3ETH9-12.0
3ETH9-12.0
    APEM(埃斐)
    顶部触动 触摸开关 SPST-NO 通孔
3ETH9-12.0 数据手册
3C/3E Technical Data: - Dimensions (Through-hole) Dimensions (SMD) 4 PCB layout Max 0.05 7.6 0.3 14.0 PCB layout 12.5 10.1 7.62 2.54 2.5 10.1 10.1 10.16 10.1 7.62 10.1 10.1 2.54 Ø=0.9 0.8 7.6±0.5 12.5 7.62 2.54 Min. 10.16 Max 12.5 PCB layout 10.16 10.1 0.8 7.6 PCB layout H= 8.0 9.5 10.4 11.0 12.0 15.0 5.1 5.1 6.4 ± 0.2 0.8 14.0 - 7.6 ± 0.5 ø 6.5 H= 8.0 9.5 10.4 11.0 12.0 15.0 1.2 0.8 Max 0.05 0.3 4 Min.10.16 Max 12.5 5.1 6.4 ± 0.2 ø 6.5 2.54 Ø=0.9 10.1 1.2 Dimensions (SMD) 7.62 Dimensions (Through-hole) VARIABLE HEIGHTS 3E 5.1 STANDARD 3C through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations life time IP67 sealing temperature range: low temp: -40/+115ºC high temp: -40/+160ºC 2.5 HOW TO ORDER 3 C Switch Mounting T through-hole S surface mount L 6 low temp. white L 9 low temp. black H 9 high temp. Standard versions: 3CTL6 3CTL9 3CTH9 3CSH9 3CSH9R ( tape/reel) - Mounting T through-hole S surface mount Standard versions: 3ETL9 3ETH9 3ESH9 3ESH9R Switch L 9 low temp. H 9 high temp. . Standard overall height 08.0 09.5 10.4 11.0 12.0 15.0 Custom heights: 3E is available in any height from 08.0 to 15.0 mm. Min. order qty. for custom heights is 2.000 pcs. / A start-up charge will apply. Ordering example: 3CTL6 and 3ETL9 - 09.5 mec . Industriparken 23 . P.o. Box 26 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . Web: www.mec.dk. . E-mail: danmec@mec.dk mec a/s jan. 2003 3 E multimec® basic switch modules Through-hole Version 3F Ø 6.5 Ø 6.5 0.8 7.6±0.5 0.8 7.6±0.5 4 0.3 Min.10.16 Max 12.5 10.4 ±0.2 6.5 6.5 10.4 ±0.2 6.5 0.8 7.6±0.5 0.5 Min.10.16 Max12.5 w/LED for 1K1116/1T/1U/1V 0.3 Min.10.16 Max12.5 0.3 12.7 ± 0.3 9.2 0.8 7.6±0.5 0.3 8.0-15.0±0.2 Ø6.5 Min.10.16 Max12.5 4 0.3 12.7 ± 0.3 Min.10.16 Max12.5 5.1 0.3 4 5.1 Min.10.16 Max12.5 6.4 ± 0.2 1U/1V/1X/1GA/1GC 4 0.3 w/LED for 1E/1F/1N/1Q/1R/1S/1X 4 For 1D/1K/1N/1P/1S/1T/ 4 6.5 4 Min.10.16 Max12.5 3E w/LED for 1C/1H 6.5 For 1A/1B/1M 3C 10.4 ± 0.2 3A 0.5 0.5 Standard Versions 3ATL6 3ATH9 * 3ATL600/20/40/80 3CTL6/3CTL9 3CTH9 3ETL9-H* 3ETH9-H* 3FTL600/20/40/80/ 2040/8020/8040 3FTL6 3FTH9 3FTL623/44/88 3E available in 6 standard heights: 08.0, 09.5, 10.4, 11.0, 12.0, 15.0 mm Other heights between 08.0 and 15.0 mm are available upon request Specials: Gold contacts, quiet version and actuation force other than 3.0N Surface Mount Versions 3A 3C Right Angle Versions 3E 3F 3C 3F 14 Ø 6.5 0.8 7.6±0.5 3ASH9/3ASH9R 7.6±0.5 3CSH9/3CSH9R 0.8 8.68 12 6 0.8 7.6±0.5 3ESH9/3ESH9R For 1A/1B/1M 7.6±0.5 3FSH9 / 3FSH9R 3CTL6RAS 3FTL6RAS For 1D/1K/1N/1P/1S/1T/ For 1D/1K/1P/1S 1U/1V/1X/1GA/1GC multimec 17.7 12 5.5 0.8 7.62 14 Ø 6.5 7.62 4.85 13.9 0.3 10.4±0.2 Max.0.05 6.5 0.3 Max. 0.05 5.1 14 Ø6.5 8.0-15.0 ± 0.2 14 0.3 Max.0.05 6.4±0.2 0.3 Max.0.05 6.5 11 Cross Section Recommended PCB layout MULTIMEC top view MULTIMEC Surface-mount solder pad MULTIMEC Right Angle Version top view 12.5 10.16 7.62 Ø1.0(3X) 2.5 2.54 • Optional LED 5.08 1.2 7.62 2.54 7.62 7.62 Ø= 0.9 Operating Force (Typical example) 4 Force (N) Circuit diagram 2 1 - 3 4 + 3 1 Travel (mm) 0 DIMENSIONS (mm) Unless otherwise specified, all tolerances ±0.2 mec 0 1 Industriparken 23 . P.o. Box 26 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s may 2003 2 multimec® technical specifications Low Temperature Versions Silver Gold Electrical Specifications Contact resistance Insulation resistance Recommended load Contact bounce Mechanical Specifications Standard actuation force (switch) Max. actuation force without cap Key travel (switch) Life time (switch) Temperature Range Working temperature Storage temperature Soldering IEC 68-2-20 10M 0.5-50mA 24VDC 10.000.000 cycles Min. -40ºC Max. +115 ºC Min. -40ºC Max. +115 ºC Wave -max. 260º C for max. 10 sec., please r efer to usage guidelines Soldering iron - max. 350 ºC for max. 3 sec. Flux tight. Environmental Endurance IEC-68-2-3 Temperature Humidity Duration Temperature Cycling IEC 68-2-14 Temperature limit Number of cycles Exposure time at each temperature Recovery time before measurements Sealing IEC 529 Cleaning Material Specifications - Switches Housing Actuator Sealing + spring Contact spring Fixed Contacts Terminals Min. -40 ºC Max. +160 ºC Min. -40 ºC Max. +160 ºC Infrared, vapour phase, wave - max. 260 ºC for max. 30 sec. Soldering iron - max. 350 ºC for max. 3 sec. Flux tight. +40 ºC 93% RH 56 Days Min. -55º C - Max. +85 ºC 200 10 min. 16 hrs. IP-67 Standard methods such as freon and water PBT UL94VO PBT UL94VO Silicone rubber Stainless steel + 3µAg SnCu + 2µNI + 3µAg SnCu + 2µNI + 3µSnPb PPS UL94VO PPS UL94VO Stainless steel + 3µAg + 1µAu SnCu + 2µNI + 3µAg+1µ Au SnCu + 2µNI + 3µSnPb Stainless steel + 3µ Ag SnCu + 2µ NI + 3µ Ag SnCu + 2µNI + 3µSnPb Stainless steel + 3µ Ag +1µAu SnCu + 2µNI + 3µAg +1µ Au SnCu + 2µNI + 3µSnPb Material Specifications - Caps & Bezels Material Parts ABS Standard Standard parts except the below mentioned Max 65ºC UL94HB Polycarbonate All lenses Max. 85ºC UL94V1 LCP PPS Polyamide Legends Adhesion Temp limit Actuator of 3E Max. 160ºC 1S, 2S Max. 160ºC Actuator of Varimec , 1GA / 1GC Max. 160ºC ISO Class.: 1/ ASTM Class.: 4B DIN EN ISO 2409 UL rating UL94VO UL94VO UL94VO mec a/s may 2003 Specifications are subject to change without notice mec Industriparken 23 . P.o. Box 26 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. Exisiting and New Part Nos. for Lead Free, RoHS compatible and Proces compatible mec products MULTIMEC Part No. Part Name Lead RoHS Proces New Part No. Lead RoHS Proces Free Comp. Comp. Comments Free Comp. Comp. UL 3ASH9 Switch Surface Ag/High Temp N N Y RA3ASH9 Y Y Y V0 3AXXXG All 3A Switches with Au N N Y RA3AXXXG Y Y Y V0 3AXXXQ All 3A Quiet Switches N N Y RA3AXXXQ Y Y Y VO 3ASH9R All 3A Switches delivered on Tape N N Y RA3ASH9R Y Y Y V0 3ATH9 Switch Th Ag/High Temp. N N Y RA3ATH9 Y Y Y V0 3ATL6 Switch Th Ag/White But/Low Temp. N N Y RA3ATL6 Y Y Y V0 3ATL6 w/LED Switch Th Ag/Low Temp w/LED N N Y RA3ATL6 w/LED Y Y Y V0 3CSH9 Switch Surface Ag/High Temp. N N Y RA3CSH9 Y Y Y V0 3CXXXG All 3C Switches with Au N N Y RA3CXXXG Y Y Y V0 3CXXXQ All 3C Quiet Switches N N Y RA3CXXXQ Y Y Y V0 3CSH9R All 3C Switches delivered on Tape N N Y RA3CSH9R Y Y Y V0 3CTH9 Switch Th Ag/High Temp N N Y RA3CTH9 Y Y Y V0 3CTL6 Switch Th/White But/Low Temp N N Y RA3CTL6 Y Y Y V0 3CTL6-2SL Switch Low Temp. 2 Straight Legs N N Y RA3CTL6-2SL Y Y Y V0 3CTL6RAS Right Angle Switch Low Temp. N N Y RA3CTL6RAS Y Y Y V0 3CTL9 Switch Th Ag/Black But/Low Temp N N Y RA3CTL9 Y Y Y V0 3ESH9 Switch Surface Ag High Temp. N N Y RA3ESH9 Y Y Y V0 3ESH9-XX.X Switch Ag/High Temp./w Actuator N N Y RA3ESH9-XX.X Y Y Y V0 3EXXXG All 3E Switches with Au N N Y RA3EXXXG Y Y Y V0 3EXXXQ All 3E Quiet Switches N N Y RA3EXXXQ Y Y Y V0 3ESH9R All 3E Switches delivered on Tape N N Y RA3ESH9R Y Y Y V0 3ETH9 Switch Th Ag High Temp. N N Y RA3ETH9 Y Y Y V0 041213 1/4 3ETH9-XX.X Switch Th Ag/High Temp. w/Actuator N N Y RA3ETH9-XX.X Y Y Y V0 3ETL9 Switch Th Ag/Low Temp. N N Y RA3ETL9 Y Y Y V0 3ETL9-XX.X Switch Th Ag/Low Temp. w/Actuator N N Y RA3ETL9-XX.X Y Y Y V0 3FSH9 Switch Surface Ag/High Temp. N N Y RA3FSH9 Y Y Y V0 3FXXXG All 3F Switches with Au N N Y RA3FXXXG Y Y Y V0 3FXXXQ All 3F Quiet Switches N N Y RA3FXXXQ Y Y Y V0 3FSH9R All 3F Switches delivered on Tape N N Y RA3FSH9R Y Y Y V0 3FTH9 Switch Th Ag/High Temp. N N Y RA3FTH9 Y Y Y V0 3FTH9 w/LED Switch Th High Temp w/ LED N N Y RA3FTH9 w/LED Y Y Y V0 3FTL6 Switch Th Ag/Low Temp. N N Y RA3FTL6 Y Y Y V0 3FTL6 w/LED Switch Th Ag/Low Temp w/LED N N Y RA3FTL6 w/LED Y Y Y V0 3FTL6-2SL Switch Low Temp. 2 Straight Legs N N Y RA3FTL6-2SL Y Y Y V0 3FTL6RAS Right Angle Switch Low Temp. N N Y RA3FTL6RAS Y Y Y V0 1CXXXX Leds for 1C or 1H Button N N N RA1CXXXX Y Y Y 2BXXXX Leds for 2B Bezel N N N RA2BXXXX Y Y Y 3FXXXXX Leds Bent for 3F N N N RA3FXXXXX Y Y Y 1AXX Dl Buttons all colours for 3A Y Y N No change, pls see note 1 HB 1BXX Dl Buttons f. Bezels all colours Y Y N No change, pls see note 1 HB 1CXXX Dl Buttons w/Lens all colours Y Y N No change, pls see note 1 HB 1DXX Lk Buttons all colours Y Y N No change, pls see note 1 HB 1EXXX Lk Buttons w/Lens all colours Y Y N No change, pls see note 1 HB 1FXXX Lk Buttons w/Lens all colours Y Y N No change, pls see note 1 HB 1GA09 Cap black 11 Y Y Y No change V0 1GC09 Cap black 15 Y Y Y No change V0 1HXXX Dl Buttons w/Lens all colours Y Y N No change, pls see note 1 HB 1KXX Lk Lid all colours Y Y N No change, pls see note 1 HB 1KXX16 Lid all colours/Lens/Reflector Y Y N No change, pls see note 1 HB 041213 2/4 1KXX1 Lens Milky White For 1K Button Y Y N No change, pls see note 1 HB 1KXXX6 Reflector For 1K Button White Y Y N No change, pls see note 1 HB 1MXX Dl Button Double Width all colours Y Y N No change, pls see note 1 HB 1NXX Teardrop Buttons all colours Y Y N No change, pls see note 1 HB 1PXX Gf Buttons all colours Y Y N No change, pls see note 1 HB 1QXXX 1P But. W/Square Hole, all colours Y Y N No change, pls see note 1 HB 1RXXX 1P Button w/Round Hole, all colours Y Y N No change, pls see note 1 HB 1S09-XX.X Lk Button Black, all heights Y Y Y No change V0 1S11-XX.X Lk Button Transparent, all heights Y Y N No change, pls see note 2 V1 1TXX Sq. Button, all colours Y Y N No change, pls see note 1 HB 1UXX Round Button, all colours Y Y N No change, pls see note 1 HB 1VXX Arrow Button, all colours Y Y N No change, pls see note 1 HB 1X XX Rectangular Button, all colours Y Y N No change, pls see note 1 HB 1ZAXX DL Button, all colours Y Y N No change, pls see note 1 HB 1ZBXX Curved Button, all colours Y Y N No change, pls see note 1 HB 1ZCXX Round Button, all colours Y Y N No change, pls see note 1 HB 3E-XX.X Actuator f. 3E Switch, all heights Y Y Y No change V0 3E-AXXXX Varimec cap 5.2 Round, all heights Y Y Y No change V0 3E-BXXXX Varimec cap 5.2 Square, all heights Y Y Y No change V0 3E-EXXXX Varimec cap 7.8 Round, all heights Y Y Y No change V0 3E-FXXXX Varimec cap 7.8 Square, all heights Y Y Y No change V0 3E-KXXXX Varimec cap 11.6 Round, all heights Y Y Y No change V0 3E-LXXXX Varimec cap 11.6 Square, all heights Y Y Y No change V0 AQB01XX Sealing Boot (incl. Sea.ring) Y Y Y No change AQB0111 Sealing Boot Trans. (incl. Sea.ring) Y Y Y No change AQC09-XX.X Cap Black, all overall heights Y Y Y No change V0 AQC11-XX.X Cap Trans. all overall heights Y Y N No change, pls see note 2 V1 041213 3/4 AQN-X.X Bushing, all heights Y Y Y No change 1CXXX Lens f. 1C/1H/1Q Buttons, all colours Y Y N No change, pls see note 2 V1 1EXXX Lens f. 1E Buttons, all colours Y Y N No change, pls see note 2 V1 1FXXX Lens f. 1F Buttons, all colours Y Y N No change, pls see note 2 V1 1RXX1 Round Transparent Lens For 1R Y Y N No change, pls see note 2 V1 2AXX Dl Bezel, all colours Y Y N No change, pls see note 1 HB 2BXXX Bezel/Lens, all colours Y Y N No change, pls see note 1 HB 2BXXX Lens f. 2B Bezel, all colours Y Y N No change, pls see note 2 V1 2KXX Lk Bezel f. 1K, all colours Y Y N No change, pls see note 1 HB 2RAS Right Angle Support. Y Y Y No change 2S09-XX.X Extender, Black Pps, all heights Y Y Y No change V0 1A09XDXXX Button 1A Down/all legends Y Y N No change, pls see note 1 HB 1A09XUXXX Button 1A Up/all legends Y Y N No change, pls see note 1 HB 1B09XDXXX Button 1b Down/0 Y Y N No change, pls see note 1 HB 1B09XUXXX Button 1B Up/all legends Y Y N No change, pls see note 1 HB 1D09XXX Round Button/all legends Y Y N No change, pls see note 1 HB 1F096XXX 1F Button/Inverse legends Y Y N No change, pls see note 1 HB 1ZB09XDXXX Button1ZB09 Down / all legends Y Y N No change, pls see note 1 HB 1ZC09XXX Button 1ZC09 / all legends Y Y N No change, pls see note 1 HB Note 1: Complies with RoHS, however plastic material limited to 65°C. Accessories must be mounted after soldering. Note 2: Complies with RoHS, however plastic material is limited to 85°C, so excessive proces heat must be avoided. 041213 041213 4/4
3ETH9-12.0 价格&库存
很抱歉,暂时无法提供与“3ETH9-12.0”相匹配的价格&库存,您可以联系我们找货
