Technical Data Sheet
TRA-DUCT 2902
June-2010
PRODUCT DESCRIPTION
TRA-DUCT
2902
provides
the
following
product
characteristics:
Technology
Epoxy
Appearance
Silver
Filler Type
Silver
Cure
Room Temperature or Heat Cure
Components
Two component - requires mixing
Product Benefits
• Electrically conductive
• Thermally conductive
• Solvent-free
• High adhesion
• Two component
• Room temperature cure
• Good adhesion to a variety of
substrates
Mix Ratio, by weight 100 : 6
Resin : Hardener
Typical Assembly
Electrical modules, Printed circuitry,
Applications
Wave guides, Flat cables, High
frequency shields and Cold solder
Operating Temperature -60 to 110 °C
Application
Bonding, Sealing or Repair
Surfaces
Ceramics, Many metals, Glass and
Plastic laminates
TYPICAL PROPERTIES OF CURED MATERIAL
Physical Properties:
Coefficient of Thermal Expansion, cm/cm/ºC
Glass Transition Temperature (Tg), °C
Thermal Conductivity, W/mk
Hardness, Shore D
4.9×10-05
52
2.99×1000
80
Electrical Properties:
Volume Resistivity, ohms-cm:
1 hour @ 110°C
15 minutes @ 150ºC
2 hours @ 65ºC
24 hours @ 25ºC
5 minutes @ 160ºC
0.0006
0.0005
0.0009
0.001
0.0003
Outgassing Properties:
Total Mass Loss, %
Collected Volatile Condensable Material, %
TYPICAL PERFORMANCE OF CURED MATERIAL
Lap Shear Strength :
Aluminum:
Cured @ 110 °C for 1 hour
TRA-DUCT 2902 is designed for electronic bonding and
sealing applications that require a combination of good
mechanical and electrical properties.
Cured @ 150 °C for 15 minutes
TRA-DUCT 2902 passes NASA outgassing standards.
Cured @ 25 °C for 24 hours
ISO-10993-5
TRA-DUCT 2902 was tested to and passed the requirements
of ISO 10993-5 for Cytotoxicity.
TYPICAL PROPERTIES OF UNCURED MATERIAL
Mixed Viscosity, mPa·s (cP) :
cp #52, 10 rpm
Specific Gravity, mixed
Pot life , minutes
Flash Point - See MSDS
20,000
3.2
60
TYPICAL CURING PERFORMANCE
Cure Schedule
24 hours @ 25°C or
1 to 4 hours @ 65°C
The above cure profile is a guideline recommendation. Cure
conditions (time and temperature) may vary based on
customers' experience and their application requirements, as
well as customer curing equipment, oven loading and actual
oven temperatures.
0.64
0.05
Cured @ 65 °C for 2 hours
N/mm²
(psi)
N/mm²
(psi)
N/mm²
(psi)
N/mm²
(psi)
11
(1,600)
11
(1,600)
7
(1,000)
5
(700)
GENERAL INFORMATION
For safe handling information on this product, consult the
Material Safety Data Sheet, (MSDS).
DIRECTIONS FOR USE
1. Carefully clean and dry all surfaces to be bonded.
2. Remove clamp and thoroughly mix the TRA-DUCT 2902
epoxy adhesive system components in the handy BIPAX
mixing-dispenser package until color is uniform
throughout.
3. Apply this completely mixed adhesive to the prepared
surfaces, and gently press these surfaces together.
Contact pressure is adequate for strong, reliable bonds;
however, maintain contact until adhesive is completely
cured.
4. Some separation of components is common during
shipping and storage. For this reason, it is recommended
that the contents of the shipping container be thoroughly
mixed prior to use.
5. Some ingredients in this formulation provided in BIPAX,
TRA-PAX and bulk packaging may crystallize when
subjected to low temperature storage. A gentle warming
cycle of 52ºC for 30 minutes prior to mixing components
may be necessary. Crystallized epoxy components do
not react as well as liquid components and should be
redissolved prior to use for best results.
Not for product specifications
The technical data contained herein are intended as reference
only. Please contact your local quality department for
assistance and recommendations on specifications for this
product.
Storage
Store product in the unopened container in a dry location.
Storage information may be indicated on the product container
labeling.
Optimal Storage: 27 °C
Material removed from containers may be contaminated during
use. Do not return product to the original container. Henkel
Corporation cannot assume responsibility for product which
has been contaminated or stored under conditions other than
those previously indicated. If additional information is required,
please contact your local Technical Service Center or
Customer Service Representative.
Conversions
(°C x 1.8) + 32 = °F
kV/mm x 25.4 = V/mil
mm / 25.4 = inches
N x 0.225 = lb
N/mm x 5.71 = lb/in
N/mm² x 145 = psi
MPa x 145 = psi
N·m x 8.851 = lb·in
N·m x 0.738 = lb·ft
N·mm x 0.142 = oz·in
mPa·s = cP
Americas
+1.888.943.6535
Note
The data contained herein are furnished for information only
and are believed to be reliable. We cannot assume
responsibility for the results obtained by others over whose
methods we have no control. It is the user's responsibility to
determine suitability for the user's purpose of any production
methods mentioned herein and to adopt such precautions as
may be advisable for the protection of property and of persons
against any hazards that may be involved in the handling and
use thereof. In light of the foregoing, Henkel Corporation
specifically disclaims all warranties expressed or implied,
including warranties of merchantability or fitness for a
particular purpose, arising from sale or use of Henkel
Corporation’s products. Henkel Corporation specifically
disclaims any liability for consequential or incidental
damages of any kind, including lost profits. The discussion
herein of various processes or compositions is not to be
interpreted as representation that they are free from
domination of patents owned by others or as a license under
any Henkel Corporation patents that may cover such
processes or compositions. We recommend that each
prospective user test his proposed application before repetitive
use, using this data as a guide. This product may be covered
by one or more United States or foreign patents or patent
applications.
Trademark usage
Except as otherwise noted, all trademarks in this document
are trademarks of Henkel Corporation in the U.S. and
elsewhere. ® denotes a trademark registered in the U.S.
Patent and Trademark Office.
Reference 0.3
Europe
+44.1442.278.000
Asia
+86.21.3898.4800
For the most direct access to local sales and technical support visit: www.henkel.com/electronics
很抱歉,暂时无法提供与“1402586”相匹配的价格&库存,您可以联系我们找货
