VT-752D-03-K
VT-752D-03-K
    MASTERAPPLIANCECO(晨星半导体)
    HEAT GUN KIT 1200F 230V EURO
VT-752D-03-K 数据手册
MASTER ® ™ MASTER HEAT GUN® MASTER VARITEMP® HEAT GUN A LA SORTIE. DU BEC OPÉRER À ‘COLD’ AVANT DE FERMER -CAUTIONHIGH TEMPERATURE AT NOZZLE. RUN ON ‘COLD’ BEFORE TURNING OFF. -ADVERTENCIAALTA TEMPERATURA EN LA BOQUILLA. ANTES DE APAGAR LA HERRAMIENTA. Instruction Manual Models HG- 502D, 502T, 302D, 302T, 202D, 202T, VT-752D Original Instructions Please read, understand and keep this manual for future reference. Traduction des instructions d'origine Veillez à lire, comprendre et conserver ce mode d'emploi pour pouvoir vous y reporter ultérieurement. Traducción de las Instrucciones originales Lea, entienda y guarde este manual para futuras consultas. Übersetzung der Originalanweisungen Bitte lesen Sie dieses Handbuch aufmerksam durch und bewahren Sie es zur späteren Zuhilfenahme auf. Assembled in USA Assemblé aux États-Unis Ensamblado en EE. UU. Montiert in den USA Important Safety Instructions Heat guns are a source of extremely high-temperature flameless heat (up to 1300˚F / 704˚C). Extreme caution should be observed when using these products. READ and FOLLOW these instructions. 230V/8A 230V/8A When using an extension cord, use only a 3-prong grounded cord rated equal to or greater than the appliance. Connect to properly grounded outlets only. Use only on properly-rated electrical circuits. Connect to properly grounded outlets only. Disconnect from power source during service and when replacing parts. If the supply cord is damaged, it must be replaced by the manufacturer, its service agent or similarly qualified persons in order to avoid a hazard. To reduce risk of fire or electric shock, do not expose heat gun to rain or moisture. Store indoors. Keep away from children and persons with reduced physical, sensory or mental capabilities or lack of experience or knowledge. Do not use near flammable materials or where fumes, gases or dust are present. Do not use in presence of explosive atmosphere. Do not direct air stream at people or pets. Keep nozzle at least 1”/2.5 cm from work surface. Do not apply to the same place for a long time. Be aware that heat may be conducted to combustible materials that are out of sight. Introduction Our Master Heat Gun® and Master Varitemp® Heat Gun feature heavy-duty, industrial quality design, with industry leading heat and airflow, that gets any job done faster. ONE YEAR LIMITED WARRANTY Master Heat Tools are carefully tested and inspected before being shipped from the factory. We warrant our product to be free from defects in materials and workmanship, under normal use and service, for one year from the date of purchase. In the event of defect in materials or workmanship we will either repair or replace, at our option, without charge any part which in our judgement shows evidence of such defect. Warranty does not apply to wearable items such as attachments, motor brushes or heating elements, which require periodic replacement, nor does it apply if the heat tool has been misused, abused, tampered with or altered. At the end of the warranty period, Master Appliance shall be under no further obligation, expressed or implied. Master Appliance assumes no responsibility for, and this warranty shall not cover, any incidental or consequential damages from any defects in products or their use. The warranty gives you specific rights. You may also have other rights which may vary from state to state. Warranty information is included within the Instruction Manual for each product or may be obtained by contacting Master’s Customer Service Department. Wear safety glasses at all times. Use in well-ventilated area. Use caution in confined areas. Do not touch nozzle until cool. Do not leave heat gun unattended when it is switched on. Always hold gun or place on its stand (see below) when in use. Recycle properly. Place heat gun on its stand (built-in or external) after use and allow it to cool down before storage. 2 Introduction & Product Warranty Master Appliance Corp. 2420 18th Street Racine, WI 53403-2381 USA 262-633-7791 800-558-9413 (USA) sales@masterappliance.com www.masterappliance.com WARNING: This product, when used for soldering and similar applications, can expose you to LEAD, which is known to the State of California to cause cancer and birth defects and other reproductive harm. For more information go to www.P65Warnings.ca.gov www.masterappliance.com www.masterappliance.com 3 1600/2600 Surface Temperature Control HG Model Heat Gun Operating instruction 1600/2600 Surface Temperature Control Heat VT Model Gun Operating instruction A LA SORTIE. A LA SORTIE. DU BEC OPÉRER À ‘COLD’ DU BEC OPÉRER À ‘COLD’ AVANT DE FERMER AVANT DE FERMER -CAUTION- -CAUTION- HIGH TEMPERATURE AT NOZZLE. RUN ON ‘COLD’ HIGH TEMPERATURE AT NOZZLE. RUN ON ‘COLD’ BEFORE TURNING OFF. BEFORE TURNING OFF. -ADVERTENCIA- -ADVERTENCIA- ALTA TEMPERATURA EN LA ALTA TEMPERATURA EN LA BOQUILLA. ANTES DE BOQUILLA. ANTES DE APAGAR LA HERRAMIENTA. APAGAR LA HERRAMIENTA. 5 4 3 2 1 9 8 7 6 FULL HEAT COOL HG Model Operating Instructions HEAT 1) Plug heat gun into properly rated outlet 1) Plug heat gun into properly rated outlet 2) For COOL temperature press the switch to the center position (I) 2) For COOL temperature press the switch to the center position (I) 3) For HEAT press the switch to the high position (II) COOL 4) For OFF, press switch to the O position OFF OFF 4 VT Model Operating Instructions www.masterappliance.com www.masterappliance.com 3) For VARIABLE HEAT press the switch to the high position (II). Rotate dial to desired temperature 4) For OFF, press switch to the O position 5 Master Heat Gun® Temperature °F °C Voltage Amps Watts Replacement Element 600 900 1300 316 482 704 230 230 230 3 6 9 690 1380 2070 30088 30086 30084 Model HG-202D/T HG-302D/T HG-502D/T Features and Specifications Master Heat Gun® Temperature Model HG-202D/T HG-302D/T HG-502D/T °F °C Voltage Amps Watts Replacement Element 600 900 1300 316 482 704 230 230 230 3 6 9 690 1380 2070 30088 30086 30084 Master Varitemp® Heat Gun Temperature Model VT-752D °F °C Voltage Amps Watts Replacement Element 1300 706 230 9 2070 30084 51542 Glass Protector Voltage A-160-HG A-170-HG Shrink Tube Amps 51543 Spreader Watts 51544 Replacement 7/8 Reducer Element 230 9 2070 30084 Attachments Master Varitemp® Heat Gun 30202 51309 Temperature Solder Pinpoint Preform Model °F °C Model VT-752D 1300 706 HG-202D/T HG-302D/T HG-502D/T VT-752D • • • • • • • • • • • • Master Heat Gun® Replacement Parts (HG/VT Models) Item No. 1 2 2 3 4 4 5 6 7 7 8 8 8 9 10 11 12 13 14 Part No. 35153 30071 30072 30074 30075 30076 30077 30078 30097 30098 30084 30086 30088 30089 30091 30092 30094 30095 30096 Description Blower wheel Stand kit (D Models) Stand kit (T Models) Motor 220-240V Switch Bezel Kit (3 pos) Switch Bezel Kit (MC) Nozzle Shield Kit Grille Kit Cordset Kit 220-240V EU -03 Cordset Kit 220-240V UK -04 Element Kit, HG-502D/ VT-752D (230V) Element Kit, HG-302D (230V) Element Kit, HG-202D (230V) Element Connector Handle Kit VT-752D (230V) VT- Knob Kit Circuit Board Kit VT-752D (230V) Housing Plastic (T Models) Grounding Kit (T Models) 12 2 10 14 REPAIR AND MAINTENANCE INSTRUCTIONS All repairs and maintenance recommended in this instruction manual must be performed by a qualified repair technician who is experienced with the repair of electric tools, a qualified service organization, or Master Appliance Corp.’s Repair Department. Please contact Master’s Customer Service Department for genuine Master Appliance replacement parts or for repair service. Master Appliance Corp. 262-633-7791 sales@masterappliance.com www.masterappliance.com 8 11 9 13 1 5 6 LD E. RTI À ‘CO SO A C DU BE ’ R ER ME ÉR FER IONAT RE UT -CA RATU LD’ PE ‘CO ON OFF. H TEMRUN ING E. RN ZZL IA- LA NO RE TU NC EN FO RTE RA DE BE VE TU LA OP T DE AN AV HIG TA. IEN -AD PERAANTES AM RR TEMILLA. HE A LA ALTBOQU R GA APA 4 7 3 WARNING: Always unplug your tool before performing any maintenance or repairs. Use only identical Master Appliance brand replacement parts. 6 www.masterappliance.com www.masterappliance.com 7 Master Appliance Corp. 2420 18th St. Racine, WI 53403-2381 USA Master Appliance Corp. 2420 18th St. Racine, WI 53403-2381 USA www.masterappliance.com Phone: 262-633-7791 Fax 262-633-9745 sales@masterappliance.com www.masterappliance.com P/N 58356 REV A
VT-752D-03-K 价格&库存
很抱歉,暂时无法提供与“VT-752D-03-K”相匹配的价格&库存,您可以联系我们找货
