WN 300.1
Adjustable Levers
Nylon Plastic, Tapped or Plain Bore Type, with Stainless Steel Components
Inch | Metric
Specification
1
4
• Lever body
Plastic
KT
Nylon thermoplastic
-- Glass fiber reinforced
-- With molded-in stainless steel inlay
-- Temperature resistant up to 230 °F (110 °C)
• Color
Black, RAL 9005, textured finish
Orange, RAL 2004, textured finish
Gray, RAL 7035, textured finish
• Insert / retaining screw
Stainless steel
European Standard No. 1.4305 (AISI 303)
• RoHS compliant
SW
OS
GS
Information
Made in the USA, WN 300.1 adjustable levers are the result of modern industrial design: glass fiber
reinforced thermoplastic with molded-in stainless steel inlay.
All such levers have proven to be ideal wherever parts have to be clamped in a confined space or
in a particular lever position. The insert is connected to the lever via serrations that can easily be
disengaged.
Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping
position. When releasing the lever, the serrations automatically re-engage.
see also...
• Adjustable Levers WN 300.1 (Nylon Plastic, Threaded Stud Type)
• Adjustable Levers GN 300.1 (Zinc Die-Cast, Tapped or Plain Bore Type)
• Adjustable Levers GN 300.5 (Stainless Steel, Matte Shot-Blasted Finish)
• Adjustable Levers WN 303.1 (Nylon Plastic, with Push Button, Tapped or Plain Bore Type)
• Adjustable Levers GN 303.1 (Zinc Die-Cast, with Push Button, Tapped Type)
On request
• Special colors, bores, and threads
How to order (Inch)
1
2
3
4
WN 300.1-KT-45-10X32-OS
How to order (Metric)
1
2
3
4
WN 300.1-KT-92-M12-SW
18
| 2.1 Tensioning, Clamping, Switching with Levers
1
Material
2
Lever length l1
3
Thread d1 (Bore d 2 )
4
Color
1
Material
2
Lever length l1
3
4
Color
www.jwwinco.com | phone: 1-800-877-8351
WN 300.1 Adjustable Levers continued
Inch table
2
3
l1
d1
Dimensions in: inches - millimeters
3
d 2 +0.001
Thread
d3
Bore
1.18
30
10 x 32
10 x 24
1/4 x 20
B 1/4
1.77
45
10 x 32
10 x 24
1/4 x 20
B 1/4
2.48
63
1/4 x 20
5/16 x 18
B 1/4
B 5/16
3.07
78
5/16 x 18
3/8 x 16
B 5/16
B 3/8
3.62
92
3/8 x 16
1/2 x 13
B 3/8
B 1/2
d4
h1
.39
.57
14.5
.96
24.5
4
.39
.57
14.5
.96
24.5
4
.53
13.5
.76
19.4
.63
.75
10
10
16
19
h2
h3
h4
.16
1.20
30.5
.14
3.5
9
.16
1.38
35
.14
3.5
9
1.22
31
.26
6.5
1.77
45
4
.87
22.2
1.42
36
8
.31
2.17
55
4
.99
25.2
1.69
43
11
.43
2.56
65
4
Stroke
.16
.16
.16
t
min.
11
14
17
.35
.35
.43
.55
.67
Metric table
2
3
l1
d1
30
1.18
M 3
30
1.18
M 4
M 5
M6
45
1.77
M 4
M 5
63
2.48
M 6
78
3.07
92
3.62
Dimensions in: millimeters - inches
3
d 2 H7
Bore
d3
d4
h1
10
.39
14.5
.57
24.5
.96
4
B 5
B 6
10
.39
14.5
.57
24.5
.96
4
M6
B 6
10
.39
14.5
.57
24.5
.96
4
M 8
B 6
B 8
13.5
.53
19.4
.76
31
1.22
M 8
M 10
B 8
B 10
16
.63
22.2
.87
M 10
M 12
B 10
B 12
19
.75
25.2
.99
Thread
h2
h3
h4
.16
30.5
1.20
3.5
.14
7
.16
30.5
1.20
3.5
.14
9
.16
35
1.38
3.5
.14
9
6.5
.26
45
1.77
4
36
1.42
8
.31
55
2.17
4
43
1.69
11
.43
65
2.56
4
Stroke
.16
.16
.16
t
min.
11
14
17
.28
.35
.35
.43
.55
.67
2.1 Tensioning, Clamping, Switching with Levers |
19
很抱歉,暂时无法提供与“5TS34O”相匹配的价格&库存,您可以联系我们找货
