AN_MASTER_001-2
AN_MASTER_001-2
    MASWELL(迈斯维)
    3.3GHz 4G,5G,LTE 面板 RF 天线 600MHz ~ 6GHz 6dBi SMA 粘接,磁吸,螺钉
AN_MASTER_001-2 数据手册
Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Mechanical dimension Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Specifications Specifications Item Antenna1 Antenna2 Mechanical Environmental Center Frequency 600-8000MHz Polarization Linear (+45°) Gain 6.9dBi (Maxium) V.S.W.R <2.0 Impendance 50Ω Isolation 15dB Center Frequency 600-8000MHz Polarization Linear (-45°) Gain 7.5dBi (Maximum) V.S.W.R <2.0 Impendance 50Ω Isolation 15dB Dimension 22cm*22cm*4.5cm Weight 1380g Cable Customizable Connector SMA or others Mounting Method U bolt /Screw Operating Temperature -40℃~+85℃ Waterproof IP67 UV stabilized: YES Vibration 10 to 55Hz with 1.5mm amplitude 2hours Environmentally Friendly ROHS Compliant Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Product Configuration in Details ◆Support all 5g, 4G, 3G, GSM and dual band WiFi bands in the world! ◆Single antenna meets all wireless protocol needs, no need to buy other antenna! ◆Up to 6dbi gain for various signal transmitting and receiving scenarios! Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured results: S11 Antenna 1 (Main) Antenna 2 (AUX) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured results: VSWR Antenna 1 (Main) Antenna 2 (AUX) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured results: Isolation Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Radiation pattern: low frequency Antenna 1 E plane H plane Antenna 2 E plane Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com H plane Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Radiation pattern: medium frequency Antenna 1 E plane H plane Antenna 2 E plane Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com H plane Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Radiation pattern: high frequency Antenna 1 E plane H plane Antenna 2 E plane Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com H plane Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured Gain Performances(Antenna 1) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured Gain Performances(Antenna 1) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured Gain Performances(Antenna 2) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Measured Gain Performances(Antenna 2) Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com Maswell 5G/4G/WiFi MIMO Panel Antenna 600-8000MHz AN_Master_001-2 Package Unit:cm AN_Master_001-2 Package with one cartoon: Cable dimension: 27cm*27cm*9cm Antenna weight: 1380g 9 27 27 Installation Guide Suzhou maswell communication technology co. Ltd Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China Http ://www.maswelltech.com E-mail:Sales@maswelltech.com
AN_MASTER_001-2 价格&库存
很抱歉,暂时无法提供与“AN_MASTER_001-2”相匹配的价格&库存,您可以联系我们找货
