GPS Module with Internal &
External Antenna (NEO-M8N)
SKU: M003
GPS is build with NEO-M8N, u-blox M8 concurrent GNSS modules and come with an active Antenna.
The NEO-M8 series provides high sensitivity and minimal acquisition times while maintaining low
system power.
The NEO-M8N integrates a 72-channel u-blox M8 GNSS engine that supports multiple GNSS
systems ( Beidou, Galileo, GLONASS, GPS / QZSS ) and able to receive 3 GNSS systems
simultaneously.
The series communicate protocol between M5Core and GPS is UART, physically connected
via UART2 (GPIO16, GPIO17)
If you want to Change the uart baudrate,please check here ( u-center-just-for-Windows )
*Notice: GPS signal can only be found outdoors
Product Features
Operating voltage: 2.7 ~ 3.6
Operating temperature: -40 ~ 80 °C
Antenna type: built-in ceramic antenna and external antenna
external Antenna port: SMA
Can receive data from 3 GNSS systems concurrently
Horizontal position accuracy: minimum 2.5m
GPS module (NEO-M8N) Built-in Flash, so that you can upgrade firmware via u-center-just-forWindows
Supported protocols: NMEA, UBX, RTCM
Industry leading -167dBm sensitivity
Backward compatibility with NEO‐7 and NEO‐6 series
Kit includes
1x GPS Module
1x external Antenna(cable length : 1 meter)
Application
GPS-based logistics tracking management
Driverless car positioning
Example
Arduino IDE
To the complete code GPSRaw.ino, please click here.
**Note: The GPS module needs placed outdoors to be able to receive GPS signal **
#include
/* By default, GPS is connected with M5Core through UART2 */
HardwareSerial GPSRaw(2);
void setup() {
M5.begin();
GPSRaw.begin(9600);// GPS init
Serial.println("hello");
termInit();
void loop() {
// put your main code here, to run repeatedly:
if(Serial.available()) {
int ch = Serial.read();
GPSRaw.write(ch);
if(GPSRaw.available()) {
int ch = GPSRaw.read();// read GPS information
Serial.write(ch);
termPutchar(ch);
After burnt the example code GPSRaw.ino, m5core and PC serial terminal will display following
information
Protocol Specification:
Please refer to the u-blox 8 / u-blox M8 Receiver Description - Manual, The following table is a
instruction of xxRMC message in NMEA protocol.
UART protocol: baud rate (default is 9600bps), data bit (8 bits), start bit (1 bit), stop bit (1 bit), Parity
(none)
M5Stack Fire has occupied GPIO16 / 17 to connect with the PSRAM by default, it's conflict with TXD
/ RXD (GPIO16, GPIO17) of GPS module. Therefore, when using the GPS module with the M5Stack
Fire, you might have to cut the TXD and RXD from GPS module and wire fly to another set of UART
pin, if you gonna use the PSRAM.
Schematic
https://m5stack.com/products/gps‐module/10‐2‐19
很抱歉,暂时无法提供与“M003”相匹配的价格&库存,您可以联系我们找货
