Me High-Power Encoder
Motor Driver
SKU: 12045 Weight: 34.90 Gram
What Is High-Power Encoder Motor Driver?
This module is the newer version of the original Me Encoder Motor Driver, which is capable of
driving two encoder motors simultaneously. The chip inside this driver integrates the PID control
algorithms which can be used to control and feed back the speed and the movement of the motors.
The internal program of this driver uses I2C and PWM for controlling, which will meet your different
needs. It comes with various pins for further development, such as SPI, I2C, UART pins. The highpower MOS interface has strong driving ability and also comes with protection system which will
prevent the circuit from burning out.
Features
? Two power slide switches for powering off the driver easily;
? The main control chip comes with a reset key;
? A 8A resettable fuse to prevent short circuits;
? Anti-reserve measurement which protects the circuit board;
? High-power MOS interface which enables up to 20A current;
Features
? Six mounting holes which allows the driver to be connected with robot cars or other structures;
? Can be controlled via RJ25 ports or pins;
? Control the location, speed and direction of the motor precisely;
? When use this driver on Makeblock mainboards, connect mainboard with the driver via the red
port;
? Enable to connect with two 36mm encoder motors at the same time.
Demo:
Specifications
SKU
12045
Product Name
Me High‐Power Encoder Motor Driver
Motor Driving Voltage
DC6‐12V
Driving Current
8A
Mainboard Voltage
DC5V
Motors
2 (Capable of driving two encoder motors at the same time)
Chip
Atmega328P
Dimension
42mm*100mm
Weight
34.9 grams
Package Content (Quantity x Part Name)
1 x Me High‐Power Encoder Motor Driver
https://store.makeblock.com/me-high-power-encoder-motor-driver/2-15-18
很抱歉,暂时无法提供与“12045”相匹配的价格&库存,您可以联系我们找货
