ATOMIC
SKU:A077
Description
ATOMIC is a DIY Proto Kit designed specially for the Atom series, which makes it convenient for users to design small circuits or external hardware
by themselves. It can be stacked with Atom directly via the 9 pins on the base. Two blank proto boards are provided in the kit, each of which
provides more than 60 hole positions to meet the spatial layout requirements of users. A pair of 3.96 4 pin connectors are contained to make the
external electrical connection more reliable. The shell incorporates a series of ventilation holes which allow heat dissipation and allows for more
accurate temperature and humidity readings from sensors. The product provides a variety of attachment methods, such as mounting hole, Lego
connection, screw mounting, etc. If you want to make a mini controller with customized characteristics, ATOMIC should be the best choice.
Product Features
Compatible with Atom Matrix/Atom Lite
Compact design
DIY Style
Built-in Infra-red
Open design
Include
1x Proto Board
1x Proto Board(soldered pin/finished product)
1x 4P VH-3.96 Plug + Plug Base
1x 4P 2.54 Pins
1x 5P 2.54 Pins
1x ATOMIC Case
1x M2*3mm Hexagon self tapping screw
1x M2*8mm Hexagon socket cup head machine screw
Applications
Atom expansion board
DIY node controller
Peripheral connection
Specification
Related Link
PcbDoc
ATOMIC v1.0
Specification
Parameter
External port
VH-3.96 4P
Net weight
5g
Gross weight
42g
Product Size
24*48*18mm
Package Size
50*50*20mm
Case material
Plastic (PC)
很抱歉,暂时无法提供与“A077”相匹配的价格&库存,您可以联系我们找货
