FM Radio Telescopic Antenna / Aerial
An FM Aerial Antenna add-on, telescopic design and compatible with FM Radio Kit 2157.
Code 2006
Product Description
This FM Aerial Antenna is designed to be compatible with the 2157 FM Radio Kit.
Includes solder tag and bolt for simple implementation with the kit, to bring your project to life!
Features:
Telescopic design for compact storage.
Universal Compatibility.
Contents:
1 x FM Radio Aerial Antenna.
1 x M2 Nut.
1 x M2 Bolt, 16mm, Pan Head.
1 x Solder Tag For Antenna.
Dimensions:
Length (Minimum): 11cm.
Length (Maximum): 49cm.
Requires:
1 x 2157 FM Radio Kit.
Soldering Iron.
Solder.
Screwdriver.
Pliers.
https://www.kitronik.co.uk/2006‐fm‐radio‐telescopic‐antenna‐aerial.html 4‐20‐18
很抱歉,暂时无法提供与“2006”相匹配的价格&库存,您可以联系我们找货
