Great for Beginners
SE Tool Head | Single Extruder | 0.5 mm
Versatility and precision come standard with the LulzBot SE Tool Head,
featuring the Universal Mounting System, and the industry leading Titan Aero
Hot End and Extruder from E3D. This tried and true combination enables
a vast palette of supported 3D printing material, both rigid and flexible.
As the featured tool head on the LulzBot Mini 2 3D Printer, the SE tool head is
here to bring even more performance and dependability to your already trusty
LulzBot TAZ 6, TAZ 5, and LulzBot Mini 1.
Compatibility Alert:
This tool head is currently compatible with the LulzBot Mini 2 3D Printer.
LulzBot Mini 1, TAZ 5 & TAZ 6 users will be able to upgrade to the SE Tool
Head with the TAZ 5/6 Universal Tool Head Adapter and the Mini 1 Universal
Tool Head Adapter.
Works with: LulzBot Mini 2
Features
The LulzBot SE Tool Head features a genuine E3D Titan Aero
Extruder/Hot End with a 0.50 millimeter nozzle enabling out of
the box 3D printing with over 35 materials, including flexibles!
Printer. LulzBot Mini 1, TAZ 5 & TAZ 6 users can add this tool
head with the TAZ 5/6 Universal Tool Head Adapter and the Mini
1 Universal Tool Head Adapter.
A high-output centrifugal fan and quad-port cooling duct support
elaborate prints with extensive bridging, cooling filament in 360degrees before it has time to sag between points.
The Universal Mounting System makes swapping tool heads
easy, you'll have the right tool head for the right job installed in
minutes.
Parts & Specifications
Parts Included
(1) LulzBot SE Tool Head | 0.5 mm (Fully Assembled)
Specifications
Layer Resolution: 0.05 mm - 0.5 mm (0.002 in - 0.020 in)
Nozzle Diameter: 0.5 mm
Hot End Temperature Range: 120°C - 290°C (248°F - 554°F)
Hot End Heatup Time: From 23°C to 210°C (73°F to 410°F) in 73
seconds
Extruder & Hot End: Genuine E3D Titan Aero
Required power system: 24 Volts
Fans: (1) 5v 40 mm heat sink cooling fan, and (1)
360° print cooling fan
Recommended filament diameter: 2.85 mm diameter (3 mm)
Certified Open Source Hardware: US000138
https://www.lulzbot.com/store/tool‐heads/se‐tool‐head‐single‐extruder‐05‐mm/1‐18‐19
很抱歉,暂时无法提供与“KT-CP0136”相匹配的价格&库存,您可以联系我们找货
