PC+PBT by Push Plastic
3 mm , 750g reel
PC+PBT is a polycarbonate filament alloy from Push Plastic that excels in
balancing print stiffness, structural integrity, and impact strength with superb
filament ductility. PC+PBT filament produces sturdy, quality prints with
excellent fatigue performance and a high chemical resistance to motor oil and
grease.
Print Surface Recommendation:
PC+PBT filament is a polycarbonate-based material, therefore applying a glue
stick (such as Elmer's® brand) directly to the print surface before starting your
LulzBot 3D printer is strongly recommended for increased printed object
adhesion.
Works with: LulzBot Mini 2, LulzBot Mini 1, LulzBot TAZ 6, LulzBot TAZ
5, LulzBot TAZ/Mini Aerostruder, LulzBot Hexagon, LulzBot TAZ 6
Hexagon, LulzBot TAZ 5 Hexagon
This polycarbonate alloy material produces smooth prints with excellent
structural integrity and a high chemical resistance to motor oil and grease,
making it ideal for industrial applications in need of long-term fatigue
performance (i.e. 3D printed PC+PBT dirt bike parts from MotoMinded LLC).
Filament Specifications
Filament Diameter: 2.85mm (0.11 inches)
Amount of Filament: 750g (1.65 lbs)
Filament Colors: Black and White
Printing Specifications
Hot End Temperature Range: 235°C-255°C
Print Surface: 110°C-120°C; PC+PBT filament is a polycarbonate-based
material, therefore applying a glue stick (such as Elmer's® brand) directly to
the print surface before starting your LulzBot 3D printer is strongly
recommended for increased printed object adhesion.
Packaging Information
PC+PBT filament ships vaccum sealed and mounted on a reel.
Storage Information
Store your filament in an air tight container. The use of desiccant is especially
encouraged in humid environments as PC+PBT filament will absorb moisture
from the air.
Print Profiles
Get the most up-to-date print profiles, including hot end and print bed
temperatures, by updating to the latest version of Cura LulzBot Edition
software:
Black White
https://www.lulzbot.com/store/filament/pcpbt 11‐19‐18
很抱歉,暂时无法提供与“RM-PY0012”相匹配的价格&库存,您可以联系我们找货
