PH-1615
PH-1615
    MASTERAPPLIANCECO(晨星半导体)
    HEAT GUN STC 120V 15' CORD
PH-1615 数据手册
Master ProHeat STC ® SURFACE TEMPERATURE CONTROL HEAT GUN MasterAppliance.com  n  262.633.7791 Benefits  Perfect for process control applications n  Know your work surface temperature at all times n  Fine tune and lock-in temperature and airflow settings for repeatability n  Easy to reach and maintain defined target temperatures n  Speeds up the process by allowing operator to work in the upper limits of the cure zone n  Avoid overheating or burning heat-sensitive materials n Common Applications  Regulate and maintain surface or substrate temperatures n  Cure paint, epoxy, glue, adhesive, potting compounds and powder coatings n  Reticulate adhesives over honeycomb (phenolic coated nomex or aluminum), open weave pattern or perforated aluminum as used inside airplane wings n  Heat tacking: warm composite and adhesive materials, making them “tacky” to assist with the shaping, forming and layup of composite materials n  Splicing core-fill using foaming adhesives n  Install vehicle, building, wall and furniture wraps n  Post heat vinyl wraps n  Remove surface mount and through-hole components from circuit boards without overheating adjacent components n  Pre-heat decals, surfaces and substrates n  Remove bubbles from decals n The Master ProHeat STC Series heat guns are the world’s first heat guns to have the capability to sense, display and control actual work surface temperatures. Save time and money avoiding costly re-work while your Proheat STC Series heat gun enables you to heat your work surface more accurately than ever before!  Remove decals n  Cure paint and pinstripe n  Preheat, bend and form plastic n  Reactivate dry adhesives n  Heat shrink packaging materials without over-heating or going over the temperature constraints of the film n  Many other temperature-sensitive applications n MasterAppliance.com  || 800.558.9413 10 7 3 2 1 11 9 8 6 4 5 12 13 1   BUILT-IN SURFACE TEMPERATURE SENSOR & LCD DISPLAY Senses displays and controls surface temperature. Provides real-time display of both target and surface temperatures. Know your surface temperature at all times. 2   SPEED UP THE HEATING PROCESS High temperature and airflow ratings get the job done fast. Knowing the surface temperature enables you to work in the upper limits of the cure zone. Allows you to bring surfaces up to target temperature fast. 3   LTS™ LASER TARGETING SYSTEM Unique and innovative laser targeting system provides field of view for accurate surface temperature measurement with ideal operating range of 3” to 5” from the work piece. 4   DIAL-IN VARIABLE TEMPERATURE AND AIRFLOW CONTROLS 7   STC™AUTOMATIC SURFACE TEMPERATURE CONTROL Adjusts output temperature during the heating process. More heat when you are away from the surface and less heat when you are close to the surface. Automatically regulates the heater to maintain the target surface temperature. 8   DISPLAY TEMPERATURE IN EITHER DEGREES CELSIUS OR FAHRENHEIT Easy to change Celsius or Fahrenheit temperature settings. 9   LOCKABLE MOMENTARY CONTACT SWITCH Tool operates only when switch is depressed. Switch can be locked into place for continuous duty applications or when tool is used in various positions. 10   BUILT-IN HANGING LOOP Makes it easy to hang the tool on balancers over the production area. Easy to dial in target surface temperature and desired airflow. 5   PROLOC™ SUPERVISOR LOCKING FEATURE After dialing in the temperature and airflow that is best for your application, the supervisor can lock the controls to prevent changing of temperature or airflow for repeatable process control. 6   LED PROGRESS INDICATORS Green, yellow and red LED lights indicate progress in heating process. Green – proceed, Yellow – you are close and Red – you have reached target temperature. 11   EASY GRIP CUSHIONED HANDLE Balanced, ergonomic design prevents operator fatigue. 12   3-WIRE GROUNDED CORDSET Oil resistant neoprene provides flexibility and ease of use. 13   TRADITIONAL HEAT GUN MODE Proloc key allows the user to turn off STC controls and use the heat gun in traditional nozzle sensing mode. Master ProHeat STC ® Surface Temperature Control Heat Gun PH Series ProHeat STC Heat Gun ProLoc™ Magnetic Key (included) 35542 35337 ProHeat STC Storage Case ProHeat STC Nozzle Guard NOTE:  For European shipments please specify either (A1) European or (A6) UK plug type Master ProHeat STC Heat Gun Model No. Surface Temp. Control Nozzle Temp. Control Air Velocity PH-1600 PH-1615 PH-2600 PH-2615 PH-1600K PH-1615K PH-2600K PH-2615K 90°–500°F 170°–1000°F 734–4000 FPM 90°–500°F 170°–1000°F 734–4000 FPM 40°–270°C 80°–540°C 213–1219 m/min 40°–270°C 80°–540°C 213–1219 m/min Incudes PH-1600 and 35542 Storage Case Incudes PH-1615 and 35542 Storage Case Incudes PH-2600 and 35542 Storage Case Incudes PH-2615 and 35542 Storage Case Air Volume Volts Hz Max Amps Watts Cord Length 4–16 CFM 4–16 CFM 113–453 l/min 113–453 l/min 120 120 230 230 60 60 50/60 50/60 11 11 6.8 6.8 1300 1300 1564 1564 6 Ft 16.4 Ft 1.83 M 5M Please visit www.masterappliance.com or contact Master Appliance Corp at 262-633-7791 for more information. Specifications  Motor: Permanent Magnet   Nozzle Opening: .88”I.D., 1.31” O.D. n  Cordset: 3-wire grounded n  Dimensions: 8.2” L x 3.0” W x 7.3” H n  120V Models n  230V Models n  Tool Net Weight: 1.6 lbs. n  Shipping Weight Tool: 2 lbs. 10 oz. n  Shipping Weight Kit: 3 lbs. 14 oz. n n NOTE: U sers should independently evaluate the suitability of the product for their application. For Master Appliance products contact: Master Appliance Corp.  n  2420 18th St.  n  Racine, WI 53403  n  US & Canada 800.558.9413  n  International 262.633.7791 Fax 262.633.9745  n MasterAppliance.com n  E-mail: Sales@MasterAppliance.com As with all electrical equipment and tools, for your safety, read the instruction manual before using. All information including illustrations, is believed to be reliable. Users, however, should independently evaluate the suitability of this product for their application. The only obligations of Master Appliance are those in the Standard Terms and Conditions of Sale for this product. In no case will Master Appliance be liable for any incidental indirect, or consequential damages arising from the sale, resale, use or misuse of this product. FORM# 58343 REV F
PH-1615 价格&库存
很抱歉,暂时无法提供与“PH-1615”相匹配的价格&库存,您可以联系我们找货
