RKT 5L-949/10 M
RKT 5L-949/10 M
    BELDEN
    缆线组件 32.8'(10.00m)
RKT 5L-949/10 M 数据手册
Datasheet The information/details in this datasheet merely contain general descriptions or performance factors which, when applied in an actual situation, do not always correspond with the described form, and may be amended by way of the further development of products. The desired performance factors shall only be binding if these are expressly agreed on conclusion of the contract. Datasheet-No. 934-849-999 EN Revison: 11 Type: Created: 2017-04-21 pkuhn RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 1 of 6 Datasheet Product description - M12 female shielded / unshielded connecor with threaded joint and molded cable - knurled nut with self-locking threaded joint - Optional 360° shielding connected to knurled nut RKT(S) 4 / 5…., see standard products see standard products female 5 (4+PE):, K - Coding 5 (4+FE):, L - Coding 4 (3+PE):, S - Coding 4:, T - Coding IEC 61076-2-111 K-, L-, S- or T-coded 1,5 mm² * K: blue L: grey S: black T: dark-grey Type Order No Type of contacts Number of contacts Standard Construction type Conductor size Color contact bearer * Cable size: 0,75 mm² and 2,5 mm² on request Technical data Clearance / Creepage distance Rated voltage Operating voltage DIN EN 60664-1 (2008/01); VDE 0110-1 see table, last page 600 V ac/dc, K- / S-Coding 50 V ac / 60 V dc, L- / T-Coding Rated current * 16 A; 1,5 mm² 10 A; 0,75 mm² see table, last page III acc. to DIN EN 60664-1 (VDE 0110-1) 3 acc. to DIN EN 60664-1 (VDE 0110-1) ≤ 10 mΩ > 10^9 Ohm max. 100 Rated impulse voltage Overvoltage category Pollution degree Contact resistance Insulation resistance Mating cycles * Notice derating Materials RoHS (EU directive) Contact Contact plating Contact bearer over molding Coupling nut O-ring Surface coupling nut Shielding sleeve Datasheet-No. 934-849-999 EN Revison: 11 2011/65/EU CuNi Cu/Au PBT GF TPE, blue or black CuZn FKM Cu/Ni CuZn, plating: Ni Type: Created: 2017-04-21 pkuhn RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 2 of 6 Datasheet Environmental conditions Protection class (IEC 60529) * Temperature range (connector) IP65, IP67 -40 °C to +125 °C, notice derating * only if mounted and locked in combination with Hirschmann / Lumberg connector. Flammability class over molding Contact bearer UL 94 HB UL 94 V-2 Approvals VDE UL DIN EN 61984: in preparation UL 2238, E315587 Cable-data Cabletype see cable-datasheets further types on request Additional technical data Fastening torque (coupling nut) M 12x1: (50-60) Ncm, hand-tight Cutline Do not connect / disconnect under load. Caution hot! Under power the surface of the connector can reach a temperature of more then 56 °C (144 °F). The specified electrical and mechanical characteristics require a properly locked connector. When the connetor is unlocked and in risk of pollution the connector has to be covered with a protective cap ≥ IP54. "L" = standard length of control line Further technical information on control lines see STL 700 to STL 740 Datasheet-No. 934-849-999 EN Revison: 11 Type: Created: 2017-04-21 pkuhn RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 3 of 6 Datasheet Datasheet-No. 934-849-999 EN Revison: 11 Type: Created: 2017-04-21 pkuhn RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 4 of 6 Datasheet Standard products Artikel-No. 000-018-615 000-020-033 000-020-376 934-849-001 934-849-002 934-849-003 934-849-004 934-849-005 934-849-006 934-849-007 934-849-008 934-849-009 934-849-010 934-849-011 934-849-012 934-849-017 934-849-018 934-849-019 934-849-020 934-849-021 934-849-022 934-849-023 934-849-024 934-849-025 934-849-026 934-849-027 934-849-028 934-849-039 934-849-040 934-849-041 934-849-042 934-849-043 934-849-044 934-849-045 934-849-046 934-849-047 934-849-048 934-849-049 934-849-050 934-849-055 934-849-056 934-849-057 934-849-058 934-849-059 934-849-060 934-849-061 934-849-062 934-849-075 934-849-076 934-849-077 934-849-078 934-849-081 934-849-082 934-849-083 934-849-301 934-849-302 934-849-303 934-849-304 934-849-305 934-849-306 Type Rated voltage Rated impulse voltage Cable size 630 V 630 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 6 kV 6 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 0,75 mm² 0,75 mm² 0,75 mm² 0,75 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² RKTS 4S-700/3 M RKT 4S-703/1 M RKT 4T-723/0,65 M RKT 4S-703/2 M RKT 4S-703/5 M RKT 4S-703/10 M RKT 4S-703/15 M RKT 4S-733/2 M RKT 4S-733/5 M RKT 4S-733/10 M RKT 4S-733/15 M RKT 4T-723/2 M RKT 4T-723/5 M RKT 4T-723/10 M RKT 4T-723/15 M RKT 5K-911/2 M RKT 5K-911/5 M RKT 5K-911/10 M RKT 5K-911/15 M RKT 5K-735/2 M RKT 5K-735/5 M RKT 5K-735/10 M RKT 5K-735/15 M RKT 5K-736/2 M RKT 5K-736/5 M RKT 5K-736/10 M RKT 5K-736/15 M RKTS 4S-700/2 M RKTS 4S-700/5 M RKTS 4S-700/10 M RKTS 4S-700/15 M RKTS 4S-915/2 M RKTS 4S-915/5 M RKTS 4S-915/10 M RKTS 4S-915/15 M RKTS 4T-722/2 M RKTS 4T-722/5 M RKTS 4T-722/10 M RKTS 4T-722/15 M RKTS 5K-910/2 M RKTS 5K-910/5 M RKTS 5K-910/10 M RKTS 5K-910/15 M RKTS 5K-916/2 M RKTS 5K-916/5 M RKTS 5K-916/10 M RKTS 5K-916/15 M RKT 5L-949/2 M RKT 5L-949/5 M RKT 5L-949/10 M RKT 5L-949/15 M RKTS 5L-956/2 M RKTS 5L-956/5 M RKTS 5L-956/10 M RKT 4S-703/2 M SW RKT 4S-703/5 M SW RKT 4S-703/10 M SW RKT 4S-703/15 M SW RKT 4S-733/2 M SW RKT 4S-733/5 M SW Datasheet-No. 934-849-999 EN Revison: 11 Type: Created: 2017-04-21 pkuhn RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 5 of 6 Datasheet 934-849-307 934-849-308 934-849-309 934-849-310 934-849-311 934-849-312 934-849-317 934-849-318 934-849-319 934-849-320 934-849-321 934-849-322 934-849-323 934-849-324 934-849-325 934-849-326 934-849-327 934-849-328 934-849-339 934-849-340 934-849-341 934-849-342 934-849-343 934-849-344 934-849-345 934-849-346 934-849-347 934-849-348 934-849-349 934-849-350 934-849-355 934-849-356 934-849-357 934-849-358 934-849-359 934-849-360 934-849-361 934-849-362 934-849-381 934-849-382 934-849-383 934-849-384 934-849-385 934-849-386 RKT 4S-733/10 M SW RKT 4S-733/15 M SW RKT 4T-723/2 M SW RKT 4T-723/5 M SW RKT 4T-723/10 M SW RKT 4T-723/15 M SW RKT 5K-911/2 M SW RKT 5K-911/5 M SW RKT 5K-911/10 M SW RKT 5K-911/15 M SW RKT 5K-735/2 M SW RKT 5K-735/5 M SW RKT 5K-735/10 M SW RKT 5K-735/15 M SW RKT 5K-736/2 M SW RKT 5K-736/5 M SW RKT 5K-736/10 M SW RKT 5K-736/15 M SW RKTS 4S-700/2 M SW RKTS 4S-700/5 M SW RKTS 4S-700/10 M SW RKTS 4S-700/15 M SW RKTS 4S-915/2 M SW RKTS 4S-915/5 M SW RKTS 4S-915/10 M SW RKTS 4S-915/15 M SW RKTS 4T-722/2 M SW RKTS 4T-722/5 M SW RKTS 4T-722/10 M SW RKTS 4T-722/15 M SW RKTS 5K-910/2 M SW RKTS 5K-910/5 M SW RKTS 5K-910/10 M SW RKTS 5K-910/15 M SW RKTS 5K-916/2 M SW RKTS 5K-916/5 M SW RKTS 5K-916/10 M SW RKTS 5K-916/15 M SW RKT 5L-949/2 M SW RKT 5L-949/5 M SW RKT 5L-949/10 M SW RKTS 5L-956/2 M SW RKTS 5L-956/5 M SW RKTS 5L-956/10 M SW Datasheet-No. 934-849-999 EN Revison: 11 630 V 630 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 630 V 63 V 63 V 63 V 63 V 63 V 63 V Type: Created: 2017-04-21 pkuhn 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 6 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,5 kV 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 0,75 mm² 0,75 mm² 0,75 mm² 0,75 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² 1,50 mm² RKT(S) …/… M M12 female power connector 4 / 5-poles Page: 6 of 6
RKT 5L-949/10 M 价格&库存
很抱歉,暂时无法提供与“RKT 5L-949/10 M”相匹配的价格&库存,您可以联系我们找货
