PoECAM
SKU:U121
Description
PoECAM is an open source Fully programmable camera integrating PoE (Power Over Ethernet) . This item is ESP32 based webcam
with W5500 embedded Ethernet controller plus 200w pixel image sensor OV2640 .
PoECAM equipped with a combination of 8MB
PSRAM + 16MB Flash large memory. This teeny tiny with flexible power supply, you can get stable image by connecting the network cable in
just 2 steps. It's wonderful for you to monitor warehouse, get auto image acquisition, etc.
Plug and Play :
One step to get the IP by connecting to the network cable, You can view the images from any device in the wireless LAN.
Image data acquisition due to it's own existing software
CameraTool'/UART image transfer with PC upper computer
Abundant features :
ESP32 embedded, reserved burning interface for developing
W5500 embedded Ethernet controller supports `TCP, UDP, IPv4, ICMP, ARP, IGMP and PPPoE protocols
Exporting image data in various formats /Tuning Image Parameters
Highly flexible :
Support PoE power supply Network cable & power supply 2 in 1 , wiring simplified / Support 5V power supply
GROVE expansion interface
Camera fixed back clip for wall hanging
Product Features
Rich image processing API interface
PoE IEEE802.3 AF specification
Ethernet webcam
Built-in ESP32 MCU
Development platform:
UIFlow, Arduino, ESP-IDF
Software code / hardware open source
Include
1x PoECAM
1x Camera mount clip
1x LEGO compatible clip
Applications
Warehouse monitoring
Timed filming
Specifications
Specifications
Parameters
ESP32-D0WDQ6-V3
240MHz dual core, 600 DMIPS, 520KB SRAM, Wi-Fi, dual mode Bluetooth
Flash
16MB
PSRAM
8MB
Image Sensor
OV2640
Maximum Resolution
2MegaPixel
OV2640 supports the maximum image transmission
YUV(422/420)/YCbCr422, 8-bit compressed data, RGB565/555, 8-/10-bit Raw RGB
rate
data
DFOV
65°
PoE specification
PoE IEEE802.3 AF specification / maximum power 6W
Ethernet Controller
W5500, built-in 32Kbytes buffer area, SPI interface
Support protocols
Ethernet interface specifications
RJ45
Basic Peripherals
1x programmable buttons, 2x work indicator lights
Net weight
38g
Gross weight
45g
Product size
64 * 24 * 18mm
Packing size
80 * 37 * 32mm
Related Links
Datasheet
ESP32
OV2640
W5500
Pin mapping
OV2640 interface
接口
Camera Pin
PoE CAM
SCCB Clock
SIOC
G12
SCCB Data
SIOD
G14
System Clock
XCLK
G27
Vertical Sync
VSYNC
G22
Horizontal Reference
HREF
G26
Pixel Clock
PCLK
G21
Pixel Data Bit 0
D0
G32
Pixel Data Bit 1
D1
G35
Pixel Data Bit 2
D2
G34
Pixel Data Bit 3
D3
G5
Pixel Data Bit 4
D4
G39
Pixel Data Bit 5
D5
G18
Pixel Data Bit 6
D6
G36
Pixel Data Bit 7
D7
G19
Camera Reset
RESET
G15
Camera Power Down
PWDN
-1
Power Supply 3.3V
3V3
3V3
Ground
GND
GND
W5500 interface
W5500
PoE CAM
W5500
MOSI
PoE
CAM
G13
MISO
G38
SCLK
G23
CS
G4
EXT.PORT
PoE CAM
RX
G25
TX
G33
5V
5V
GND
GND
Button
PoE CAM
Signal
G37
Blue LED
PoE CAM
Signal
G0
EXT.PORT
Right button
**Blue LED **
Schematic
Example
Arduino
PoE CAM Firmware
Video
很抱歉,暂时无法提供与“U121”相匹配的价格&库存,您可以联系我们找货
