Motors
MINI LOW TORQUE FLAT DC MOTOR LOW TORQUE DC MOTOR
MM10 3V DC motor, operating voltage 1.5V to
4.5V. The two flat sides enable easy mounting
onto a panel or PCB. Typical speed 12400
RPM, typical current 1.5A.
Axle diameter: 2mm.
Length: 25mm.
Diameter: 20mm.
Shaft: 8.1mm, diameter: 2mm.
Axle diameter: 2mm.
Length: 25mm.
Diameter: 21mm.
1+
10+
2543
Description
Code
Low torque DC motor - 10 pack
2510
1+
MEDIUM TORQUE DC MOTOR
HIGH TORQUE DC MOTOR
MM18 3V DC motor, operating voltage 1.5V to
4.5V. Mountable using x2 M3 bolts. Typical speed
5000 RPM, typical current 350 mA. Pack of 10.
MM28 3V DC motor, operating voltage 1.5V to
6V. Mountable using x2 M3 bolts. Typical speed
7930 RPM, typical current 760 mA. Pack of 10.
Axle diameter: 2mm.
Length: 30.5mm.
Diameter: 24mm.
Shaft: 10mm, diameter: 2mm.
Axle diameter: 2mm.
Length: 27mm.
Diameter: 24mm.
Shaft: 8.6mm, diameter: 2mm.
Description
Code
Med torque DC motor - 10 pack
2501
1+
Description
Code
1+
High torque DC motor - 10 pack 2507
LOW INERTIA MOTOR - 1760 RPM
LOW INERTIA MOTOR - 1820 RPM
Low inertia motor ideal for low power
applications such as solar. Voltage
range 0.7 to 5.0V (2V nominal).
This is a low inertia solar DC mini motor.
Operating voltage: 0.5V to 3V. Starting speed:
1000. Starting current: 30ma at 0.5V.
Axle diameter: 2mm.
Length: 12.8mm.
Diameter: 24.4mm.
Shaft: 6mm, diameter: 2mm.
Code
2506
1+
Axle diameter: 2mm.
Length: 12.8mm.
Diameter: 24.4mm.
Shaft: 10.5mm, diameter: 2mm.
10+
50+
Code
1+
10+
100+
2546
www.kitronik.co.uk
sales@kitronik.co.uk
Components
Code
MM12 3V DC motor, operating voltage 1.5V to
3.0V. Mountable using x2 M3 bolts. Typical speed
11500 RPM, typical current 1.05A. Pack of 10.
很抱歉,暂时无法提供与“2546”相匹配的价格&库存,您可以联系我们找货
