Suited for Advanced Users
LulzBot TAZ Dual Extruder v3 Tool Head
Take your designs to the next level with the all-new LulzBot TAZ Dual
Extruder v3 Tool Head. This tool head was engineered
to utilize dedicated support material, including soluble filament, like
PVA, that dissolves and separates in water, freeing you to focus on
the function of your design rather than on how to make it 3D printable.
The Dual Extruder v3 does not require nozzle leveling or offset
calibration, is lighter and more compact than its predecessor, and
features improved heat sink and part cooling. With hassle-free
hardware, integrated software, and water-soluble support material,
who knew geometric freedom could be this easy?
Features
The LulzBot TAZ Dual Extruder v3 was engineered with a focus
on printing with dedicated support materials. The Dual Extruder v3
enables 3D printing complex geometry that previously would have
required time spent removing same-material supports with a risk of
breaking your print and almost always leaving evidence of the support
in imperfect bottom surfaces. With water-soluble supports like PVA, let
the water do the work and enjoy clean and accurate bottom surfaces.
The Dual Extruder v3 features a unibody heatsink with two hot ends
co-developed with E3D, makers of the ever popular line of all-metal
hot ends. The precision-machined design brings the hot ends closer
together, resulting in a dual extruder with no need for nozzle leveling
or offset calibration. Just install the tool head and accessories, quickly
flash firmware with Cura LulzBot Edition, and start printing.
The Dual Extruder v3 comes with everything you need to install on
your LulzBot TAZ 6, including an extra wide wiper pad mount that
enables your Dual Extruder v3 to work flawlessly with LulzBot selfcleaning and self-leveling technology.
The Dual Extruder v3 was specifically designed for 3D printing models
with soluble support material, which is the primary reason LulzBot
users want dual extrusion. Soluble support allows freedom of
design which means better rapid prototypes and better efficiency.We
have had many questions about the v3’s ability to do other kinds of
dual extrusion printing:
Question 1: Can the LulzBot TAZ Dual Extruder v3 Tool Head print in
two colors of the same material?
Answer: Yes, absolutely, however the print profiles built into Cura
LulzBot Edition have not been optimized for multicolor printing. If
multicolor printing is your goal, you may need to make modifications to
the included profiles for optimal results. We have included all LulzBot
supported material base profiles under the Experimental classification
in Materials as a good starting point. As we continue to develop Cura
LulzBot Edition, we hope to have more supported material
combinations in the future.
Question 2: Can the LulzBot TAZ Dual Extruder v3 Tool Head print
flexible materials?
Answer: Yes, the Dual Extruder v3 is capable of printing flexible
materials. Through our internal testing, we have found that
PolyDissolve S1 and PVA stick very will to TPU’s (flexible filaments),
but the profiles have not yet been fine-tuned for optimal cosmetic
results. Because of this, all of our flexible material profiles have been
included in the Experimental section of Cura LulzBot Edition as a
starting point for making your own modifications. Printing with flexible
materials is recommended for advanced users on the Dual Extruder
v3. As we continue to work on Cura LulzBot Edition, we hope to have
more supported materials in the future.
Question 3: Can the LulzBot TAZ Dual Extruder v3 Tool Head print
solid and flexible materials together?
Answer: Yes, the hardware of the Dual Extruder v3 is capable of
printing solid and flexible material together, but the profiles have not
been optimized for reliability or cosmetic results. Because ofthis, all of
our flexible and solid material profiles are included in the Experimental
section of Cura LulzBot Edition Materials, and can be used as a good
and solid materials is recommended for advanced users on the Dual
Extruder v3.
Question 4: Where can the individual components for the LulzBot TAZ
Dual Extruder v3 be purchased?
Answer: We are currently ramping up production on the v3 Dual
Extruder Tool Head, and at the moment we are using all components
for production units. Once our inventory levels stabilize, we will likely
be carrying the harder-to-find components, such as the hot ends,
machined parts, and motors. Sign up for our New Product newsletterin
order to get the latest information on new product releases.
Parts & Specifications
Parts Included
(1) LulzBot TAZ Dual Extruder Tool Head v3 (Fully Assembled)
(1) 3D Printed Z-axis endstop extension mount (for TAZ 6)
(1) Machined Z-axis endstop extension (for TAZ 6)
Note: The Z-axis Toggle Extension and Mount should only be
used on a TAZ 6 with the Dual Extruder v3 Tool Head. Leaving
this extension on the printer and using it with other tool heads
will cause failed probes due to the higher registered minimum
position.
(1) Dual v3 wiper mount
(1) Additional spool arm
(1) Feed tube spinner
(1) T-nut holder jig
(1) Idler jig
(4) Wire tie
(4) 3D printed low profile bed corners (For TAZ 5)
(2) Extension harnesses
(1) M5 washer (Black)
(1) M5 x 14 socket head cap screw
(1) Filament Feed tube
(1) Sample length of Polylite PLA
(1) Sample length of PolyDissolve S1
Specifications
Required filament diameter: 2.85mm diameter
Hot end temperature range: 120°C - 300°C
Nozzle diameters: 0.5mm
Required power system: 24 Volts
Fans: Two 24v 40mm axial fans for extrusion cooling, one 5v
40mm axial fan for heat-sink cooling
Weight: 0.96 kg (2.11 lbs)
https://www.lulzbot.com/store/tool‐heads/lulzbot‐taz‐dual‐extruder‐v3‐tool‐head 4‐11‐18
很抱歉,暂时无法提供与“KT-CP0127”相匹配的价格&库存,您可以联系我们找货
