K046
K046
    M5STACK
    A0Z1282CI,MAX232 RS232 接口 M5Atom 平台评估扩展板
K046 数据手册
ATOM RS-232 Kit SKU:K046 Description ATOM RS-232 is a TTL-RS232 level-converter designed for use with the M5Atomic module. RS232 is a full-duplex communication protocol standard, which defines the electrical characteristics of the serial communication system. It is a widely used communication protocol in the field of industrial control. MAX232 chip is integrated in the module, which supports bidirectional conversion between TTL level and RS232 level. A DC/DC voltage regulator chip is integrated in the ATOM RS-232, which can directly convert the 12V voltage of the RS232 hub to 5V to supply power for ATOM. Product Features Compatible ATOM Matrix/ATOM Lite Built-in DC/DC Full-duplex communication Include 1x ATOM RS-232 1x ATOM Lite 1x Hex Key 1x M2*8mm Hexagon socket cup head machine screw 1x 18cm TYPE-C Cable Applications RS232 Communication Industrial control node Specification Specification Parameter External port VH-3.96 4P level-conversion IC MAX232 DC-DC A0Z1282CI Net weight 26g Gross weight 36g Product Size 24*48*18mm Package Size 54*54*20mm Case Material Plastic( PC ) EasyLoader EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the main control by simple steps to perform a series of function verification. Download Windows Version Easyloader ? Download MacOS Version Easyloader Description: Send and receive the message through RS485, LED is on, press the key to send the message Related Link Datasheet MAX232 AOZ1282CI Pin Map ATOM GPIO22 GPIO19 5V GND ATOM RS-232 RX TX 5V GND Schematic Learn Roller Mill Remote Scale Display A practical use of the M5Stack Atom RS232 as part of a remote display. Example Arduino Click here to get Arduino example UIFlow Clicke here to get UIFlow example
很抱歉,暂时无法提供与“K046”相匹配的价格&库存,您可以联系我们找货
