K044
K044
    M5STACK
    微型 SD 连接性 M5Atom 平台评估扩展板
K044 数据手册
ATOM TF-CARD Kit SKU:K044 Description ATOM TF-CARD is an Atomic based TF-card(microSD) module.It has a self elastic TF card slot, which can support up to 16GB capacity TF cards. You can save important configuration files and user data in the program to TF card, or call these files at any time during the program operation. The use of TF card reading and writing module can greatly reduce the occupation of precious flash space by external resource files. Product Features Compatible with ATOM Matrix/ ATOM Lite Up to 16G TF card FAT/FAT32 format Self elastic TF-card (microSD) slot Include 1x ATOM TF-CARD 1x ATOM Lite 1x M2 HEX Key 1x M2*3mm Hexagon self tapping screw 1x M2*8mm Hexagon socket cup head machine screw 1x 18cm TYPE-C Cable Application Data saving File reading and writing Logging Self elastic slot Self elastic slot Specification Resources Parameter Support type 16G FAT/FAT32 MicroSD Net weight 23g Gross weight 33g Product size 24*48*18mm Package size 54*54*20mm EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: SD card read-write file test, serial output view PinMap ATOM GPIO19 GPIO23 GPIO33 ATOM TF-CARD MOSI CLK MISO Schematic Example Arduino Click here to download the Arduino example
很抱歉,暂时无法提供与“K044”相匹配的价格&库存,您可以联系我们找货
