Maswell 5G/4G/LTE+GNSS Panel MIMO Combo Antenna
AN_Master_001-4
Mechanical dimension
Suzhou maswell communication technology co. Ltd
Add:Floor 3, Building 6, No. 88 Zhenbei Road, High-tech District, Suzhou 215153, Jiangsu, China
Http ://www.maswelltech.com
E-mail:Sales@maswelltech.com
AN_Master_001-4
Specifications
Item
GNSS Antenna
(GPS/GLONASS/
Beidou/Gaileo)
Antenna 1 (Main)
Antenna 2 (AUX)
Mechanical
Environmental
Specifications
Dielectric Center Frequency
Antenna Polarization
Gain
V.S.W.R
Impendance
Axial Ratio
Gain
LNA
Noise Figure
Filter Insertion Loss
Supply Voltage
Current Consumption
V.S.W.R
Frequency Range
Polarization
Gain
V.S.W.R
Impendance
Isolation
Frequency Range
Polarization
Gain
V.S.W.R
Impendance
Isolation
Dimension
Weight
Cable
Connector
Mounting Method
Operating Temperature
Waterproof
UV stabilized
Vibration
Environmentally Friendly
1561.098~1602MHz
RHCP
5dBic@PCB(Zenith)
<1.5
50Ω
3dB(max)
28±2dB
≤1.5dB
<3dB
3~5V DC
<20mA
<2.0
600-8000MHz
Linear (+45°)
6.9dBi (Maximum)
<2.0
50Ω
15dB
600-8000MHz
Linear (-45°)
7.5dBi (Maximum)
<2.0
50Ω
15dB
22cm*22cm*4.5cm
1490g
Customizable
SMA or others
U bolt /Screw
-40℃~+85℃
IP67
YES
10 to 55Hz with 1.5mm amplitude 2hours
ROHS Compliant
AN_Master_001-4
Product Configuration in Details
◆GNSS antenna supports GPS, Beidou, GLONASS and Gaileo 4 satellites
L1 bands!
◆Support all 5g, 4G, 3G, GSM and dual band WiFi bands in the world!
◆Single antenna meets all wireless protocol needs, no need to buy other
antenna!
◆Up to 6dBi gain for various signal transmitting and receiving scenarios!
AN_Master_001-4
Measured results:
S11
Antenna 1 (Main)
Antenna 2 (AUX)
AN_Master_001-4
Measured results:
VSWR
Antenna 1 (Main)
Antenna 2 (AUX)
AN_Master_001-4
Measured results:
Isolation
AN_Master_001-4
Radiation pattern: low frequency
Antenna 1
E plane
H plane
Antenna 2
E plane
H plane
AN_Master_001-2
Radiation pattern: medium frequency
Antenna 1
E plane
H plane
Antenna 2
E plane
H plane
AN_Master_001-4
Radiation pattern: high frequency
Antenna 1
E plane
H plane
Antenna 2
E plane
H plane
AN_Master_001-4
Measured Gain Performances(Antenna 1)
AN_Master_001-4
AN_Master_001-4
Measured Gain Performances(Antenna 2)
AN_Master_001-4
AN_Master_001-4
Package
Unit:cm
AN_Master_001-4
Package with one cartoon:
Cable dimension: 27cm*27cm*9cm
Antenna weight: 1490g
9
27
27
Installation Guide
