”NY-LEV®” Leveling Mounts WN 9000 (Nylon Base, Steel Tapped Socket Type)
On request
• Non-skid Elastomer pad
• Molded Delrin® plastic base in additional sizes
• For certain minimum quantities, modifications
such as lag bolt holes, custom stud lengths,
and other versions of plating
How to order
1
2
3
LPSO-0.75-10X32-A1
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Type
www.jwwinco.com | phone: 1-800-877-8351
LPSO “Level-It”™ Leveling Mounts continued
Inch table
1
2
d1
d2
Dimensions in: inches - millimeters
l1
l2
A/F
Thread
t
Max. load
min.
Steel base
0.75
19.1
10
x 32
0.53
13.5
0.100
2.5
0.375
9.5
0.17
4.3
700 lbf
3113.75 N
150 lbf
667.23 N
1.00
25.4
1/4
x 20
0.70
17.8
0.141
3.6
0.500
12.7
0.31
7.9
1000 lbf
4448.22 N
200 lbf
889.64 N
1.00
25.4
1/4
x 28
0.70
17.8
0.141
3.6
0.500
12.7
0.31
7.9
775 lbf
3447.37 N
125 lbf
556.02 N
1.25
31.8
5/16
x 18
0.88
22.4
0.170
4.3
0.625
15.9
0.38
9.7
2500 lbf
11120.55 N
250 lbf
1112.05 N
1.25
31.8
5/16
x 24
0.88
22.4
0.170
4.3
0.625
15.9
0.38
9.7
2150 lbf
9563.67 N
200 lbf
889.64 N
1.25
31.8
3/8
x 16
0.88
22.4
0.170
4.3
0.625
15.9
0.38
9.7
3750 lbf
16680.83 N
300 lbf
1334.46 N
1.25
31.8
3/8
x 24
0.88
22.4
0.170
4.3
0.625
15.9
0.38
9.7
3300 lbf
14679.13 N
250 lbf
1112.05 N
1.88
47.8
1/2
x 13
1.13
28.7
0.250
6.4
0.750
19.1
0.44
11.2
5000 lbf
22241.10 N
700 lbf
3113.75 N
1.88
47.8
1/2
x 20
1.13
28.7
0.250
6.4
0.750
19.1
0.44
11.2
4000 lbf
17792.89 N
625 lbf
2780.13 N
2.50
63.5
5/8
x 11
1.25
31.8
0.350
8.9
0.875
22.2
0.45
11.4
6000 lbf
26689.32 N
1200 lbf
5337.86 N
2.50
63.5
5/8
x 18
1.25
31.8
0.350
8.9
0.875
22.2
0.45
11.4
5000 lbf
22241.11 N
1100 lbf
4893.04 N
3.00
76.2
3/4
x 10
1.50
38.1
0.410
10.4
1.062
27.0
0.65
16.5
7400 lbf
32916.84 N
1800 lbf
8006.79 N
3.00
76.2
3/4
x 16
1.50
38.1
0.410
10.4
1.062
27.0
0.65
16.5
6200 lbf
27578.97 N
1650 lbf
7339.56 N
4.00
101.6
7/8
x 14
1.88
47.8
0.440
11.2
1.375
34.9
0.81
20.6
13500 lbf
60050.99 N
1950 lbf
8674.03 N
4.00
101.6
7/8
x 9
1.88
47.8
0.440
11.2
1.375
34.9
0.81
20.6
15000 lbf
66723.32 N
1700 lbf
7561.97 N
4.00
101.6
1
x 8
1.88
47.8
0.440
11.2
1.375
34.9
0.81
20.6
20000 lbf
88964.43 N
2400 lbf
10675.73 N
4.00
101.6
1
x 12
1.88
47.8
0.440
11.2
1.375
34.9
0.81
20.6
18000 lbf
80067.99 N
2250 lbf
10008.49 N
6.00
152.4
1 1/4 x 7
2.75
69.9
0.750
19.1
1.875
47.6
1.00
25.4
43000 lbf
191273.53 N
3600 lbf
16013.59 N
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“10TLVT/DN”相匹配的价格&库存,您可以联系我们找货
