Hall effect Unit
SKU:U084
Description
Hall effect Unit integrated with three A3144E Hall sensor switches which are processed by 74HC series gate integrated circuits.
Low-level signal can be generated when the magnet S pole is close to the top of the sensor or the N pole is close to the back, and the internal LED
indicator will light up.
It is widely used in applications such as door sensor alarms, proximity sensors, rotation speed measurement and so on. The front side is the North
pole, and the low level is output when the south pole signal of the magnetic field is sensed.
Produce Future
Unipolar Hall switch sensor
Fast response and high sensitivity
Status indicator
Low-level output
Lego compatible
Include
1x Hall effect Unit
1x GROVE Cable(20cm)
1x Magnet
Application
Door sensor alarm
Magnetic field proximity sensing
Speed measurement
Specification
Specification
Parameter
Hall sensor
A3144E * 3
Logic IC
74HC08D
Status indication
RED LED
Output Level
Active Low
Net weight
4g
Gross weight
17g
Product Size
24*32*8mm
Package Size
67*52*11mm
EasyLoader
EasyLoader is a concise and fast program writer, which has a built-in case program related to the product. It can be burned to the
main control by simple steps to perform a series of function verification.
Download Windows Version Easyloader
Download MacOS Version Easyloader
Description:
The screen displays the state of magnetic induction, low-level effective
PinMap
M5Core (PORT B)
Hall effect Unit
Related Links
Datasheet
A3144E
Schematic
GPIO26
GPIO36
5V
GND
INPUT
5V
GND
Example
Arduino
Click here to download Arduino example.
UIFlow
Click here to download UIFlow example.
Last updated: 2020-12-11
很抱歉,暂时无法提供与“U084”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.38188
- 5+47.80993
- 10+44.39419
