80042
    MAKEBLOCK(创客工场)
    GEARMOTOR 86 RPM 9V
80042 数据手册
  Optical Encoder Motor-25 9V/86RPM SKU: 80042 Weight: 112.00 Gram What Is Optical Encoder Motor-25 9V/86RPM? In contrast to the DC motor, a photoelectric encoder is added into the encoder motor for detecting speed which is fed back to the signal input terminal for PID control to implement servo control for the motor. Features of the Encoder Motor ? Control the speed and the movement of the motor precisely; ? Real-time speed and position feedback; ? Can be connected with encoder motor driver easily by using the 6P encoder motor cable; ? Users can customize their own PID parameter by self-contained software; ? It provides overload protection. How to Use This Pack? Optical Encoder Motor-25 9V/86RPM can be connected withMe Encoder Motor Driver by using the 6P motor cable in this pack. You can control the diver through programming on the computer or connect it with Makeblock Orion mainboard via RJ25 cable.                                                    https://store.makeblock.com/optical‐encoder‐motor‐25‐9v‐86rpm/2‐25‐19
80042 价格&库存
很抱歉,暂时无法提供与“80042”相匹配的价格&库存,您可以联系我们找货
