TYS60454R5M-10
TYS60454R5M-10
    LAIRD(莱尔德)
    非标准
    FIXED IND 4.5UH 3.3A 26 MOHM SMD
TYS60454R5M-10 数据手册
Ferrite EMI Cable Cores About Laird Laird is a global technology business focused on enabling wireless communication and smart systems, and providing components and systems that protect electronics. Laird operates through two divisions, Wireless Systems and Performance Materials. Wireless Systems solutions include antenna systems, embedded wireless modules, telematics products and wireless automation and control solutions. Performance Materials solutions include electromagnetic interference shielding, thermal management and signal integrity products. As a leader in the design, supply and support of innovative technology, our products allow people, organisations, machines and applications to connect effectively, helping to build a world where smart technology transforms the way of life. Custom products are supplied to major sectors of the electronics industry including the handset, telecommunications, IT, automotive, public safety, consumer, medical, rail, mining and industrial markets. Providing value and differentiation to our customers through innovation, reliable fulfilment and speed, Laird PLC is listed and headquartered in London, and employs over 9,000 people in more than 58 facilities located in 18 countries. TABLE OF CONTENTS Ferrite Material Impedance Comparison ................................................ 3 Design & Selection “Rules of Thumb” ..................................................... 3 High Frequency (HFB-) Cylindrical Cores ................................................ 4 High Frequency (HFA-) Split, Snap-On Cores .......................................... 5 Broadband (28B-) Cylindrical Cores ....................................................... 6 Broadband (28A-) Split, Snap-On Cores ................................................. 9 Low Frequency (LFB-) Cylindrical Cores ................................................ 15 Broadband (28R) Ribbon & Flex Cable Cores ....................................... 16 Broadband (28S) Split Ribbon & Flex Cable Cores ............................... 20 Ferrite EMI Disks & Plates .................................................................... 26 Ferrite Plates for Wireless Charging ...................................................... 27 Flexible Ferrite Sheets ........................................................................... 29 Sample Kit Lists .................................................................................... 32 Pb All parts listed in this catalog are lead free and RoHS compliant. NOTICE Laird’s products or subcomponents are not specifically designed or tested by Laird for use in any medical applications, surgical applications, medical device manufacturing, or any similar procedure or process requiring approval, testing, or certification by the United States food and drug administration or other similar Governmental entity. Applications with unusual environmental requirements such as military, medical, life-support or Life-sustaining equipment are specifically not recommended without additional testing for such application. FERRITE EMI CABLE CORES FERRITE MATERIAL COMPARISON LF, 28 & HF MATERIAL IMPEDANCE VS FREQUENCY (300 KHz - 2 GHz) Impedance Materials for Cable & Wiring Harness Cores HF LF Low Frequency 28 Impedance (Z) in Ohms (Ω) 28 Broadband High Performance HF High Frequency LF 0.3 0.5 1 5 10 50 100 1000 2000 Frequency (MHz) DESIGN & SELECTION “RULES OF THUMB” SELECT THE APPROPRIATE FERRITE MATERIAL For the EMI frequency range to be attenuated, refer to cable core material impedance vs.frequency chart above. FERRITE MATERIAL COMPOSITION AFFECTS CORE PERFORMANCE MOST High-performance material is best. Cheap, low-performance materials require the use of larger, heavier cores. SHAPE (DESIGN) AND MASS OF THE FERRITE CORE SIGNIFICANTLY AFFECT IMPEDANCE DON’T OVER SIZE Use high-performance ferrite material and select the smallest core that will do the job. High-performance material allows the use of smaller, lighter and lower cost cores. SELECT A FERRITE CORE THAT FITS OVER THE CABLE’S OUTSIDE DIMENSIONS Core should slide easily over the cable during installation. WHEN POSSIBLE, INSTALL A CABLE CORE OVER WIRES IN A COMMON MODE CONFIGURATION (Out and back lines inside the same ferrite cable core). A differential cable pair inside the same core will make the ferrite core a common mode choke that is not susceptible to saturation from very high currents. INSTALL THE FERRITE CORE NEAR THE NOISE SOURCE ADDITIONAL TURNS THROUGH A CORE WILL PROVIDE MULTIPLE AMOUNTS OF PEAK IMPEDANCE Example: Two wire turns provide four times the impedance of one turn (pass through) the ferrite core. Also, with each added turn, the peak impedance shifts to a slightly lower frequency. TWO-PIECE SPLIT CORES ARE AVAILABLE One-piece cylindrical or flat ribbon ferrite core shapes are usually preferable, but split cores can be used in applications where cores cannot slide over cable ends and connectors. Some split cores are available with snap-on plastic cases or metal clips. SIDE-BY-SIDE IMPEDANCE TESTING OF FERRITE CORES IS THE BEST WAY TO COMPARE PERFORMANCE OF DIFFERENT CORES Ferrite core impedance measurement equipment and test methods are not standardized in the industry. Every ferrite company has their own test methods. Catalog (web site) impedance data cannot be accurately compared. Optimized, high-performance, low-cost custom part designs are available. www.laird.com 3 FERRITE EMI CABLE CORES HIGH FREQUENCY FERRITE CYLINDRICAL EMI CORES 300 MHZ TO 2 GHZ OPTIMIZED Cylindrical Solid Ferrite Cores for Round Cables & Wiring Harnesses PART NUMBERING SYSTEM EXAMPLE HF B 075024 -0 0 0 Material Type Product Code Part Size Code (mm) Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code DIMENSIONS mm (inches) Part Number 4 www.laird.com Typical Impedance (Z) in Ohms (Ω) A B C @ 300 MHz @ 500 MHz @ 800 MHz @1 GHz HFB0473-200 12.00 (0.472) 3.55 (0.140) 25.00 (0.984) 320 378 – 147 HFB075024-000 7.50 (0.295) 2.40 (0.094) 10.00 (0.394) 124 136 138 133 HFB095051-100 9.52 (0.375) 5.08 (0.200) 10.00 (0.394) 64 74 89 85 HFB095051-200 9.52 (0.375) 5.08 (0.200) 19.00 (0.748) 120 135 151 147 HFB123049-000 12.32 (0.485) 4.88 (0.192) 5.00 (0.197) 50 56 63 61 HFB123049-100 12.32 (0.485) 4.88 (0.192) 10.00 (0.394) 97 110 120 115 HFB123049-300 12.32 (0.485) 4.88 (0.192) 25.40 (1.000) 258 287 300 246 HFB143064-000 14.27 (0.562) 6.35 (0.250) 5.00 (0.197) 43 50 58 60 HFB143064-100 14.27 (0.562) 6.35 (0.250) 10.00 (0.394) 85 100 113 115 HFB143064-300 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 270 315 270 200 HFB150070-200 14.99 (0.590) 6.99 (0.275) 28.58 (1.125) 242 287 270 204 HFB152034-000 15.24 (0.600) 3.38 (0.133) 10.00 (0.394) 165 190 189 185 HFB157070-000 15.65 (0.616) 6.99 (0.275) 20.00 (0.787) 170 200 220 205 HFB159079-000 15.88 (0.625) 7.87 (0.310) 20.00 (0.787) 150 175 186 195 HFB159079-100 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 235 290 302 260 HFB160093-200 16.00 (0.630) 9.25 (0.364) 19.00 (0.748) 120 145 155 170 HFB160093-300 16.00 (0.630) 9.25 (0.364) 27.99 (1.102) 170 198 232 220 HFB170070-000 16.99 (0.669) 7.01 (0.276) 10.00 (0.394) 97 115 127 140 HFB170070-100 16.99 (0.669) 7.01 (0.276) 20.00 (0.787) 185 215 239 220 HFB187102-100 18.67 (0.735) 10.16 (0.400) 30.00 (1.181) 205 250 270 210 HFB259128-100 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 175 210 254 250 All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the FERRITE EMI CABLE CORES HIGH FREQUENCY FERRITE SPLIT / SNAP-ON, CORES IN PLASTIC CASES 300 MHZ TO 2 GHZ OPTIMIZED Split, Snap-on Ferrite Cores in Plastic Cases For retrofit and post-assembly operations, a selection of high frequency EMI “split” cores are offered. Similar in performance to one-piece cylindrical core designs, these split ferrite cores provide excellent common and differential mode high frequency EMI suppression on round cable and wire assemblies. Black plastic snap-on cases provide secure closure of the split cores onto the cable or wire bundle. PART NUMBERING SYSTEM EXAMPLE HF A 100035 -0 A 2 Material Type Product Code Part Size Code (mm) Selected Dimension Code (Usually Length) Additional Part Description Plastic Case Color Code Part Number PLASTIC CASE DIMENSIONS mm (inches) A B C D Maximum Cable Diameter mm (inches) Fig # All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. Typical Impedance (Z) in Ohms (Ω) @ 300 MHz @ 500 MHz @ 800 MHz @1 GHz Laird Solid Cylindrical Core Similar Parts (for reference) HFA100035-0A2 1 13.00 (0.511) 3.50 (0.138) 25.20 (0.992) 11.50 (0.453) 3.51 (0.138) 172 192 190 150 HFB123049-300 HFA100049-0A2 1 13.72 (0.540) 5.44 (0.214) 30.56 (1.203) 13.72 (0.540) 4.88 (0.192) 133 152 168 162 HFB095051-200 HFA150066-0A2 2 18.15 (0.715) 7.05 (0.278) 32.50 (1.280) 18.90 (0.744) 6.60 (0.260) 274 350 340 256 HFB143064-300 HFA150068-0A2 1 21.00 (0.827) 6.80 (0.268) 41.70 (1.642) 21.00 (0.827) 6.76 (0.266) 275 340 281 200 HFB150070-200 HFA163090-0A2 1 20.07 (0.790) 9.07 (0.357) 41.55 (1.636) 21.57 (0.849) 9.01 (0.355) 210 260 262 200 HFB160093-300 HFA187102-0A2 2 22.88 (0.877) 10.00 (0.394) 32.77 (1.290) 21.84 (0.860) 10.16 (0.400) 220 290 281 210 HFB187102-100 HFA259131-0A2 2 29.00 (1.142) 13.00 (0.512) 32.50 (1.280) 29.62 (1.166) 13.06 (0.514) 250 315 272 200 HFB259128-100 0A2 part number sufix designates black plastic case. Additional colors may be available, please inquire with Laird customer service. Figure 1 Figure 2 D B A C Please visit lairdtech.com for the most up to date information. Custom parts are available. www.laird.com 5 FERRITE EMI CABLE CORES BROADBAND EMI FERRITE CYLINDRICAL CORES FOR ROUND CABLES & WIRING HARNESSES PART NUMBERING SYSTEM EXAMPLE 28 B 0141 -0 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code Part Number 6 www.laird.com DIMENSIONS mm (inches) Typical Impedance (Z) in Ohms (Ω) A B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0141-000 3.50 (0.138) 1.50 (0.059) 3.25 (0.128) 30 79 192 28B0157-100 4.00 (0.157) 2.00 (0.079) 10.00 (0.394) 67 121 236 28B0250-100 6.35 (0.250) 3.18 (0.125) 15.88 (0.625) 90 182 300 28B0250-700 6.35 (0.250) 3.18 (0.125) 10.00 (0.394) 64 135 255 28B0268-000 6.78 (0.267) 3.99 (0.157) 14.22 (0.560) 65 138 260 28B0275-000 7.00 (0.276) 3.80 (0.150) 13.50 (0.531) 69 146 268 28B0296-000 7.52 (0.296) 2.39 (0.94) 7.54 (0.297) 75 160 270 28B0315-000 8.00 (0.315) 3.17 (0.125) 4.78 (0.188) 43 100 220 28B0315-100 8.00 (0.315) 3.17 (0.125) 10.06 (0.396) 76 158 281 28B0339-000 8.60 (0.339) 3.80 (0.150) 10.00 (0.394) 68 143 264 28B0355-000 9.00 (0.354) 4.75 (0.187) 20.00 (0.787) 110 205 360 28B0375-000 9.53 (0.375) 5.08 (0.200) 10.41 (0.410) 57 125 245 28B0375-100 9.53 (0.375) 5.08 (0.200) 14.48 (0.570) 74 154 282 28B0375-300 9.53 (0.375) 5.08 (0.200) 19.05 (0.750) 100 194 310 28B0375-400 9.52 (0.375) 5.08 (0.200) 4.83 (0.190) 33 81 200 28B0384-000 9.75 (0.384) 3.80 (0.150) 10.00 (0.394) 82 159 286 28B0384-200 9.75 (0.384) 3.80 (0.150) 25.00 (0.984) 182 322 473 28B0390-200 9.91 (0.390) 6.35 (0.250) 15.00 (0.590) 57 128 248 28B0394-000 10.00 (0.394) 5.00 (0.197) 5.00 (0.197) 34 86 201 28B0395-000 10.01 (0.394) 5.97 (0.235) 6.17 (0.243) 31 83 199 28B0434-000 11.00 (0.433) 5.10 (0.201) 32.00 (1.260) 200 349 481 28B0452-000 11.70 (0.461) 7.70 (0.303) 15.00 (0.590) 52 116 235 28B0453-000 11.50 (0.453) 4.90 (0.193) 25.00 (0.984) 148 262 378 Broadband (28) round cable parts are sorted by diameter (B) on pages 11 & 12 and sorted by impedance on pages 13 & 14. Please refer to the separate Toroid Catalog from Laird for an extensive list of small ferrite inductor toroid core sizes and materials. FERRITE EMI CABLE CORES BROADBAND EMI FERRITE CYLINDRICAL CORES Part Number DIMENSIONS mm (inches) Typical Impedance (Z) in Ohms (Ω) A B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0470-000 12.00 (0.472) 5.60 (0.220) 20.00 (0787) 109 211 344 28B0473-000 12.00 (0.472) 3.55 (0.140) 10.00 (0.394) 101 195 320 28B0473-200 12.00 (0.472) 3.55 (0.140) 25.00 (0.984) 240 424 558 28B0474-000 12.00 (0.472) 4.50 (0.177) 20.00 (0.787) 138 245 370 28B0485-000 12.32 (0.485) 4.88 (0.192) 25.40 (1.000) 170 320 450 28B0500-100 12.70 (0.500) 7.92 (0.312) 6.35 (0.250) 33 83 200 28B0500-300 12.70 (0.500) 7.92 (0.312) 12.70 (0.500) 54 118 230 28B0562-000 14.27 (0.562) 6.35 (0.250) 10.16 (0.400) 69 145 270 28B0562-100 14.27 (0.562) 6.35 (0.250) 13.46 (0.530) 89 184 303 28B0562-200 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 159 294 439 28B0562-500 14.27 (0.562) 6.35 (0.250) 38 (1.496) 196 358 487 28B0562-300 14.27 (0.562) 6.35 (0.250) 28.32 (1.115) 150 270 420 28B0563-000 14.27 (0.562) 7.26 (0.286) 15.24 (0.600) 85 173 295 28B0563-100 14.27 (0.562) 7.26 (0.286) 20.30 (0.800) 109 217 333 28B0563-200 14.27 (0.562) 7.26 (0.286) 28.57 (1.125) 149 287 406 28B0570-000 14.48 (0.570) 8.51 (0.335) 5.51 (0.217) 32 82 200 28B0590-000 14.99 (0.590) 6.99 (0.275) 27.94 (1.100) 170 300 450 28B0591-200 15.00 (0.591) 5.90 (0.232) 35.00 (1.378) 207 377 508 28B0592-000 15.00 (0.591) 4.50 (0.177) 40.00 (1.575) 361 653 627 28B0616-000 15.65 (0.616) 6.99 (0.275) 28.58 (1.125) 170 310 450 28B0625-000 15.88 (0.625) 7.87 (0.310) 14.27 (0.563) 79 163 273 28B0625-100 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 150 280 400 28B0629-000 16.00 (0.630) 10.00 (0.394) 16.00 (0.630) 60 129 248 28B0631-000 16.00 (0.630) 9.25 (0.364) 11.99 (0.472) 60 130 250 28B0631-100 16.00 (0.630) 9.25 (0.364) 27.99 (1.102) 124 243 370 Additional wire turns multiply impedance www.laird.com 7 FERRITE EMI CABLE CORES BROADBAND EMI FERRITE CYLINDRICAL CORES Part Number 8 www.laird.com DIMENSIONS mm (inches) Typical Impedance (Z) in Ohms (Ω) A B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0672-000 17.07 (0.672) 8.76 (0.345) 25.40 (1.000) 130 245 360 28B0686-000 17.42 (0.686) 9.52 (0.375) 6.35 (0.250) 39 91 214 28B0686-100 17.42 (0.686) 9.52 (0.375) 12.70 (0.500) 66 139 265 28B0686-200 17.42 (0.686) 9.53 (0.375) 28.58 (1.125) 124 242 390 28B0734-000 18.67 (0.735) 11.18 (0.440) 28.58 (1.125) 116 229 370 28B0735-000 18.67 (0.735) 10.16 (0.400) 28.58 (1.125) 135 250 400 28B0735-300 18.67 (0.735) 10.16 (0.400) 14.27 (0.562) 73 150 270 28B0825-000 20.95 (0.825) 13.21 (0.520) 6.35 (0.250) 31 79 204 28B0870-000 22.10 (0.870) 13.72 (0.540) 6.35 (0.250) 34 85 205 28B0870-100 22.10 (0.870) 13.72 (0.540) 12.70 (0.500) 56 122 236 28B0886-20H 22.80 (0.898) 13.80 (0.543) 8.80 (0.347) 37 90 199 28B0999-000 25.40 (1.000) 15.49 (0.610) 12.70 (0.500) 56 122 247 28B1000-000 25.40 (1.000) 12.70 (0.500) 12.70 (0.500) 73 151 278 28B1020-100 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 147 276 412 28B1122-100 28.50 (1.122) 13.77 (0.542) 28.58 (1.125) 160 307 440 28B1122-300 28.50 (1.122) 13.77 (0.542) 20.00 (0.787) 115 210 350 28B1142-000 29.01 (1.142) 19.00 (0.748) 7.49 (0.295) 34 85 200 28B1142-100 29.01 (1.142) 19.00 (0.748) 13.84 (0.545) 54 114 235 28B1225-000 31.12 (1.225) 19.05 (0.750) 15.93 (0.627) 68 140 270 28B1225-100 31.12 (1.225) 19.05 (0.750) 7.92 (0.312) 39 93 210 28B1225-300 31.12 (1.225) 19.05 (0.750) 10.00 (0.394) 46 110 240 28B1250-000 31.75 (1.250) 19.05 (0.750) 22.22 (0.875) 92 186 292 28B1417-200 36.00 (1.417) 23.00 (0.905) 12.70 (0.500) 52 115 230 28B1531-000* 38.86 (1.530) 12.95 (0.510) 28.58 (1.125) 109 210 347 28B1540-000 39.12 (1.540) 16.76 (0.660) 22.22 (0.875) 130 254 405 28B2000-100 50.80 (2.000) 25.40 (1.000) 28.70 (1.130) 157 305 442 28B2400-000 60.96 (2.400) 35.56 (1.400) 12.70 (0.500) 60 135 285 *Oval Core Part Number 28B1531-000 DIMENSIONS mm (inches) D E 26.16 (1.030) 26.04 (1.025) Broadband (28) round cable parts are sorted by diameter (B) on pages 11 & 12 and sorted by impedance on pages 13 & 14. Custom parts are also available FERRITE EMI CABLE CORES BROADBAND EMI FERRITE SPLIT / SNAP-ON CORES IN PLASTIC CASES FOR ROUND CABLES & WIRING HARNESSES For retrofit and post-assembly operations, Laird offers a selection of “split” cores. Similar in performance to the one-piece core designs, these split ferrite cores provide excellent common and differential mode EMI suppression on round cable and wire assemblies. Black or white plastic snap-on cases provide secure closure of the split cores onto the cable. PART NUMBERING SYSTEM EXAMPLE Broadband (28) round cable parts are sorted by diameter (B) on pages 11 & 12 and sorted by impedance on pages 13 & 14. *0A0 = White Plastic Snap On Case *0A2 = Black Plastic Snap On Case 28 A 0350 -0 B *0 (white case) *2 (black case) Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Plastic Case Color Code Part Number Fig # on page 10 28A0350-0B2 1 28A0392-0A* 1 28A0434-0A2 4 28A0592-0A2 4 28A0593-0A2 4 28A0640-0A* 1 28A0807-0A2 4 28A1507-0A2 3 28A2005-0A2 3 28A2024-0A* 2 28A2025-0A* 2 28A2026-0A2 1 28A2029-0A* 2 28A2307-0A2 3 28A2432-0A2 3 28A2736-0A2 1 28A2809-0A2 3 28A2738-0A2 3 28A2913-0A2 3 28A3039-0A2 3 28A3851-0A2 1 28A4155-0A2 3 28A5131-0A2 5 28A5776-0A2 2 PLASTIC CASE DIMENSIONS mm (inches) A B C D Maximum Cable Diameter mm (inches) 13.00 (0.511) 13.72 (0.540) 14.71 (0.579) 18.75 (0.738) 18.75 (0.738) 20.07 (0.790) 24.82 (0.977) 15.00 (0.591) 13.00 (0.512) 29.00 (1.142) 18.15 (0.715) 21.00 (0.827) 22.28 (0.877) 16.50 (0.650) 19.20 (0.756) 19.70 (0.776) 19.70 (0.776) 19.70 (0.776) 23.50 (0.925) 24.55 (0.967) 30.00 (1.181) 28.80 (1.134) 56.64 (2.230) 29.20 (1.150) 4.90 (0.193) 5.44 (0.214) 5.44 (0.214) 5.04 (0.198) 6.75 (0.266) 9.07 (0.357) 10.00 (0.394) 7.00 (0.276) 5.00 (0.197) 13.00 (0.512) 7.05 (0.278) 6.80 (0.268) 10.00 (0.394) 7.00 (0.276) 8.20 (0.323) 9.00 (0.354) 9.00 (0.354) 9.00 (0.354) 13.06 (0.514) 10.20 (0.402) 13.00 (0.512) 13.60 (0.535) 19.50 (0.768) 20.00 (0.787) 25.50 (1.004) 30.56 (1.203) 43.03 (1.694) 53.39 (2.102) 52.91 (2.083) 41.55 (1.636) 55.91 (2.201) 18.00 (0.709) 25.50 (1.004) 32.50 (1.280) 32.50 (1.280) 41.70 (1.642) 32.77 (1.290) 30.50 (1.201) 19.90 (0.783) 35.10 (1.382) 35.25 (1.388) 35.10 (1.382) 36.25 (1.427) 13.60 (0.535) 33.70 (1.327) 15.40 (0.606) 45.00 (1.772) 42.00 (1.654) 11.70 (0.460) 13.72 (0.540) 14.70 (0.579) 18.75 (0.738) 18.75 (0.738) 21.57 (0.849) 24.82 (0.977) 22.00 (0.866) 11.70 (0.461) 29.62 (1.166) 18.90 (0.744) 21.00 (0.827) 21.84 (0.860) 15.25 (0.600) 23.10 (0.909) 18.00 (0.709) 18.25 (0.719) 18.00 (0.709) 22.00 (0.866) 28.50 (1.122) 30.00 (1.181) 33.20 (1.307) 56.63 (2.230) 29.40 (1.157) 3.50 (0.138) 4.75 (0.187) 5.05 (0.199) 4.40 (0.137) 6.50 (0.256) 8.95 (0.352) 10.00 (0.394) 7.00 (0.276) 2.50 (0.098) 12.85 (0.506) 6.45 (0.254) 6.45 (0.254) 9.95 (0.392) 7.00 (0.276) 8.05 (0.317) 8.90 (0.350) 9.00 (0.354) 8.00 (0.315) 13.00 (0.512) 10.15 (0.400) 12.85 (0.506) 13.55 (0.533) 25.40 (1.000) 19.40 (0.764) Broad Band High Performance Material is 28 High Frequency Material is HF Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz Laird Solid Cylindrical Core Similar Parts (for reference) 100 240 400 28B0472-090 75 170 320 28B0375-300 111 277 449 28B0434-000 232 511 627 28B0592-000 186 407 575 28B0591-200 105 240 390 28B0631-100 160 348 514 28B0735-000 56 123 246 28B0563-100 88 190 330 28B0394-000 130 280 440 28B1020-100 130 320 510 28B0562-200 95 270 460 28B0562-200 95 250 420 28B0734-000 92 183 315 28B0625-100 62 160 300 28B0672-000 120 220 360 28B0631-100 120 220 360 28B0631-000 106 233 366 28B0625-100 86 177 305 28B1020-100 55 130 250 28B0735-300 150 260 410 28B1020-100 50 120 230 28B0825-000 187 425 533 28B2000-100 115 210 360 28B1250-000 www.laird.com 9 FERRITE EMI CABLE CORES HIGH FREQUENCY SPLIT / SNAP-ON, FERRITE CORES IN PLASTIC CASES @ 300 MHz @ 500 MHz @ 800 MHz @1 GHz Laird Technologies Solid Cylindrical Core Similar Parts (for reference) 3.51 (0.138) 172 192 190 150 HFB100035-000 13.72 (0.540) 4.88 (0.192) 133 152 168 162 HFB095051-200 32.50 (1.280) 18.90 (0.744) 6.60 (0.260) 274 350 340 256 HFB143064-200 6.80 (0.268) 41.70 (1.642) 21.00 (0.827) 6.76 (0.266) 275 340 281 200 HFB150070-200 19.10 (0.752) 9.09 (0.358) 40.36 (1.589) 20.80 (0.819) 9.01 (0.355) 210 260 262 200 HFB160093-300 2 22.28 (0.877) 10.00 (0.394) 32.77 (1.290) 21.84 (0.860) 10.16 (0.400) 220 290 281 210 HFB187102-100 2 29.00 (1.142) 13.00 (0.512) 32.50 (1.280) 29.62 (1.166) 13.06 (0.514) 250 315 272 200 HFB259128-100 Part Number Fig # HFA100035-0A2 HFA100049-0A2 Maximum Cable Diameter mm (inches) PLASTIC CASE DIMENSIONS mm (inches) A B C D 1 13.00 (0.511) 3.50 (0.138) 25.20 (0.992) 11.50 (0.453) 1 13.72 (0.540) 5.44 (0.214) 30.56 (1.203) HFA150066-0A2 2 18.15 (0.715) 7.05 (0.278) HFA150068-0A2 1 21.00 (0.827) HFA163090-0A2 1 HFA187102-0A2 HFA259131-0A2 Typical Impedance (Z) in Ohms (Ω) All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. -0A2 = Black Plastic Snap-On Case - Other parts may be available. Please contact Laird. PLASTIC CASE SPLIT / SNAP-ON PART DIAGRAMS Figure 2 Figure 1 C B B C A A Figure 4 Figure 5 A C C A B D 10 www.laird.com A C D D B Figure 3 FERRITE EMI CABLE CORES REFERENCE CHART SORTED BY DIAMETER (B) BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28B) & SPLIT / SNAP-ON (28A) CORES FOR ROUND CABLES & WIRES PART NUMBER Sorted by Diameter (B) DIMENSIONS in mm C DIMENSIONS in mm A B 28B0141-000 3.5 1.50 3.25 - 28B0434-000 11.00 5.10 32.00 - 28B0157-100 4.00 2.00 10.00 - 28A0434-0A2 14.71 5.44 43.03 14.70 28B0296-000 7.52 2.39 7.54 - 28A0392-0A* 13.72 5.44 30.56 13.72 28B0315-000 8.00 3.17 4.78 - 28B0470-000 12.00 5.60 20.00 - 28B0315-100 8.00 3.17 10.06 - 28B0591-200 15.00 5.90 35.00 - 28B0250-100 6.35 3.18 15.88 - 28B0395-000 10.01 5.97 6.17 - 28B0250-700 6.35 3.18 10.00 - 28B0562-000 14.27 6.35 10.16 - 28B0473-000 12.00 3.55 10.00 - 28B0562-100 14.27 6.35 13.46 - 28B0473-200 12.00 3.55 25.00 - 28B0390-200 9.91 6.35 15.00 - 28B0339-000 8.60 3.80 10.00 - 28B0562-300 14.27 6.35 28.32 - 28B0384-000 9.75 3.80 10.00 - 28B0562-500 14.27 6.35 38.00 - 28B0275-000 7.00 3.80 13.50 - 28B0562-200 14.27 6.35 28.58 - 28B0384-200 9.75 3.80 25.00 - 28A0593-0A2 18.75 6.75 52.91 18.75 28B0268-000 6.78 3.99 14.22 - 28A2026-0A2 21.00 6.80 41.70 21.00 28B0474-000 12.00 4.50 20.00 - 28B0590-000 14.99 6.99 27.94 - 28B0592-000 15.00 4.50 40.00 - 28B0616-000 15.65 6.99 28.58 - 28B0355-000 9.00 4.75 20.00 - 28A1507-0A2 15.00 7.00 18.00 22.00 28B0485-000 12.32 4.88 25.40 - 28A2307-0A2 16.50 7.00 30.50 15.25 28A0350-0B2 13.00 4.90 25.20 11.70 28A2025-0A* 18.15 7.05 32.50 18.90 28B0453-000 11.50 4.90 25.00 - 28B0563-000 14.27 7.26 15.24 - 28A2005-0A2 13.00 5.00 25.50 11.70 28B0563-100 14.27 7.26 20.30 - 28B0394-000 10.00 5.00 5.00 - 28B0563-200 14.27 7.26 28.57 - 28A0592-0A2 18.75 5.04 53.39 18.75 28B0452-000 11.70 7.70 15.00 - 28B0375-400 9.52 5.08 4.83 - 28B0625-000 15.88 7.87 14.27 - 28B0375-000 9.53 5.08 10.41 - 28B0625-100 15.88 7.87 28.58 - 28B0375-100 9.53 5.08 14.48 - 28B0500-100 12.70 7.92 6.35 - 28B0375-300 9.53 5.08 19.05 - Refer to pages 6, 7, 8 & 9 for more broadband data. All chart data can be sorted on lairdtech.com. D PART NUMBER Sorted by Diameter (B) A B C D 28B0500-300 12.70 7.92 12.70 - 28A2432-0A2 19.20 8.20 19.90 23.10 28B0570-000 14.48 8.51 5.51 - 28B0672-000 17.07 8.76 25.40 - www.laird.com 11 FERRITE EMI CABLE CORES REFERENCE CHART SORTED BY DIAMETER (B) BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28B) & SPLIT / SNAP-ON (28A) CORES FOR ROUND CABLES & WIRES PART NUMBER Sorted by Diameter (B) A DIMENSIONS in mm B C D 28A2736-0A2 19.70 9.00 35.10 18.00 28B1540-000 28A2809-0A2 19.70 9.00 35.25 18.25 28B1142-000 28A0640-0A* 20.07 9.07 41.55 21.57 28B1142-100 28B0631-000 16.00 9.25 11.99 - 28B1225-100 28B0631-100 16.00 9.25 27.99 - 28B1225-300 31.12 28B0686-000 17.42 9.52 6.35 - 28B1225-000 31.12 19.05 15.93 - 28B0686-100 17.42 9.52 12.70 - 28B1250-000 31.75 19.05 22.22 - B C D 39.12 16.76 22.22 - 29.01 19.00 7.49 - 29.01 19.00 13.84 - 31.12 19.05 7.92 - 19.05 10.00 - 28B0686-200 17.42 9.53 28.58 - 28A5776-0A2 29.20 19.30 42.00 29.40 22.28 10.00 32.77 21.84 28A5131-0A2 56.64 19.50 45.00 56.63 28B0629-000 16.00 10.00 16.00 - 28A5776-0A2 29.20 20.00 42.00 29.40 28B0735-300 18.67 10.16 14.27 - 28B1417-200 36.00 23.00 12.70 - 50.80 25.40 28.70 - 60.96 35.56 12.70 - 28B0735-000 18.67 10.16 28.58 - 28B2000-100 28A3039-0A2 24.55 10.20 13.60 28.50 28B2400-000 28B0734-000 18.67 11.18 28.58 - 28B1000-000 25.40 12.70 12.70 - 28B1020-100 25.91 12.83 28.58 - 28B1531-000 38.86 12.95 28.58 26.16 28A2024-0A* 29.00 13.00 32.50 29.62 28A3851-0A2 30.00 13.00 33.70 30.00 28A2913-0A2 23.50 13.06 36.25 22.00 28B0825-000 20.95 13.21 6.35 - 28A4155-0A2 28.80 13.60 15.40 33.20 28B0870-000 22.10 13.72 6.35 - 28B0870-100 22.10 13.72 12.70 - 28B1122-300 28.50 13.77 20.00 - 28B1122-100 28.50 13.77 28.58 - 28B0886-20H 22.80 13.80 8.80 - 28B0999-000 25.40 15.49 12.70 - All chart data can be sorted on lairdtech.com. www.laird.com DIMENSIONS in mm A 28A2029-0A* Refer to pages 6, 7, 8 & 9 for more broadband data. 12 PART NUMBER Sorted by Diameter (B) FERRITE EMI CABLE CORES REFERENCE CHART SORTED BY IMPEDANCE @ 100 MHZ BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28B) & SPLIT / SNAP-ON (28A) CORES FOR ROUND CABLES & WIRES PART NUMBER Sorted by Impedance Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28B0141-000 30 79 192 28B0825-000 31 79 204 28B0375-400 33 81 28B0570-000 32 28B0395-000 28B0500-100 PART NUMBER Sorted by Impedance Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28B0250-700 64 135 255 28B2400-000 60 135 285 200 28B0268-000 65 138 260 82 200 28B0686-100 66 139 265 31 83 199 28B1225-000 68 140 270 33 83 200 28B0339-000 68 143 264 28B1142-000 34 85 200 28B0562-000 69 145 270 28B0870-000 34 85 205 28B0275-000 69 146 268 28B0394-000 34 86 201 28B0735-300 73 150 270 28B0886-20H 37 90 199 28B1000-000 73 151 278 28B0686-000 39 91 214 28B0375-100 74 154 282 28B1225-100 39 93 210 28B0315-100 76 158 281 28B0315-000 43 100 220 28B0384-000 82 159 286 28B1225-300 46 110 240 28B0296-000 75 160 270 28B1142-100 54 114 235 28A2432-0A2 62 160 300 28B1417-200 52 115 230 28B0625-000 79 163 273 28B0452-000 52 116 235 28A0392-0A* 75 170 320 28B0500-300 54 118 230 28B0563-000 85 173 295 28A4155-0A2 50 120 230 28A2913-0A2 86 177 305 28B0157-100 67 121 236 28B0250-100 90 182 300 28B0870-100 56 122 236 28A2307-0A2 92 183 315 28B0999-000 56 122 247 28B0562-100 89 184 303 28A1507-0A2 56 123 246 28B1250-000 92 186 292 28B0375-000 57 125 245 28A2005-0A2 88 190 330 28B0390-200 57 128 248 28B0375-300 100 194 310 28B0629-000 60 129 248 28B0473-000 101 195 320 28A3039-0A2 55 130 250 28B0631-000 60 130 250 Refer to pages 6, 7, 8 & 9 for more broadband data. Custom parts are also available www.laird.com 13 FERRITE EMI CABLE CORES REFERENCE CHART SORTED BY IMPEDANCE @ 100 MHZ BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28B) & SPLIT / SNAP-ON (28A) CORES FOR ROUND CABLES & WIRES PART NUMBER Sorted by Impedance Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28B0355-000 110 205 360 28B1531-000 109 210 347 28B1122-300 115 210 28A5776-0A2 115 28B0470-000 109 28B0563-100 @ 100 MHz @ 300 MHz 28A0434-0A2 111 277 449 28B0625-100 150 280 400 350 28A2024-0A* 130 280 440 210 360 28A2024-0A0 130 280 440 211 344 28A2024-0A2 130 280 440 109 217 333 28B0563-200 149 287 406 28A2736-0A2 120 220 360 28B0562-200 159 294 439 28A2809-0A2 120 220 360 28B0590-000 170 300 450 28B0734-000 116 229 370 28B2000-100 157 305 442 28A2738-0A2 106 233 366 28B1122-100 160 307 440 28A5776-0A2 115 240 360 28B0616-000 170 310 450 28A0350-0B2 100 240 400 28B0485-000 170 320 450 28A0640-0A* 105 240 390 28A2025-0A* 130 320 510 28B0686-200 124 242 390 28B0384-200 182 322 473 28B0631-100 124 243 370 28B0434-000 200 349 481 28B0474-000 138 245 370 28B0562-500 196 358 487 28B0672-000 130 245 360 28B0591-200 207 377 508 28B0735-000 135 250 400 28B0562-600 220 399 531 28A2029-0A* 95 250 420 28A0593-0A2 186 407 575 28B1540-000 130 254 405 28B0473-200 270 424 558 28A3851-0A2 150 260 410 28A5131-0A2 187 425 533 28B0453-000 148 262 378 28A5131-0A4 187 425 533 28B0562-300 150 270 420 28A0592-0A2 232 511 627 28A2026-0A2 95 270 460 28B0592-000 361 653 627 28B1020-100 147 276 412 Custom parts are also available www.laird.com Typical Impedance (Z) in Ohms (Ω) @ 25 MHz Refer to pages 6, 7, 8 & 9 for more broadband data. 14 PART NUMBER Sorted by Impedance FERRITE EMI CABLE CORES LOW FREQUENCY FERRITE EMI CORES FOR ROUND CABLES & WIRING HARNESSES 300 KHZ TO 30 MHZ OPTIMIZED PART NUMBERING SYSTEM EXAMPLE LF B 090050 -0 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) PART NUMBER Ω @ 500 KHz Ω @ 1 MHz Ω @ 5 MHz # of Wire Turns # of Wire Turns # of Wire Turns A B C 1 2 5 1 2 5 1 2 5 LFB090050-000 9.00 (0.354) 5.00 (0.197) 7.00 (0.275) 12 58 370 21 90 558 36 140 867 LFB095051-000 9.50 (0.374) 5.10 (0.201) 19.05 (0.750) 36 150 846 63 240 1464 86 340 2514 LFB127079-000 12.70 (0.500) 7.92 (0.312) 7.00 (0.276) 9 45 301 16 70 436 25 102 593 LFB143064-000 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 70 290 1757 122 490 2842 120 480 2646 LFB143064-100 14.27 (0.562) 6.35 (0.250) 13.46 (0.530) 33 145 626 57 220 1169 53 215 1552 LFB159079-000 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 61 250 1605 105 410 2615 100 390 2305 LFB174095-000 17.40 (0.685) 9.50 (0.374) 28.58 (1.125) 52 200 1290 91 350 2184 85 340 2044 LFB180100-000 18.10 (0.713) 10.00 (0.394) 10.00 (0.394) 18 75 493 31 138 809 29 115 722 LFB187102-000 18.67 (0.735) 10.16 (0.400) 28.58 (1.125) 53 200 1182 91 350 1969 84 330 1863 LFB220140-000 22.10 (0.870) 14.00 (0.551) 12.70 (0.500) 18 72 469 30 120 818 28 110 699 LFB250150-000 25.00 (0.984) 15.00 (0.591) 13.00 (0.512) 16 70 562 34 105 850 26 80 624 LFB259128-000 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 61 220 1446 106 420 2647 62 240 1487 LFB290190-000 28.98 (1.141) 19.05 (0.750) 15.21 (0.599) 19 90 533 34 155 963 22 70 513 LFB310190-000 31.00 (1.220) 19.00 (0.748) 13.00 (0.512) 19 80 523 33 143 845 22 88 554 LFB360230-300 36.00 (1.417) 23.00 (0.905) 15.00 (0.591) 24 96 614 27 110 653 19 75 438 All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. This catalog lists a limited sample of available parts. Custom parts are also available.. 1 Turn 2 Turns 5 Turns www.laird.com 15 FERRITE EMI CABLE CORES BROADBAND FERRITE EMI CORES FOR RIBBON & FLEX CABLES PART NUMBERING SYSTEM EXAMPLE 28 R 0315 -2 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code PART NUMBER Fig # on page 19 Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R0315-200 2 8.00 (0.315) 6.00 (0.236) 12.00 (0.472) 2.70 (0.106) 0.70 (0.028) 48 102 250 28R0394-000 2 10.00 (0.394) 7.00 (0.276) 25.00 (0.984) 5.00 (0.197) 2.00 (0.079) 92 169 294 28R0453-200 2 11.50 (0.453) 8.00 (0.315) 12.00 (0.472) 3.00 (0.118) 0.70 (0.028) 43 104 260 28R0453-300 2 11.50 (0.453) 8.00 (0.315) 20.00 (0.787) 3.00 (0.118) 0.70 (0.028) 72 160 330 28R0480-000 2 12.20 (0.480) 8.00 (0.315) 18.00 (0.709) 5.50 (0.217) 1.00 (0.039) 100 190 320 28R0480-100 2 12.20 (0.480) 8.00 (0.315) 12.00 (0.472) 5.50 (0.217) 1.00 (0.039) 68 150 290 28R0492-100 2 12.50 (0.492) 8.30 (0.327) 12.00 (0.472) 5.50 (0.217) 1.00 (0.039) 68 150 290 28R0610-000 3 15.50 (0.610) 13.50 (0.531) 10.00 (0.394) 3.40 (0.134) 1.40 (0.055) 29 80 216 28R0614-100 2 15.60 (0.614) 13.60 (0.535) 12.00 (0.472) 2.80 (0.110) 0.70 (0.028) 36 98 245 28R0614-300 2 15.60 (0.614) 13.60 (0.535) 18.00 (0.709) 2.80 (0.110) 0.70 (0.028) 45 125 280 28R0669-000 2 17.00 (0.669) 13.00 (0.512) 12.00 (0.472) 3.50 (0.138) 0.75 (0.030) 41 110 270 3 19.20 (0.756) 15.00 (0.591) 10.00 (0.394) 5.35 (0.211) 1.15 (0.045) 40 107 258 28R0756-000 Custom parts with double sided mounting tape are available. *Broadband (28) ribbon and flex cable cores are sorted by slot width on pages 22 & 23 and sorted by impedance on pages 24 & 25. 16 www.laird.com FERRITE EMI CABLE CORES BROADBAND FERRITE EMI CORES FOR RIBBON & FLEX CABLES PART NUMBERING SYSTEM EXAMPLE 28 R 0315 -2 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code PART NUMBER Fig # on page 19 Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R0756-200 3 19.20 (0.756) 15.00 (0.591) 16.00 (0.630) 5.35 (0.211) 1.15 (0.045) 57 140 308 28R0852-500 3 21.65 (0.852) 17.50 (0.689) 5.50 (0.317) 5.15 (0.203) 1.00 (0.039) 28 83 210 28R0880-000 2 22.35 (0.880) 14.00 (0.551) 19.05 (0.750) 7.75 (0.305) 1.50 (0.059) 93 187 356 28R0900-100 2 22.80 (0.898) 18.70 (0.736) 12.00 (0.472) 3.60 (0.142) 0.70 (0.028) 38 116 266 3 24.00 (0.945) 19.00 (0.748) 10.00 (0.394) 6.25 (0.246) 1.25 (0.049) 43 112 269 28R0983-000 3 25.00 (0.984) 21.00 (0.827) 15.00 (0.590) 3.00 (0.118) 0.80 (0.031) 43 123 276 28R0984-000 3 25.00 (0.984) 18.00 (0.709) 24.00 (0.945) 7.70 (0.303) 0.90 (0.035) 100 220 430 28R0984-200 3 25.00 (0.984) 18.00 (0.709) 16.00 (0.630) 7.70 (0.303) 0.90 (0.035) 70 170 370 28R1022-000 3 26.00 (1.022) 22.00 (0.866) 9.00 (0.354) 5.00 (0.197) 1.20 (0.047) 32 91 227 28R1024-000 2 26.00 (1.024) 20.50 (0.807) 10.00 (0.394) 6.00 (0.236) 0.80 (0.031) 48 128 299 3 26.00 (1.024) 21.40 (0.8425) 10.00 (0.394) 5.00 (0.197) 0.75 (0.030) 34 97 242 28R1101-000 1 27.97 (1.101) 22.94 (0.903) 14.66 (0.577) 7.75 (0.305) 1.50 (0.059) 55 140 300 28R1102-000 2 28.00 (1.102) 23.00 (0.906) 15.00 (0.591) 5.80 (0.228) 0.80 (0.031) 61 154 340 28R1102-100 2 28.00 (1.102) 23.00 (0.906) 20.00 (0.787) 5.80 (0.228) 0.80 (0.031) 75 192 380 28R1103-000 2 28.00 (1.102) 23.00 (0.906) 27.00 (1.063) 6.10 (0.240) 1.10 (0.043) 95 230 480 28R1127-000 3 28.58 (1.125) 23.50 (0.925) 31.00 (1.220) 7.70 (0.303) 1.70 (0.067) 100 220 430 28R0945-000 28R1025-000 www.laird.com 17 FERRITE EMI CABLE CORES BROADBAND FERRITE EMI CORES FOR RIBBON & FLEX CABLES PART NUMBERING SYSTEM EXAMPLE 28 R 0315 -2 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code PART NUMBER 18 www.laird.com Fig # on page 19 Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R1127-200 3 28.58 (1.125) 23.50 (0.925) 24.89 (0.980) 7.70 (0.303) 1.70 (0.067) 85 191 410 28R1127-400 3 28.58 (1.125) 23.50 (0.925) 17.00 (0.669) 7.70 (0.303) 1.70 (0.067) 60 150 330 28R1127-500 3 28.58 (1.125) 23.50 (0.925) 9.70 (0.382) 7.70 (0.303) 1.70 (0.067) 40 110 265 28R1128-100 3 28.58 (1.125) 24.00 (0.945) 26.00 (1.024) 5.38 (0.212) 0.80 (0.031) 79 204 399 28R1128-200 3 28.58 (1.125) 24.00 (0.945) 14.00 (0.551) 5.38 (0.212) 0.80 (0.031) 52 145 312 28R1227-100 2 31.12 (1.225) 24.77 (0.975) 13.30 (0.525) 8.26 (0.325) 1.91 (0.075) 52 128 300 28R1236-000 2 31.40 (1.236) 23.00 (0.906) 19.00 (0.748) 7.75 (0.305) 1.50 (0.059) 78 162 370 28R1261-100 3 32.00 (1.260) 25.10 (0.988) 35.00 (1.378) 7.75 (0.305) 0.90 (0.035) 140 350 700 28R1262-000 2 32.00 (1.260) 26.00 (1.024) 30.00 (1.181) 7.00 (0.276) 1.00 (0.039) 110 260 520 28R1262-200 2 32.00 (1.260) 26.00 (1.024) 13.00 (0.512) 7.00 (0.276) 1.00 (0.039) 53 141 344 28R1300-000 3 33.02 (1.300) 28.50 (1.122) 3.00 (0.118) 5.00 (0.197) 0.59 (0.023) 21 72 200 28R1319-000 3 33.50 (1.312) 27.00 (1.063) 12.00 (0.472) 6.50 (0.256) 1.50 (0.059) 43 117 269 28R1340-100 3 34.00 (1.340) 28.00 (1.100) 12.00 (0.472) 7.00 (0.280) 1.00 (0.039) 50 139 315 28R1340-200 3 34.00 (1.340) 28.00 (1.100) 25.00 (0.984) 7.00 (0.280) 1.00 (0.039) 86 220 449 28R1417-000 2 36.00 (1.417) 26.00 (1.024) 40.00 (1.575) 11.00 (0.433) 1.00 (0.039) 187 393 734 28R1418-000 3 36.00 (1.417) 33.00 (1.299) 10.00 (0.394) 4.00 (0.157) 1.00 (0.039) 34 104 245 28R1450-100 3 36.83 (1.450) 29.58 (1.165) 10.00 (0.394) 7.75 (0.305) 0.75 (0.030) 48 130 290 FERRITE EMI CABLE CORES BROADBAND FERRITE EMI CORES FOR RIBBON & FLEX CABLE PART NUMBERING SYSTEM EXAMPLE 28 R 0315 -2 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating Code PART NUMBER A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R1457-400 3 37.01 (1.457) 33.00 (1.299) 13.46 (0.530) 4.50 (0.177) 0.51 (0.020) 44 140 310 28R1476-100 3 37.50 (1.476) 34.50 (1.358) 13.00 (0.512) 4.00 (0.157) 1.00 (0.039) 38 110 251 28R1496-000 2 38.00 (1.496) 30.00 (1.181) 25.00 (0.984) 9.25 (0.364) 1.25 (0.049) 91 239 479 28R1517-000 2 38.10 (1.500) 26.67 (1.050) 25.40 (1.000) 12.07 (0.475) 1.91 (0.075) 110 230 520 28R1518-000 1 38.50 (1.516) 26.80 (1.055) 25.40 (1.000) 12.09 (0.476) 1.91 (0.075) 105 235 478 28R1775-000 2 45.08 (1.775) 34.42 (1.355) 28.58 (1.125) 12.45 (0.490) 1.52 (0.060) 115 260 530 28R1779-000 2 63.50 (2.500) 52.07 (2.050) 28.58 (1.125) 12.70 (0.500) 1.68 (0.066) 114 298 588 28R1779-100 2 63.50 (2.500) 52.07 (2.050) 12.98 (0.511) 12.70 (0.500) 1.68 (0.066) 65 170 375 28R1862-000 2 47.70 (1.878) 39.00 (1.535) 31.00 (1.220) 15.00 (0.590) 3.00 (0.118) 116 261 561 28R1953-000 3 49.61 (1.953) 44.00 (1.732) 12.00 (0.472) 7.62 (0.300) 1.45 (0.057) 45 127 300 28R2000-200 2 50.80 (2.000) 40.60 (1.600) 28.00 (1.102) 12.20 (0.480) 2.00 (0.079) 103 252 545 28R2170-000 2 55.12 (2.170) 43.69 (1.720) 25.40 (1.000) 12.70 (0.500) 1.27 (0.050) 110 280 550 28R2170-100 2 55.12 (2.170) 43.69 (1.720) 12.70 (0.500) 12.70 (0.500) 1.27 (0.050) 62 170 370 28R3149-000 2 79.98 (3.149) 68.58 (2.700) 12.70 (0.500) 11.99 (0.472) 1.91 (0.075) 51 135 318 FIGURE 1 FIGURE 2 C A B D Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) Fig # on page 19 *Broadband (28) ribbon and flex cable cores are sorted by slot width on pages 22 & 23 and sorted by impedance on pages 24 & 25. Ferrite core shape and size affect frequency response and impedance. Please visit lairdtech. com for the most up to date information. All dimensions & impedance values can be sorted and compared on lairdtech. com. Custom parts are available. FIGURE 3 A A C E E D D E B C B www.laird.com 19 FERRITE EMI CABLE CORES BROADBAND SPLIT FERRITE CORES FOR RIBBON & FLEX CABLES Laird Techologies offers a selection of broadband “split” ribbon and flex cores for retrofit and post-assembly operations. Similar in performance to one-piece core designs, these split ferrite cores provide excellent differential and common mode EMI suppression on flat cable assemblies. Lightweight, inexpensive metal or plastic end clips and cases provide secure closure of the ferrite onto the flat cable. PART NUMBERING SYSTEM EXAMPLE *0 = No End Clip 28 S 0670 -0 0* 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Case or Clip Code Additional Part Description Fig # on page 21 *Available End Clip Types 28S0670-000 2 28S2001-0*0 PART NUMBER *M = Metal Clip *P = Plastic Clip *A = Hinged Case Typical Impedance (Z) in Ohms (Ω) DIMENSIONS mm (inches) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz NA 17.02 (0.670) 12.50 (0.492) 14.99 (0.590) 3.40 (0.134) 0.51 (0.020) 60 150 310 1 M, P 63.50 (2.500) 52.07 (2.050) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 280 590 28S2001-2A2 3 Hinged Case 67.08 (2.641) 53.75 (2.116) 27.53 (1.084) 16.66 (0.656) 1.91 (0.075) 80 230 480 28S2011-0*0 1 M, P 76.20 (3.000) 65.28 (2.570) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 280 600 28S2012-0M0 1 M 88.90 (3.500) 78.23 (3.080) 28.58 (1.125) 6.48 (0.255) 0.84 (0.033) 80 240 630 28S2022-0*0 1 M, P 45.09 (1.775) 34.42 (1.355) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 250 550 28S2023-0M0 1 M 38.10 (1.500) 26.67 (1.050) 25.40 (1.000) 6.35 (0.250) 0.84 (0.033) 115 250 520 ** The “D” & “E” dimensions for 28S, split, two piece cores must be doubled for total assembled dimensions. “D” & “E” dimensions shown for hinged case parts are for a complete assembly. PLASTIC CLIP DIAGRAM METAL CLIP DIAGRAM (side view) 20 www.laird.com Custom parts with double sided mounting tape and hinged case are available. *Broadband (28) ribbon and flex cable cores are sorted by slot width on pages 22 & 23 and sorted by impedance on pages 24 & 25. FERRITE EMI CABLE CORES SPLIT FERRITE CORES FOR RIBBON & FLEX CABLES PART #28S2001-2A2 SPLIT FERRITE CORE ASSEMBLY WITH HINGED BLACK PLASTIC CASE ** To determine total inside slot gap (I.D.) of an assembled split ferrite ribbon core, multiply the “E” dimension by 2. Both the “D” and “E” dimensions must be doubled for assembled core dimensions. FIGURE 1 B E D A FIGURE 2 C FIGURE 3 A E D B C SPLIT FERRITE CORES FOR FLAT / RIBBON CABLES ARE SOLD AS SINGLE SIDES. IT IS NECESSARY TO ORDER TWO SIDES TO FORM ONE SET. [EXCEPT 28S2001-2A2 (FIGURE 3) WHICH IS SOLD ASSEMBLED] SPLIT CORE WITH WHITE PLASTIC CLIPS Plastic Clip Assemblies: To specify one core side and one white plastic clip together, replace the second ferrite core part number character after the dash with the letter “P” (example: 28S2022-0P0). One complete assembly of two ferrite core sides (28 material) with two plastic clips would be specified as follows: 2 of part # 28S2022-0P0. Attachment ears are standard. Metal Clip Assemblies: To specify one core side and one metal clip together, replace the second ferrite core part number character after the dash with the letter “M” (example: 28S2022-0M0). One complete assembly of two ferrite cores (28 material) with two metal clips would be specified as follows: 2 of part # 28S2022-0M0. SPLIT CORE WITH METAL CLIPS Clips for Bulk Shipment: To order white plastic end clips (with attachment ears) separately in bulk, specify part number ASSE001-2. To order metal end clips separately in bulk, specify part number ASSE017-2. No standard clips are available for 28S2827-210. www.laird.com 21 FERRITE EMI CABLE CORES QUICK REFERENCE CHART SORTED BY SLOT WIDTH (B) BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28R) & SPLIT (28S) CORES FOR RIBBON & FLEX CABLES PART NUMBER Sorted by Slot Width DIMENSIONS in mm A B C D** A B C D** E** 28R0315-200 8.00 6.00 12.00 2.70 0.70 28R1024-000 26.00 20.50 10.00 6.00 0.80 10.00 7.00 25.00 5.00 2.00 28R0983-000 25.00 21.00 15.00 3.00 0.80 28R0453-200 11.50 8.00 12.00 3.00 0.70 28R1025-000 26.00 21.40 10.00 5.00 0.75 28R0480-000 12.20 8.00 18.00 5.50 1.00 28R1101-000 27.97 22.94 14.66 7.75 1.50 28R0480-100 12.20 8.00 12.00 5.50 1.00 28R1102-000 28.00 23.00 15.00 5.80 0.80 28R1236-000 31.40 23.00 19.00 7.75 1.50 28R0453-300 11.50 8.00 20.00 3.00 0.70 28R0492-100 12.50 8.30 12.00 5.50 1.00 28R1102-100 28.00 23.00 20.00 5.80 0.80 28S0670-000** 17.02 12.50 14.99 3.40 0.51 28R1103-000 28.00 23.00 27.00 6.10 1.10 28R0669-000 17.00 13.00 12.00 3.50 0.75 28R1127-500 28.58 23.50 9.70 7.70 1.70 28R0610-000 15.50 13.50 10.00 3.40 1.40 28R1127-400 28.58 23.50 17.00 7.70 1.70 28R0614-100 15.60 13.60 12.00 2.80 0.70 28R1127-200 28.58 23.50 24.89 7.70 1.70 28R0614-300 15.60 13.60 18.00 2.80 0.70 28R1127-000 28.58 23.50 31.00 7.70 1.70 28R0825-000 20.95 14.00 19.05 7.75 0.80 28R1128-100 28.58 24.00 26.00 5.38 0.80 28R0880-000 22.35 14.00 19.05 7.75 1.50 28R1128-200 28.58 24.00 14.00 5.38 0.80 28R0756-000 19.20 15.00 10.00 5.35 1.15 28R1227-100 31.12 24.77 13.30 8.26 1.91 28R0756-200 19.20 15.00 16.00 5.35 1.15 28R1261-200 32.00 25.10 9.70 7.75 0.90 28R0984-200 25.00 18.00 16.00 7.70 0.90 28R1261-100 32.00 25.10 35.00 7.75 0.90 28R0984-000 25.00 18.00 24.00 7.70 0.90 28R1262-000 32.00 26.00 30.00 7.00 1.00 28R0900-100 22.80 18.70 12.00 3.60 0.70 28R1417-000 36.00 26.00 40.00 11.00 1.00 28R0945-000 24.00 19.00 10.00 6.25 1.25 28R1517-000 38.10 26.67 25.40 12.07 1.91 Custom parts are also available. Refer to pages 16 - 20 for more data. www.laird.com DIMENSIONS in mm 28R0394-000 ** The “D” & “E” dimensions for 28S split, two-piece cores must be doubled for total assembled dimensions. 22 E** PART NUMBER Sorted by Slot Width 28S2023-0M0** 38.10 26.67 25.40 6.35 0.84 28R1518-000 38.50 26.80 25.40 12.09 1.91 28R1319-000 33.50 27.00 12.00 6.50 1.50 28R1340-100 34.00 28.00 12.00 7.00 1.00 28R1340-200 34.00 28.00 25.00 7.00 1.00 28R1300-000 33.02 28.50 3.00 5.00 0.59 28R1450-100 36.83 29.58 10.00 7.75 0.75 FERRITE EMI CABLE CORES QUICK REFERENCE CHART SORTED BY SLOT WIDTH (B) BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28R) & SPLIT (28S) CORES FOR RIBBON & FLEX CABLES PART NUMBER Sorted by Slot Width DIMENSIONS in mm A B C D** E** 28R1496-000 38.00 30.00 25.00 9.25 1.25 28R1418-000 36.00 33.00 10.00 4.00 1.00 28R1457-400 37.01 33.00 13.46 4.50 0.51 28R1775-000 45.08 34.42 28.58 12.45 1.52 28S2022-0*0** 45.09 34.42 28.58 6.35 0.84 28R1476-100 37.50 34.50 13.00 4.00 1.00 28R1862-000 47.70 39.00 31.00 15.00 3.00 28R2000-200 50.80 40.60 28.00 12.20 2.00 28R2170-100 55.12 43.69 12.70 12.70 1.27 28R2170-000 55.12 43.69 25.40 12.70 1.27 28R1953-000 49.61 44.00 12.00 7.62 1.45 28R1779-100 63.50 52.07 12.98 12.70 1.68 28R1779-000 63.50 52.07 28.58 12.70 1.68 28S2001-0*0** 63.50 52.07 28.58 6.35 0.84 28S2001-2A2** 63.50 52.07 24.38 6.35 0.84 28S2011-0*0** 76.20 65.28 28.58 6.35 0.84 28R3149-000 79.98 68.58 12.70 11.99 1.91 28S2012-0M0** 88.90 78.23 28.58 6.48 0.84 ** The “D” & “E” dimensions for 28S split, two-piece cores must be doubled for total assembled dimensions. Custom parts are also available Refer to pages 16 - 20 for more data. www.laird.com 23 FERRITE EMI CABLE CORES QUICK REFERENCE CHART SORTED BY IMPEDANCE @ 100 MHZ BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28R) & SPLIT (28S) CORES FOR RIBBON & FLEX CABLES PART NUMBER Sorted by Impedance Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28R1300-000 21 72 200 28R0610-000 29 80 28R0386-000 36 96 28R1025-000 34 28R0614-100 www.laird.com Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28R1101-000 55 140 300 216 28R0756-200 57 140 308 224 28R1457-400 44 140 310 97 242 28R1128-200 52 145 312 36 98 245 28R0480-100 68 150 290 28R0315-200 48 102 250 28R0492-100 68 150 290 28R1418-000 34 104 245 28S0670-000 60 150 310 28R0453-200 43 104 260 28R1127-400 60 150 330 28R0756-000 40 107 258 28R1102-000 61 154 340 28R1127-500 40 110 265 28R0453-300 72 160 330 28R1476-100 38 110 251 28R1236-000 78 162 370 28R0669-000 41 110 270 28R0394-000 92 169 294 28R0945-000 43 112 269 28R2170-100 62 170 370 28R1319-000 43 117 269 28R0984-200 70 170 370 28R0983-000 43 123 276 28R1779-100 65 170 375 28R0614-300 45 125 280 28R0880-000 93 187 356 28R1953-000 45 127 300 28R0480-000 100 190 320 28R1024-000 48 128 299 28R0825-000 96 190 363 28R1227-100 52 128 300 28R1127-200 85 191 410 28R1450-100 48 130 290 28R1102-100 75 192 380 28R1261-200 50 135 310 28R1128-100 79 204 399 28R3149-000 51 135 318 28R0900-100 38 116 266 28R1340-100 50 139 315 All chart data can be sorted on lairdtech.com Refer to pages 16 - 20 for more data. 24 PART NUMBER Sorted by Impedance FERRITE EMI CABLE CORES QUICK REFERENCE CHART SORTED BY IMPEDANCE @ 100 MHZ BROADBAND 28 MATERIAL PARTS ONLY ONE-PIECE (28R) & SPLIT (28S) CORES FOR RIBBON & FLEX CABLES PART NUMBER Sorted by Impedance Typical Impedance (Z) in Ohms (Ω) @ 25 MHz @ 100 MHz @ 300 MHz 28R0984-000 100 220 430 28R1127-000 100 220 430 28R1340-200 86 220 449 28S2001-2A2 80 230 480 28R1103-000 95 230 480 28R1517-000 110 230 520 28R1518-000 105 235 478 28R1496-000 91 239 479 28S2012-0M0 80 240 630 28S2023-0M0 115 250 520 28S2022-0*0 100 250 550 28R2000-200 103 252 545 28R1262-000 110 260 520 28R1775-000 115 260 530 28R1862-000 116 261 561 28R2170-000 110 280 550 28S2001-0*0 100 280 590 28S2011-0*0 100 280 600 28R1779-000 114 298 588 28R1261-100 140 350 700 28R1417-000 187 393 734 All chart data can be sorted on lairdtech.com Refer to pages 16 - 20 for more data. www.laird.com 25 FERRITE EMI CABLE CORES FERRITE EMI DISKS AND PLATES Ferrite disks and plates provide a simple, cost-effective solution for radiated and inductively-coupled electromagnetic interference. After the PC board soldering process, a ferrite disk or plate can be installed directly on the source of EMI (such as active devices or unwanted antennas). FEATURES: M 0787 100 M - Disk P - Plate Part Size Indentification Thickness Code MM0650-100 MM0787-100 MM0787-200 MM1400-200 • Ferrite disks and plates can be utilized either as inductively coupled components or EMI shields on PC board components and traces. Inductive coupling occurs when the ferrite affects the conducted wave form leaving the active component. The rise time of the wave form is effectively slowed by the ferrite, and the overshoot and associated ringing are attenuated. EMI shielding occurs when the ferrite absorbs the radiated emissions from active components, effectively protecting other boards or components in the vicinity from radiated contamination • Can be used to locate unwanted EMI antennas • Flat flex & ribbon cables • Can also provide retrofit, auxiliary EMI attenuation MP0315-200 EXAMPLE APPLICATION MP1040-300 MP1040-100 MP0350-000 MP0433-000 MP0512-200 MP0590-200 MP0591-200 MP0760-100 MP1040-100 MP1040-200 MP1496-000 B mm (inches) – – – – – 8.00 (0.315) 8.89 (0.350) 11.00 (0.433) 13.00 (0.512) 15.00 (0.591) 15.00 (0.591) 19.30 (0.760) 26.42 (1.040) 26.42 (1.040) 26.42 (1.040) 38.00 (1.496) C mm (inches) 1.27 (0.050) 1.27 (0.050) 1.91 (0.075) 1.91 (0.075) 2.54 (0.100) 2.00 (0.079) 1.27 (0.050) 1.96 (0.077) 2.00 (0.079) 2.00 (0.079) 2.00 0.079) 1.27 (0.050) 1.27 (0.050) 1.91 (0.075) 2.25 (0.089) 2.00 (0.079) 0 -1 HP -2 -3 MP -4 -5 10 Frequency MHz 100 EXAMPLE APPLICATION GRAPH EXPLANATION: The zero line on the graph represents the base line noise recorded for an unprotected microprocessor. The curve (dB down) represent the performance of the Laird’s ferrite plate relative to the baseline. The addition of the ferrite plates to the top of the processor in this specific application exhibits up to a 5 dB EMI reduction relative to the unprotected part. Performance can vary with different sizes, materials, processors and applications. 1000 Disk Plate ADHESIVE -6 1 ADHESIVE dB down (relative to baseline noise) 1 A mm (inches) 16.51 (0.650) 20.00 (0.787) 20.00 (0.787) 35.56 (1.400) 35.56 (1.400) 8.00 (0.315) 26.42 (1.040) 11.00 (0.433) 13.00 (0.512) 21.00 (0.827) 15.00 (0.591) 19.30 (0.760) 26.42 (1.040) 26.42 (1.040) 26.42 (1.040) 38.00 (1.496) MM1400-300 APPLICATIONS: www.laird.com M M - Material PART NUMBER • Easy installation • Each part for volume production is provided with permanent, double sided 3,5 mil acrylic adhesive with 218 oz. / inch2 adhesion • Samples and sample kits are available with removable and reusable adhesive for “trial and error” testing • Variety of sizes offered • Custom parts also available. 26 PART NUMBER SYSTEM EXAMPLE FERRITE PLATES FOR WIRELESS CHARGING MP & 33 SERIES Pb FEATURES APPLICATIONS • Ferrite materials are Wireless Power Consortium (WPC) listed, recommended & certified for interoperability test • Optimized for highest charging efficiency • Precise dimension control and automotive grade available • -40ºC to 125ºC operating temperature • Available in wide range of size selection, custom shapes are also available • Wireless charger for general consumer electronics,transmitter (TX) or receiver (RX) • Aftermarket charging pads • Wireless charger for Office, Residential and Public Area applications • Wireless charger embedded solution for automobile central console, arm-rest, etc. • Power tools or any industrial devices that need power transmission without metallic contact DIMENSIONS PART NUMBER A mm (inches) B mm (inches) C mm (inches) Fig. # MP1040-3M0 26.42 (1.040) 26.42 (1.040) 2.25 (0.089) 1 MP1496-0M0 38.00 (1.496) 38.00 (1.496) 2.00 (0.079) 1 MP2106-0M0 53.00 (2.087) 53.00 (2.087) 2.50 (0.099) 1 MP2126-0M0 53.80 (2.118) 53.80 (2.118) 1.10 (0.043) 1 MP2170-1M0 47.20 (1.858) 55.20 (2.173) 2.50 (0.099) 1 MP3940-0M0 100.00 (3.937) 56.00 (2.205) 1.10 (0.043) 1 33P2098-0M0 53.30 (2.099) 53.30 (2.099) 2.50 (0.099) 1 33P3839-0M0 97.50 (3.839) 50.00 (1.969) 1.10 (0.043) 2 PART NUMBER SYSTEM EXAMPLE 33 P 2098 0M0 M-28 Material 33-33 Material Plate Part Size Code Thickness Code Catalog or Custom Information www.laird.com 27 FERRITE PLATES FOR WIRELESS CHARGING MP & 33 SERIES MATERIAL SPECIFICATIONS 28 Material (WPC Listed) 33 Material 650 2300 mT [Gauss] 280 [2800] 390 [3900] H A/m [Oe] 800 [10] 800 [10] Residual Field Strength Br mT [Gauss] 130 [1300] 55 [550] Coercive Strength Hc A/m [Oe] 32 [0.4] 9 [0.1] Loss Factor @ Frequency tan d/µi f 10-6 500 6 MHz 0.1 0.1 Curie Temperature Tc ºC > 140 > 200 Resistivity r Ω-cm 105 5 x 102 PROPERTY SYMBOL Initial Permeability µi Flux Density B @ Field Strength UNIT TYPICAL ELECTRICAL CHARACTERISTICS 28 MATERIAL 33 MATERIAL 28 www.laird.com FLEXIBLE FERRITE SHEETS FOR NFC & WIRELESS CHARGING MHLL SERIES Pb FEATURES APPLICATIONS • Flexible ferrite sheets for 13.56 MHz NFC, RFID application & wireless charging application • Made by thin, high permeability sintered ferrite with PET film and adhesive tape • Standard ferrite layer thickness 0.05mm,0.1mm and 0.2mm • Custom size or thickness available upon request • Operating temperature -40ºC to 85ºC • RoHS compliant • NFC antenna for mobile phones • NFC antenna for automobile • NFC or RFID antenna for security & access control system • Wireless charging for mobile phones and battery powered handheld electronic devices • NFC or RFID read/write devices, improved read distance • EMI suppression for IC or IC circuitry SHAPES AND DIMENSIONS PART NUMBER A mm (inches) B mm (inches) C mm (inches) D mm (inches) MHLL5040-000 50 (1.969) 40 (1.575) 0.20 (0.008) 0.35 (0.014) MHLL5040-200 50 (1.969) 40 (1.575) 0.10 (0.004) 0.20 (0.008) MHLL6060-300 60 (2.362) 60 (2.362) 0.05 (0.002) 0.09 (0.004) MHLL12060-000 120 (4.724) 60 (2.362) 0.20 (0.008) 0.35 (0.014) MHLL12060-200 120 (4.724) 60 (2.362) 0.10 (0.004) 0.20 (0.008) PART NUMBER SYSTEM EXAMPLE MHLL 12060 000 Material Code Part Size Code Thickness Code Catalog or Custom Information TYPICAL ELECTRICAL CHARACTERISTICS MATERIAL SPECIFICATIONS PROPERTY MHLL Series Real Permeability µ’ @ 13.56MHz, O.1V 130 ± 20% Imaginary Permeability µ” @ 13.56MHz, O.1V 5 max Operating Temperature ºC -40ºC ~ +85ºC www.laird.com 29 FLEXIBLE FERRITE SHEETS FOR NFC & WIRELESS CHARGING MSLL SERIES Pb FEATURES APPLICATIONS • Flexible ferrite sheets for 13.56 MHz NFC, RFID application & wireless charging application • Made by thin, high permeability sintered ferrite with PET film and adhesive tape • Standard ferrite layer thickness 0.05mm,0.1mm and 0.2mm • Custom size or thickness available upon request • Operating temperature -40ºC to 85ºC • RoHS compliant • NFC antenna for mobile phones • NFC antenna for automobile • NFC or RFID antenna for security & access control system • Wireless charging for mobile phones and battery powered handheld electronic devices • NFC or RFID read/write devices, improved read distance • EMI suppression for IC or IC circuitry SHAPES AND DIMENSIONS PART NUMBER A mm (inches) B mm (inches) C mm (inches) D mm (inches) MSLL5040-000 50 (1.969) 40 (1.575) 0.20 (0.008) 0.35 (0.014) MSLL5040-200 50 (1.969) 40 (1.575) 0.10 (0.004) 0.20 (0.008) MSLL6060-300 60 (2.362) 60 (2.362) 0.05 (0.002) 0.09 (0.004) MSLL12060-000 120 (4.724) 60 (2.362) 0.20 (0.008) 0.35 (0.014) MSLL12060-200 120 (4.724) 60 (2.362) 0.10 (0.004) 0.20 (0.008) PART NUMBER SYSTEM EXAMPLE MSLL 12060 000 Material Code Part Size Code Thickness Code Catalog or Custom Information TYPICAL ELECTRICAL CHARACTERISTICS MATERIAL SPECIFICATIONS PROPERTY 30 www.laird.com MSLL Series Real Permeability µ’ @ 13.56MHz, O.1V 100 ± 20% Imaginary Permeability µ” @ 13.56MHz, O.1V 5 max Operating Temperature ºC -40ºC ~ +85ºC FLEXIBLE FERRITE SHEETS FOR NFC & WIRELESS CHARGING MULL SERIES Pb FEATURES APPLICATIONS • Flexible ferrite sheets for 13.56 MHz NFC, RFID application & wireless charging application • Made by thin, high permeability sintered ferrite with PET film and adhesive tape • Standard ferrite layer thickness 0.05mm,0.1mm and 0.2mm • Custom size or thickness available upon request • Operating temperature -40ºC to 85ºC • RoHS compliant • NFC antenna for mobile phones • NFC antenna for automobile • NFC or RFID antenna for security & access control system • Wireless charging for mobile phones and battery powered handheld electronic devices • NFC or RFID read/write devices, improved read distance • EMI suppression for IC or IC circuitry SHAPES AND DIMENSIONS PART NUMBER A mm (inches) B mm (inches) C mm (inches) D mm (inches) MULL5040-000 50 (1.969) 40 (1.575) 0.20 (0.008) 0.35 (0.014) MULL5040-200 50 (1.969) 40 (1.575) 0.10 (0.004) 0.20 (0.008) MULL6060-300 60 (2.362) 60 (2.362) 0.05 (0.002) 0.09 (0.004) MULL12060-000 120 (4.724) 60 (2.362) 0.20 (0.008) 0.35 (0.014) MULL12060-200 120 (4.724) 60 (2.362) 0.10 (0.004) 0.20 (0.008) PART NUMBER SYSTEM EXAMPLE MULL 12060 000 Material Code Part Size Code Thickness Code Catalog or Custom Information TYPICAL ELECTRICAL CHARACTERISTICS MATERIAL SPECIFICATIONS PROPERTY MULL Series Real Permeability µ’ @ 13.56MHz, O.1V 150 ± 20% Imaginary Permeability µ” @ 13.56MHz, O.1V 5 max Operating Temperature ºC -40ºC ~ +85ºC www.laird.com 31 FERRITE EMI CABLE CORES SAMPLE KIT LISTS BROADBAND EMI FERRITE CYLINDRICAL EMI CORES, SPLIT/SNAP-ON CORES PARTS AND SUPPLIES FOR SAMPLE KIT# K-401 EMI B PART NUMBER QTY PER KIT PART NUMBER QTY PER KIT 28A0640-0A0 1 28B0590-000 28A2024-0A0 1 28B0591-200 28A2025-0A0 1 28A2029-0A0 28B1122-100 PARTS AND SUPPLIES FOR SAMPLE KIT# K-402 EMI B SML PART NUMBER QTY PER KIT PART NUMBER QTY PER KIT 4 28A0350-0B2 2 28B0375-100 4 4 28A0392-0A2 2 28B0375-300 4 28B0625-000 4 28A0434-0A2 1 28B0375-400 8 1 28B0625-100 4 28B0250-100 6 28B0384-000 4 1 28B0631-100 4 28B0268-000 6 28B0384-200 4 28B1250-000 1 28B0672-000 4 28B0275-000 6 28B0390-200 4 28B1531-000 1 28B0686-100 4 28B0296-000 6 28B0434-000 2 28A0593-0A2 2 28B0686-200 4 28B0315-000 6 28B0472-090 4 28B0616-000 2 28B0734-000 4 28B0315-100 6 28B0473-000 8 28B0870-100 2 28B0735-000 4 28B0339-000 8 28B0473-200 4 28B0999-000 2 28B0735-300 4 28B0355-000 4 28B0485-000 4 28B1020-100 2 28B0773-050 4 28B0375-000 4 28B0562-000 4 28B1142-100 2 28B0825-000 4 28B1417-200 2 28B0870-000 4 28B1225-100 3 28B1000-000 4 28B0500-300 4 28B0570-000 8 28B0562-100 4 28B0686-000 8 28B0562-200 4 28B0500-100 12 28B0563-100 4 FERRITE EMI CABLE CORES SAMPLE KIT LISTS BROADBAND EMI FERRITE SPLIT/SNAP-ON CORES PARTS AND SUPPLIES FOR SAMPLE KIT# K-403 EMI A DEMO PARTS AND SUPPLIES FOR SAMPLE KIT# K-404 EMI A PART NUMBER QTY PER KIT PART NUMBER QTY PER KIT 28A0350-0B2 1 28A0350-0B2 12 28A0392-0A2 1 28A0392-0A2 12 28A0434-0A2 1 28A0434-0A2 6 28A0592-0A2 1 28A0592-0A2 6 28A0593-0A2 1 28A0593-0A2 6 28A0640-0A2 1 28A0807-0A2 4 28A2024-0A2 1 28A2024-0A2 2 28A2025-0A2 1 28A2025-0A2 4 28A2026-0A2 1 28A2026-0A2 3 28A2029-0A2 1 28A2029-0A2 4 28A2432-0A2 1 28A2432-0A2 4 28A2736-0A2 1 28A2736-0A2 4 28A3851-0A2 1 28A3039-0A2 3 28A5776-0A2 1 28A3851-0A2 2 28A4155-0A2 3 28A5776-0A2 1 32 www.laird.com FERRITE EMI CABLE CORES SAMPLE KIT LISTS ONE-PIECE(28R) & SPLIT (28S) CORES FOR RIBBON & FLEX CABLES HIGH FREQUENCY FERRITE CYLINDRICAL, SPLIT, SNAP-ON CORES PARTS AND SUPLIES FOR SAMPLE KIT# K-406 EMI R PARTS AND SUPPLIES FOR SAMPLE KIT# K-409 EMI HFB PART NUMBER QTY PER KIT PART NUMBER QTY PER KIT 28R0315-200 22 HFA100049-0A2 6 28R0453-200 18 HFA150066-0A2 4 28R0453-300 9 HFA150068-0A2 4 28R0480-000 6 HFA163090-0A2 4 28R0592-010 5 HFA187102-0A2 4 28R0610-000 20 HFA259131-0A2 3 28R0614-100 24 HFB075024-000 12 28R0669-000 18 HFB095051-100 9 28R0756-000 12 HFB095051-200 12 28R0756-200 12 HFB123049-000 10 28R0880-000 4 HFB123049-100 12 28R0898-100 20 HFB123049-300 6 28R0898-200 20 HFB143064-000 8 28R0945-000 10 HFB143064-100 8 28R0984-000 4 HFB143064-300 6 28R0984-200 8 HFB150070-200 6 28R1024-000 10 HFB152034-000 12 28R1102-000 10 HFB157070-000 4 28R1102-100 5 HFB159079-100 6 28R1127-200 4 HFB160093-200 4 28R1127-500 12 HFB160093-300 6 28R1141-010 3 HFB170070-000 8 28R1227-100 8 HFB170070-100 6 28R1236-000 4 HFB187102-100 6 28R1240-010 4 HFB259128-100 3 28R1261-100 4 28R1261-200 12 28R1262-000 4 28R1340-100 10 28R1340-200 4 28R1417-000 3 28R1450-100 12 28R1457-400 6 28R1496-000 3 28R1517-000 3 28R1654-010 8 28S0670-000 20 28S2023-0M0 4 28S2827-210 16 www.laird.com 33 FERRITE EMI CABLE CORES SAMPLE KIT LISTS LOW FREQUENCY FERRITE EMI CORES PARTS AND SUPPLIES FOR SAMPLE KIT# K-408 EMI LFB PART NUMBER QTY PER KIT LFB090050-000 24 LFB095051-000 12 LFB127079-000 24 LFB143064-000 6 LFB143064-100 12 LFB159079-000 6 LFB174095-000 6 LFB180100-000 18 LFB187102-000 6 LFB220140-000 8 LFB250150-000 8 LFB259128-000 4 LFB290190-000 6 LFB310190-000 6 LFB360230-300 4 FERRITE EMI DISKS AND PLATES FERRITE PLATES FOR WIRELESS CHARGING PARTS AND SUPPLIES FOR SAMPLE KIT# K-407 EMI DISC PL 34 www.laird.com PARTS AND SUPPLIES FOR SAMPLE KIT# K-412 PLATES PART NUMBER QTY PER KIT PART NUMBER QTY PER KIT MM0650-100 5 MP1040-3M0 4 MM0787-100 5 MP1496-0M0 4 MM0787-200 5 MP2106-0M0 3 MM1400-200 5 MP2126-0M0 3 MM1400-300 5 MP2170-1M0 3 MP0315-200 5 MP3940-0M0 1 MP0350-000 5 33P2098-0M0 2 MP0433-000 5 33P3839-0M0 2 MP0512-200 5 MP0590-200 5 MP0591-200 5 MP0760-100 5 MP1040-100 5 MP1040-200 5 MP1040-300 5 MP1496-000 5 ANTENNA & RECEPTION | EMBEDDED WIRELESS | EMI | TELEMATICS | THERMAL | WIRELESS AUTOMATION CONTROL ANTENNAS & RECEPTION | EMBEDDED WIRELESS | EMI | TELEMATICS | THERMAL | WIRELESS AUTOMATION & CONTROL USA: +1.866.928.8181 Europe: +49.8031.24600 Asia: +86.755.2714.1166 www.laird.com MCP-CAT-FERRITE CORES MCP-CAT-FERRITE CORES 072315 071817 SIP-CAT-EMI FILTERING RF 1213 Laird Technologies, All specifications arespecifications subject to change without notice. the application of materials rests with Any and its agentsInc. is believed to be accurate and notice. Responsibility Responsibility for the use use and andfor application of Laird Laird materials rests Technologies with the the end end user, user,since since Any information information furnished by Laird and its agents is believed to reliable. be accurate and reliable. All are subject to change without notice.for Responsibility the use and application of Laird Laird and its agents cannot aware all potentialmakes uses. Laird makes as the suitability of anyofLaird materials or products for anyorspecific or for general uses. Laird, Laird Technologies, materials rests with the endbe user. LairdofTechnologies no warranties to the fitness, suitability or or non-infringement any Laird Technologies materials products any specific or general Laird Laird makes no noaswarranties warranties as to tomerchantability, the fitness, fitness, merchantability Laird, Lairduses. Technologies, Inc or any Technologies not beshall liablenot forbeincidental consequential damages of damages any kind. All Lairdkind. Technologies products are sold to Laird Technologies’ Terms and time tototime, a copy ofupon of its affiliatesshall or agents liable fororincidental or consequential of any All the Laird Conditions of sale in effect from time of toofsale time, aeffect copy offrom which will betime, furnished All Laird Laird to areTechnologies’ sold pursuant pursuantTerms tothe theand Laird Technologies’ Terms andConditions Conditions saleinin effectfrom time a copy of which which furnished uponLaird request. © Copyright Laird Technologies, Inc.Rights All Rights Reserved. Laird, Laird Technologies, Laird and marks are trade or registered trade marks of company Laird will be will furnished upon2020 request. ©Technologies, Copyright 2014 Laird Technologies, Inc.Laird, All Reserved. Laird, Laird Technologies, thethe Laird Logo, and other Logo, marks areother trademarks or of registered trademarks of Technologies, Inc. orthereof. an affiliate request. © be Copyright Inc.2013 All Rights Reserved. Laird Technologies, the Laird Logo, and other marks areTechnologies trademarks or registered trademarks Lairdmarks Technologies, Inc.Laird or an affiliate Technologies, Inc. or an affiliate company thereof. Other product or service mayprovides beNothing the property ofunder third any parties. Nothing herein provides a license underintellectual any Laird Technologies or any third party intellectual property rights. Other product or service names be the property of third Nothing a license or any third rights. company thereof. Other productmay or service names may be theparties. property of names thirdherein parties. herein provides aLaird license under anyparty Lairdintellectual or any thirdproperty party property rights.
TYS60454R5M-10 价格&库存
很抱歉,暂时无法提供与“TYS60454R5M-10”相匹配的价格&库存,您可以联系我们找货
