26
multimec
3F + 1GA/1GC
Technical Data
through-hole or SMD
50mA/24VDC
single pole/momentary
10.000.000 operations life time
IP67 sealing
temperature range:
low temp: -40/+115°C
high temp: -40/+160°C
Dimensions (w/extender)
Dimensions (SMD)
Height
2Sxx.x
Dimensions (through-hole)
PCB layout
Total height (H) = 12.5+2Sxx.x
H=17.5
18.5
19.5
20.5
21.5
22.5
PCB layout
PCB layout
How to order
3 F
Switch
Mounting
T through-hole
S surface mount
L 6 low temp.
H 9 high temp.
1 G A 0 9
2 S 0 9 Extender black
Cap black
1 G C 0 9
Cap black
2S09-05.0
2S09-06.0
2S09-07.0
2S09-08.0
2S09-09.0
2S09-10.0
12.5
17.5
18.5
19.5
20.5
21.5
22.5
H1
H2
A
Foil
H1
1GA/1GC
1GA/1GC
Example
H2
Variable Extender H (height) mm
H3
Keycap
(Optional)
Adds 5-10 mm
to total height.
PCB
H3
H = Overall height
Overall heights below 12.5 mm - Please see Multimec® versions 3C and 3E.
All 2S09 extenders are stackable giving the possibility to match most overall heights.
A = We recommend you to allocate enough space for travel of the foil and leave the area free from adhesive.
Switch travel = 1 mm.
H = We recommend you to calculate this dimension from the top of the PCB to the inner top of the panel.
Ordering example: 3FTL6 + 1GA09 or 3FTL6 + 2S09-07.0 + 1GC09
For updates of products and/or changes of specifications please see www.mec.dk
mec
www.mec.dk
. 0
Height
05.0
06.0
07.0
08.0
09.0
10.0
Panel
很抱歉,暂时无法提供与“2SS09-07.0”相匹配的价格&库存,您可以联系我们找货
