2271
    KITRONIK
    电池 座(开口) AAA 2 电池 导线引线,带连接器
2271 数据手册
    2xAAA Battery Cage with JST Connector 2xAAA Battery Cage with JST connector. Supplied with 145mm colour coded leads. Perfect as a power supply to the BBC micro:bit or the Igloo Wearable Module. Code 2271   Product Description This 2xAAA Battery Cage with JST connector is compatible with the Igloo, PICAXE wearable module and the BBC micro:bit. Supplied with 145mm colour coded power leads and a JST connector at the end, this battery cage is light and features a M3 mounting hole in the centre so it can be attached to the back of BBC micro:bit cases. The JST connector easily plugs into the Igloo and BBC micro:bit to provide a portable power supply. Ideal in any project kit with a JST connector power supply interface.      Features: JST connector for easy power supply connections. Holds 2 x AAA batteries. Clips hold AAA batteries securely in place. 145mm colour coded power leads and a JST connector. Clip holder resistant to sudden impacts and vibrations.  Contents: 1 x 2xAAA Battery Cage with JST Connector.    Dimensions: Length: 53mm. Width: 25mm. Height: 13mm.  Requires: 2 x AAA Batteries.               https://www.kitronik.co.uk/2271‐2xaaa‐battery‐cage‐with‐jst‐connector.html 4‐20‐18
很抱歉,暂时无法提供与“2271”相匹配的价格&库存,您可以联系我们找货
