Kitronik Discovery Kit
for Raspberry Pi Pico
(Pico not included)
Stock code: 5333
Description
Take your first steps in Python and physical computing with
the Kitronik Discovery Kit for Raspberry Pi Pico (Pico not
included).
The Kitronik Discovery Kit for Raspberry Pi Pico (Pico not included) is a great way to
learn about microcontrollers, Python coding, and physical computing. The kit is supplied
with all of the components needed to complete the 7 included experiments, including a
large-format breadboard. The kit is packaged in sturdy reusable packaging that can be
used to store the kit. This version of the kit is NOT supplied with a Raspberry Pi Pico.
The seven experiments take you from the basics of using the board through to more
advanced concepts and using external electronics. The experiments cover key concepts
of microcontrollers, such as; basic setup, simple coding, Interrupts, Threads, Digital
Inputs, and Analog and Digital Outputs.
The kit ships with a comprehensive guide booklet. The booklet covers the basic setup
and then how to complete each of the 7 experiments. Each experiment is complete with
detailed circuit diagrams, explanations, and a complete code run-through. This means
that you can get started without having to understand too much Python.
The Raspberry Pi Pico board, a new low cost, high-performance microcontroller. The
board features a powerful new, Raspberry Pi designed ARM-based dual-core chip-- the
RP2040. The pico also features 64KB of internal RAM and support for up to 16MB of
off-chip Flash. A wide range of flexible I/O options includes I2C, SPI, and
Programmable I/O (PIO). These support endless possible applications for this small and
affordable board.
The kit is programmed using MicroPython. This is a full Python 3 implementation
created specifically for small embedded microcontrollers, such as the Pico and the
popular BBC micro:bit. You will use the Thonny editor to create your code, which can
then be saved directly to the Pico from the editor via USB. Thonny is a Python
Editor/IDE designed to allow beginners to get up and running with Python coding with
as little fuss as possible.
A power pack is not required as power will be supplied via the USB connection to the
computer that the Thonny editor is running on.
Note:
A USB cable is NOT supplied. USB cables capable of data transfer and power are
available separately here.
The Raspberry Pi Pico is NOT supplied with this kit. There is a version of this kit that
has a Pico included, available here.
Features:
This kit offers a great introduction to microcontrollers, Python coding, and physical
computing.
Make the 7 experiments in the step-by-step tutorial book and learn as you go.
All parts are included to conduct the 7 experiments.
The kit is supplied with a detailed booklet that covers setup and then how to complete
the 7 experiments.
The experiments explore; simple coding, Interrupts, Threads, Digital Inputs, and
Once you have completed all of the included experiments, you have the perfect
prototyping system for further learning/prototyping with the Raspberry Pi Pico board.
Included is a large format breadboard for ease of prototyping.
The kit is supplied in re-usable packaging suitable for long term storage of the kit.
Contents:
1 x Large Prototype Breadboard.
2 x Red 5mm LED.
2 x Yellow 5mm LED.
2 x Green 5mm LED.
10 x 330Ω Resistor.
1 x Piezo Element Buzzer.
20 x Male to Male Jumper Wires.
2 x Push Switches.
A booklet guide containing basic setup information and the following 7 experiments;
▪ Exp. 1 - Show Me The Light.
▪ Exp. 2 - Control an Input.
▪ Exp. 3 - Interrupt Me.
▪ Exp. 4 - Making a Noise.
▪ Exp. 5 - So Many Interruptions.
▪ Exp. 6 - Rub Head and Pat Tummy - Threads.
▪ Exp. 7 - Building a System from the Blocks we have Learnt.
Video:
https://www.youtube.com/watch?v=mHoK79NE1uc&feature=emb_i
mp_woyt
Requires:
USB Lead.
Raspberry Pi Pico (With headers - assembled).
Or Pico with;
o Pin Headers.
Resources:
MicroPython Code for all 7 Discovery Kit Experiments.
Get started with MicroPython on Raspberry Pi Pico.
Tech Talks - live stream playback.
Raspberry Pi Pico frequently asked questions.
More information on the Pico.
About MicroPython.
About Python.
The Thonny editor.
Raspberry Pi pico Datasheet.
RP2040 Datasheet.
Discovery Kit Extension Experiments:
The table below contains links to extension experiments for the Pico Discovery Kit. They
have been listed in the order that they should be completed, and they should only be
tackled once you have completed the 7 experiments supplied with the kit. Each
extension experiment is thoroughly explained and code examples are provided.
Although they cover quite challenging concepts, the information is provided in such a
way as to walk you through the solution.
Exp No#.
1
Experiment Name/Link.
Pico Thermometer.
2
Storing Data on the Pico.
3
Live Data Logging on the Pico.
This product is designed and manufactured in the UK by Kitronik.
https://kitronik.co.uk/products/5333-kitronik-discovery-kit-for-raspberry-pi-pico-pico-not-included?_pos=1&_sid=e25b08807&_ss=r/3-15-22
很抱歉,暂时无法提供与“5333”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+96.09889
- 5+93.90157
- 10+92.52695
- 100+86.44527
