NL1013T-02AC
NL1013T-02AC
    II-VI
    Peltier 模块 4.8W @ 27°C 1 A 85°C
NL1013T-02AC 数据手册
Technical Data Sheet for NL1013T Single-Stage Thermoelectric Module PRODUCT FEATURES • • • • • • RoHS EU Compliant Rated operating temperature of 85°C. Maximum processing temperature of 220°C. Ceramic Material: Aluminum Oxide Metallized Exterior Surfaces are Au flash, suitable for soldering. RTV Sealing options available. II-VI MARLOW www.marlow.com CONTACT US marlow.sales@ii-vi.com– Dallas, TX USA 214-340-4900 – 877-627-5691 DOC #: 102-0292 REV: N NOMINAL PERFORMANCE IN NITROGEN Hot Side Temperature (°C) Δ Tmax (°C): Qmax (watts): Imax (amps): Vmax (vdc): AC Resistance (ohms): 27 61 4.8 1.0 8.5 7.42 OPERATION CAUTIONS 50 69 5.4 1.0 9.6 ORDERING OPTIONS Model Number NL1013T-02AC NL1013T-03AC NL1013T-04AC NL1013T For maximum reliability, storage and operation below 85°C in a non-condensing environment is recommended. To minimize thermal stress, use linear/proportional temperature control or a similar method rather than an ON/OFF method. INSTALLATION Description TEM, Base Metallized Exterior TEM, No Metallized Exterior TEM, No Metallized Exterior, RTV Sealed, Special Wires Recommended mounting methods: Bonding with thermal epoxy or soldering with metallized ceramics. For additional information, please refer to our TEM Installation Guide. TYPICAL PERFORMANCE CURVES ENVIRONMENT: 10^-5 TORR VACUUM Hot Side Temperature: 27°C HEAT LOAD (WATTS) T (C) 40 20 0 8 6 4 2 0 0.0 Q=0 T=0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 1.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 60 T (C) 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 60 HEAT LOAD (WATTS) 80 40 20 0 VOLTAGE (VDC) 80 VOLTAGE (VDC) Hot Side Temperature: 50°C 8 6 4 Q=0 T=0 2 0 0.0 0.2 0.4 0.6 0.8 CURRENT (AMPS) 1.0 For performance information in a vacuum or with hot side temperatures other than 27°C or 50°C, contact one of our Applications Engineers at 877-627-5691. DOC #: 102-0292 MI Form 005-0685 Rev A REV: N 2/4 NL1013T POWER GENERATION PERFORMANCE CURVES Hot Side Temperature (°C) 70 75 85 0.5 0.025 0.4 0.02 0.3 0.015 0.2 0.01 0 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0.7 0.6 Tc=50°C 0.03 0.005 η / Opt η 80 Power 0.3 0.5 0.7 0.9 1.1 1.3 Heat (W) 1.5 1.7 Normalized Off-Peak Performance Efficiency 0 1 2 DOC #: 102-0292 MI Form 005-0685 Rev A 3 4 5 6 7 Load Resistance Ratio REV: N 8 Voltage 1.9 0.1 0 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 Voltage 0.1 0 9 10 0.1 0.09 0.08 0.07 0.06 0.05 0.04 0.03 0.02 0.01 0 30 35 40 45 50 55 65 75 85 Tc=27°C 1.2 1 0.8 0.6 0.4 Opt Voltage (V) 65 Opt Power (W) Opt Power (W) 0.035 60 Opt Voltage (V) 55 Voltage / VOC 0.04 Hot Side Temperature (°C) 0.2 Power 0.2 0.7 1.2 1.7 2.2 Heat (W) Hot Side Temperature (°C) Cold Side Temperature (°C) Optimum Efficiency, η (%) Optimum Power (W) Optimum Voltage (V) Load Resistance for Opt η (Ω) Open Circuit Voltage, VOC (V) Short Circuit Current (A) Thermal Resistance (°C/W) 85 27 2.52 0.087 1.021 12.00 1.79 0.20 16.86 Voltage 2.7 3.2 55 27 1.28 0.021 0.487 11.20 0.85 0.10 16.88 35 27 0.37 0.002 0.138 10.65 0.24 0.03 16.85 0 3/4 NL1013T MECHANICAL CHARACTERISTICS For customer support or general questions please contact a local office or visit our website at www.marlow.com. Marlow reserves the right to make product changes without notice. Power Generation performance information is given in a nitrogen environment and cold side temperatures of 27°C and 50°C. Module temperature does not include thermal resistance of heat sinks. For performance information in vacuum, other cold side temperatures, or specific heat sinks, consult one of our applications engineers. TYPICAL POWER GENERATION CONFIGURATION EXAMPLE: (-) (+) Hot Side, Th Cold Side, Tc DOC #: 102-0292 MI Form 005-0685 Rev A REV: N 4/4
NL1013T-02AC 价格&库存
很抱歉,暂时无法提供与“NL1013T-02AC”相匹配的价格&库存,您可以联系我们找货
