16NLV1/DN
16NLV1/DN
    JWWINCO
    LEVELING MOUNT, TAPPED THREAD
16NLV1/DN 数据手册
MLPSO “Level-It”™ Leveling Mounts Stainless Steel Tapped Socket Type Metric 3 Type B1 Stainless steel base B2 Solid Delrin ® plastic base B3 Molded Delrin ® plastic base Metric table 1 2 d1 d2 Dimensions in: millimeters - inches l1 l2 A/F Thread t Max. load min. Stainless steel base Delrin ® plastic base  19.1   0.75 M 6 13.5  0.53  2.5  0.100  9.5  0.375  4.3  0.17   3113.75 N    700 lbf   667.23 N   150 lbf  25.4   1.00 M 8 17.8  0.70  3.6  0.141 12.7  0.500  7.9  0.31   4448.22 N   1000 lbf   889.64 N   200 lbf  31.8   1.25 M 10 22.4  0.88  4.3  0.170 15.9  0.625  9.7  0.38   16680.83 N   3750 lbf   1334.46 N   300 lbf  47.8   1.88 M 12 28.7  1.13  6.4  0.250 19.1  0.750 11.2  0.44   22241.10 N   5000 lbf   3113.75 N   700 lbf  63.5   2.50 M 16 31.8  1.25  8.9  0.350 22.2  0.875 11.4  0.45   26689.32 N   6000 lbf   5337.86 N   1200 lbf  76.2   3.00 M 20 38.1  1.50 10.4  0.410 27.0  1.062 16.5  0.65   32916.84 N   7400 lbf   8006.79 N   1800 lbf 101.6   4.00 M 24 47.8  1.88 11.2  0.440 34.9  1.375 20.6  0.81   88964.43 N   20000 lbf 10675.73 N   2400 lbf 152.4   6.00 M 30 69.9  2.75 19.1  0.750 47.6  1.875 25.4  1.00 191273.53 N   43000 lbf 16013.60 N   3600 lbf Specification Information • Tapped socket Stainless steel, not hardened European Standard No. 1.4305 (AISI 303) MLPSO “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large diameter base design assures a solid support. • Type B1 Base Stainless steel European Standard No. 1.4305 (AISI 303) These leveling mounts were developed for applications where the mount needs to be easily removed, a longer than standard stud needs to be attached or the equipment already has a fixed stud on it. • Type B2 / B3 Base Delrin® plastic Temperature resistant up to 180 °F (82 °C) • RoHS compliant To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. see also... • ”Level-It”™ Leveling Mounts MLPSO (Steel Tapped Socket Type) • ”Level-It”™ Leveling Mounts LPSO (Stainless Steel Tapped Socket Type, Inch Thread) • ”Level-It”™ Leveling Mounts MLPST (Stainless Steel Threaded Stud Type) • ”NY-LEV®” Leveling Mounts WN 9000.1 (Nylon Base, Stainless Steel Tapped Socket Type) On request • Non-skid Elastomer pad • Molded Delrin® plastic base in additional sizes • For certain minimum quantities, modifications such as lag bolt holes, custom stud lengths, and other versions of plating 2 How to order 1 2 3 MLPSO-1.88-M12-B2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Type www.jwwinco.com | phone: 1-800-877-8351
16NLV1/DN 价格&库存
很抱歉,暂时无法提供与“16NLV1/DN”相匹配的价格&库存,您可以联系我们找货
