60123
    MAKEBLOCK(创客工场)
    SLIDE BEAM0824-496-BLUE
60123 数据手册
  Slide Beam0824-496-Blue(Singel Pack) SKU: 60123 Weight: 115.00 Gram Slide Beam0824-496 Slide Beam0824-496 is a frequently-used mechanical part of Makeblock platform,and also compatibles with most Makeblock mechanical components. There are various mounting holes and a threaded slot on the plane of this beam which allow you to assemble on other structures easily. This beam can be connected with Slider Plate to build high-precision linear motion structure. Features ? Made from heavy-duty 6061 aluminum extrusion ? With holes on 16mm increments,and M4 threaded holes on both ends ? Cross-section area 8x24mm, length 496mm ? High wear resistance and high intensity ? Strong rigidity DEMO Size Charts Specifications SKU 60123 Product Name Slide Beam0824-496-Blue(Singel Pack) Length 496mm Cross-section Area 8 x 24mm Gross Weight 115g (4.06oz) Package Content (Quantity x Part Name) 1x Slide Beam0824-496-Blue                                                https://store.makeblock.com/slide‐beam0824‐496‐blue‐singel‐pack/2‐25‐19
60123 价格&库存
很抱歉,暂时无法提供与“60123”相匹配的价格&库存,您可以联系我们找货
