Suited for Intermediate Users
t-glase by Taulman 3D
3 mm , 1lb reel
t-glase 3D prints well while also offering a high degree of translucence.
Models printed in t-glase have a great surface finish, can reflect light well, and
depending on the part geometry, can even shimmer and gleam. One of the
more exciting characteristics of this filament is it's ability to act as a light pipe
to transmit light. Use larger layer heights for enhanced translucence.
PRODUCT ALERT (3)
Printing Performance Recommendation:
One of best characteristics of t-glase is its optical properties (translucence and
light-pipes). Printing with a tool head with a larger nozzle diameter (0.50mm)
is preferred. If the optical properties are not the important characteristic tglase prints well with either nozzle diameter (0.35mm/0.50mm).
Print Surface Recommendation:
Applying a glue stick (such as Elmer's® brand) directly to the print surface
before starting your LulzBot 3D printer is strongly recommended for increased
printed object adhesion.
Packaging Note:
Reel diameter and packaging style may vary based on color selection.
Filament weight remains the same.
Works with: LulzBot Mini, LulzBot TAZ 6, LulzBot TAZ 5, LulzBot TAZ 14, LulzBot TAZ/Mini Aerostruder, LulzBot TAZ Dual Extruder, LulzBot TAZ
FlexyDually, LulzBot Hexagon, LulzBot TAZ 6 Hexagon, LulzBot TAZ 5
Hexagon, LulzBot TAZ 1-4 Budaschnozzle, LulzBot Budaschnozzle
Support: t-glase, 3mm Filament, 1lb Reel (Taulman)
Colors
Aqua
Black
Green
Red
Blue
White
Clear
Features
t-glase is a PETT based filament that can be used in most desktop 3D
printers. This filament is 100% recyclable and experiences very little
shrinking and is available in a range of colors. This filament can be
extruded under a wide temperature range.
Parts & Specifications
Filament Specifications
Filament Diameter: 3 mm (0.12 inches)
Amount of Filament: 1 lb (0.45 kg)
Filament color may vary
Printing Specifications
Special Tool Head Requirements: LulzBot Hexagon Hot End
recommended
Hot End Temperature Range: 230°C
Print Surface: PEI film recommended
Print Surface Temperature: 60°C
Packaging Information
T-Glase filament ships vacuum sealed and mounted on a reel
https://www.lulzbot.com/store/filament/t‐glase 4‐6‐18
很抱歉,暂时无法提供与“RM-PE0003”相匹配的价格&库存,您可以联系我们找货
