ATOM MATE
SKU:A086
Description
ATOM MATE is a DIY expansion kit specially designed for the M5ATOM family. The kit contains 3 kinds of accessories. AtomPin is a pin adapter
board that can expand the bottom pins of the M5Atom from all sides, making it easier to build circuits on the breadboard. With a special bracket,
you can easily attach M5Atom without affecting the use of the pins. AtomHat is an adapter board for adapting the M5StickC Hat series of
products for use with the M5Atom. If you already have some HAT accessories, you can directly use the AtomHat adapter to reuse them with
M5Atom. There is a cross shaped hole on the bottom which can be connected to Lego, allowing for easy mounting onto Lego projects.
Notice
Please check the Hat pins before using AtomHat, you may need to modify the program pin number,when using PIR HAT with AtomHat, it is
necessary to set the 33 pin as an internal pull-up
Product Features
Compatible with Atom Matrix/Atom Lite
Multiple DIY methods
Flexible installation
Adapt to HAT/bread board
Include
1x AtomPin frame
1x AtomPin board
1x AtomHat
1x AtomMount
5x 5Pin
1x 4Pin
1x M2*6 Hexagon socket cup head machine screw
1x M2*8 Hexagon socket cup head machine screw
1x Hex key
Applications
Experimental circuit construction
Use with building blocks
HAT transfer
Specification
Specification
Parameter
Net weight
11g
Gross weight
22g
Product Size
AtomHAT:24*24*8mm AtomMount:24*24*8mm AtomPin:24*38*8mm
Package dimensions
50*50*21mm
Case material
Plastic ( PC )
PinMap
HAT
GND
5V
G26
G36
G0
3V3
ATOM HAT
GND
5V
G22
G33
G19
3V3
Example
Use with PIR HAT to control LED
Related Link
PcbDoc
AtomPin
Video
很抱歉,暂时无法提供与“A086”相匹配的价格&库存,您可以联系我们找货
