Module PROTO 13.2
SKU:M032
Description
PROTO 13.2 is a universal DIY proto module in the m5stack stack module series, with a height of 13.2mm. You can easily build your own custom
circuits by using this module. You can design and build the prototype circuit according to your own needs, and interact with the M5 Core on the
top layer through M-BUS. There are HY2.0 4P, DC power socket, VH3.96 and other common openings on the board, so it is very simple to use.
Product Features
Main Hole Size: 0.039" 1mm (CNC Drilled)
Hole Pitch: 0.1" - (2.54 mm)
Entire Hole Quantity: 169 Holes
Include
1x PROTO 13.2 board
1x M-bus
3x VH-3.96 3P Plug & Plug Base
1x HY-2.0 4P Plug Base
1x DC 5V Power outlet
4x M2*5mm Hexagon self tapping screw
1x M2 Hex Key
1x sticker
Specification
Resources
Parameter
Net weight
Resources
24g
Parameter
Gross weight
49g
Product Size
54.2*54.2*13.2mm
Package Size
93*64*20mm
MBUS PinMap
Video
LEFT
RIGHT
GND
IO35(ADC1)
GND
IO36(ADC2)
GND
EN
IO23(MOSI)
IO25(DAC0)
IO19(MISO)
IO26(DAC1)
IO18(EXT_SCK)
3V3
IO3(U1_RX)
IO1(U1_TX)
IO16(U2_RX)
IO17(U2_TX)
IO21(I2C_SDA)
IO22(I2C_SCL)
IO2
IO5
IO12(I2S_SCLK)
IO13
IO15(I2S_OUT)
IO0
HPOWR
IO34
HPOWR
5V
HPOWR
BAT
很抱歉,暂时无法提供与“M032”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+37.43777
- 5+35.59452
- 10+33.83458
