M5475JFEE
M5475JFEE
    BEACONEMBEDDEDWORKS
    IC MOD COLDFIRE 266MHZ 64MB
M5475JFEE 数据手册
PRODUCT BRIEF: Logic :: Freescale MCF5475 FIRE ENGINE System on Module The MCF5475 Fire Engine is a compact, product-ready hardware and software solution that fast forwards your embedded product design. MCF5475 FIRE ENGINE :: HIGHLIGHTS: + Product-ready System on Module with the Freescale MCF5475 ColdFire microprocessor running up to 266 MHz + SOM-ETX form factor 114 mm x 95 mm x 13.8 mm The ColdFire MCF5475 processor is ideally suited for embedded industrial applications requiring simultaneous control, connectivity, and security. The Fire Engine module based on this processor is a complete System on Module (SOM) offerring essential features for embedded applications. Using a SOM allows engineers to design a custom baseboard that meets their specific needs and is compatible with other Logic SOMs. This compatibility makes it easy for developers to upgrade their product for greater functionality and performance—while still using their original baseboard design. Zoom™ By starting with the corresponding EVB Development Kit, developers can write application software on the same hardware that will be used in the final product. The MCF5475 ColdFire processor from Freescale Semiconductor provides a broad range of peripheral support, making it an ideal processor for industrial and embedded applications. + Long + 0 product life-cycle ˚C to 70 ˚C (commercial temp) + RoHS compliant ZOOM ™ COLDFIRE EVB :: FEATURES: + Application + MCF5475 baseboard Fire Engine (M5475CFEE) + Necessary accessories to immediately get up and running + Kit MCF5475 Fire Engine available from Freescale (M5475EVBE) + See Zoom™ ColdFire EVB product brief for more information Designing a product around Logic’s SOM allows developers to easily combine their core technologies with the high performance of the MCF5475 ColdFire processor. Product Features MCF5475 Fire Engine Block Diagram 5V Power In RESETS & POWER REG/MONITORING Processor + Freescale MCF5475 ColdFIre V4e microprocessor running up to 266 MHz BOOT FLASH DDR SDRAM SDRAM Memory + 64 MB DDR SDRAM standard NOR FLASH X4 I2C 2x 10/100 Ethernet Phy 4x USB 2.0 Host F E C D E B U G U A R T I F S DDR ColdFire MCF5475 Flash Memory + Boot flash: 2 MB + NOR flash: 16 MB X2 ISA-like CPLD P C I USB Target PCI F L E X B U S Display + Programmable color LCD controller + Built-in driver supports up to 1024x768 with 16-bit LCD interface CompactFlash JTAG BDM Network Support + Dual 10/100 Base-T Ethernet controller for application/debug USB Device X3 PCI Graphics Controller CRT, LCD, LV X1 PC Card Expansion + CompactFlash Type I card (memory-mapped mode only) supported through the CPLD + Two PCI 2.2 slots MCF5475 Fire Engine Ordering Information Freescale PN M5475CFEE Speed SDRAM Boot Flash NOR Flash (MB) Graphics Audio Ethernet USB Host up to 266 64 2 16 Y Y Y Y (MHz) (MB) (MB) ZOOM™ ColdFire EVB Ordering Information Freescale PN SOM Configuration Recommended Resale M5475EVBE M5475CFEE $850 USB + One USB 2.0 high-speed device interface + Four USB 2.0 high-speed host interfaces PSC Ports + Four PSC UARTs + Configurable as UART, USART, modem, codec, or IrDA PWM + Four channels GPIO + Programmable requirements Software + LogicLoader™ (bootloader/monitor) + Freescale dBug ROM monitor + Other third-party options LOGIC WEBSITE :: DESIGN RESOURCES: + Logic Technical Support : http://www.logicpd.com/support/ + Technical Discussion Group : http://www.logicpd.com/support/tdg/ + Frequently + For IO depending on peripheral Asked Questions (FAQ) : http://www.logicpd.com/support/faq/ Mechanical + 95 mm wide x 114 mm long x 13.8 mm high more information contact Logic Sales : product.sales@logicpd.com RoHS Compliant embedded product solutions 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com © 2007 Logic Product Development. All rights reserved. PN: 1001849 Rev D
M5475JFEE 价格&库存
很抱歉,暂时无法提供与“M5475JFEE”相匹配的价格&库存,您可以联系我们找货
