k i n g s t o n . c o m /e m m c
DRAM
Kingston DDR4 DRAM for embedded applications
Kingston on-board DDR4 DRAM is designed to meet the needs of embedded
applications and offers a high speed option with lower power consumption.
#KingstonIsWithYou
more >>
DRAM
MARKET SEGMENTS
Industrial IoT / Robotics & Factory Automation
DDR4 PART NUMBERS AND SPECIFICATIONS
Part Number
Capacity
Description
Package
Configuration
(Words x Bits)
Speed
Mbps
VDD,
VDDQ
Operating
Temperature
D5116AN9CXGRK
8Gb
96 ball FBGA
DDR4 C-Temp
7.5x13x1.2
512Mx16
2666 Mbps
1.2V
0°C ~ +95°C
KEY FEATURES
• Double-data-rate architecture: two data transfers per clock cycle
• The high-speed data transfer is realized by the 8 bits prefetch pipelined
architecture
• Bi-directional differential data strobe (DQS and /DQS) is transmitted/received
with data for capturing data at the receiver
5G Networking/Telecommunications Communication
Modules (WiFi Routers and Mesh Devices)
• DQS is edge-aligned with data for READs; center- aligned with data for WRITEs
• Differential clock inputs (CK_t and CK_c)
• DLL aligns DQ and DQS transitions with CK transitions
• Data mask (DM) write data-in at the both rising and falling edges of the
data strobe
• Write Cycle Redundancy Code (CRC) is supported
Office Equipment, Medical Devices, ATM,
Vending Machines
• Programmable preamble for read and write is supported
• Programmable burst length 4/8 with both nibble sequential and interleave mode
• BL switch on the fly
• Driver strength selected by MRS
• Dynamic On Die Termination supported
• Two Termination States such as RTT_PARK and RTT_NOM switchable by ODT pin
• Asynchronous RESET pin supported
Smart Home (Sound Bars, Thermostats, Fitness
Equipment, Vacuums, Beds, Faucets)
• ZQ calibration supported
• Write Levelization supported
• This product in compliance with the RoHS directive
• Internal Vref DQ level generation is available
• TCAR (Temperature Controlled Auto Refresh) mode is supported.
• LP ASR (Low Power Auto Self Refresh) mode is supported
Smart City (HVAC, Lighting, Power Monitoring/
Metering, Parking Meters)
• Command Address (CA) Parity (command/address) mode is supported
• Per DRAM Addressability (PDA)
• Fine granularity refresh is supported
• Geardown Mode(1/2 rate, 1/4 rate) is supported
• Self Refresh Abort is supported
• Maximum power saving mode is supported
• Banks Grouping is applied, and CAS to CAS latency (tCCD_L, tCCD_S) for the banks
in the same or different bank group accesses are available
• DMI pin support for write data masking and DBIdc functionality
THIS DOCUMENT SUBJECT TO CHANGE WITHOUT NOTICE.
©2021 Kingston Technology Corporation, 17600 Newhope Street, Fountain Valley, CA 92708 USA. All rights reserved.
All trademarks and registered trademarks are the property of their respective owners.
MKF-949 US
很抱歉,暂时无法提供与“D5116AN9CXGRK-U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+36.906253+4.47653
- 15+36.7337915+4.45562
- 40+36.7329740+4.45552
- 100+36.73216100+4.45542
- 250+36.73135250+4.45532
- 国内价格 香港价格
- 3+33.755723+4.09439
- 20+33.5979720+4.07526
- 75+33.5972375+4.07517
- 250+33.59649250+4.07508
- 1000+33.595751000+4.07499
