LAN Module with W5500
SKU: K012-B
Although M5 core is ESP32-based, having Wi-Fi and Bluetooth intergrated, it doesn't stop you
enable the Ethernet function. This LAN is a M5 Base that having a W5500 chip, which is a Hardwired
TCP/IP embedded Ethernet controller that provides easier Internet connection to embedded
systems. This Base is speciffically design for industrial application scenarioes, comes with couple of
HT3.96 connectors, 485 metal rail and magnet discs for easy installation and fixation.
Product Features
Input Supply Voltage: 9-24V
HT3.96 port for supporting RS485
Support RS485 communication
Easy to fixed on the wall
Kit includes
1x LAN Base
1x TTL-to-RS485 adapter board
1x pin header 20pin
1x metal rails and magnet discs
3x HT3.96 terminal
2x 3pin
1x 4pin
10x cold crimp terminal
3x Allen wrench - 1x 1.5mm - 1x 2mm - 1x 2.5mm
2x hexagon socket head cap screws M3x28
4x hexagon socket tapping screw KA2x4
1x countersunk head screw M3x8
Application
M5Core + LAN implemented a conveyor controller
PC transmits video to Core via cable
Datasheet - W5500
The 6 pin of HT3.96 connector are dangling, you can wired them up with the M-BUS and other circult
as you like.
The figure below shows the inner of LAN
If you need to add RS485 interface, soldering the RS485 board onto the mian board pin
correspondingly.
TTL-to-RS485 adapter board and LAN base
The figure below tells you how the TTL-to-RS485 adapter board connected onto LAN backplane
The serial port pins on the RS485 board will be connected to the GPIO16 and GPIO17 of the LAN backplane.
PinMap
W5500
W5500
ESP32 Chip
MOSI
GPIO23
MISO
GPIO19
CLK
GPIO18
CS
GPIO26
RST
GPIO13
INTn
GPIO34
M-Bus
Schematic
https://m5stack.com/collections/m5-base/products/lan-module?variant=16804778803290/12-99-19
很抱歉,暂时无法提供与“K012-B”相匹配的价格&库存,您可以联系我们找货
