1TW
1TW
    APEM(埃斐)
    PUSHBUTTON HALF BOOT BLACK
1TW 数据手册
5E /5G The Multimec 5E and 5G series is the new generation of the existing 3A, 3C, 3E, 3F, 4A and 4Fmultimec switches. The 5E and 5G series is a narrower product line, but the flexibility is more advanced. The switches will be supplied in high temperature material only to stand today’s advanced soldering processes. The cap holding system is improved, by a superior snap system. The 5E and 5G series can be supplied with LED’s integrated in the switch and also as a surface mount switch. A high variety of aesthetic designed keycaps is available for the multimec switches both as solid caps, but also with excellent illumination possibilities. The standard program will include three different actuation forces: 2, 3.5, and 6.5N. The multimec switches are known for their crisp audible tactile feel although a quiet version is available for sensitive applications such as audio, conference and military equipment. The switch can be used as through-hole or SMD versions, and are designed to be used in a wide variety of applications. Distributor: www.mec.dk multimec® 5E/5G Technical Data:  through-hole or SMD / 50mA/24VDC / single pole/momentary  10.000.000 operations life time / IP67 sealing / actuation force: 2.0, 3.5, 6.5 N  high temperature -40/+160º C 5GTH9 (through-hole) 0.8 Min 10.16 Max 12.5 0.3 7.62 Max 10.3 6.4 0.3 0.8 Min 10.16 Max 12.5 Min 10.16 Max 12.5 7.62 0.8 4 0.3 5ETH9 (through-hole) 6.4 8.5 5GTH9 (through-hole) 1+2 LED 7.62 10,16 -2 1 10.16 7,62 10.1 2 10.16 10.1 2 1 1 Max 10.3 10,16 - 2 7.62 3+ 10.1 10.1 4 7.62 Ø0,9 ø 0.9 ø 0.9 4 1 3 7,62 G R 4 3 Ø0,9 3+ 4 5GSH9 (SMD) 1+2 LEDS 14 5ESH9 (SMD) 0.8 14.0 7.62 0.3 0.8 6.4 6.4 0.3 0.3 8.5 5GSH9 (SMD) 7.62 0.8 7.62 14.0 Max 10.3 12,5 -2 1 12.5 12,5 2- 7.62 1 2.5 4 2.5 7,62 G R 1.2 1.2 1.2 Max 10.3 10.1 3+ 7.62 10.1 7,62 1,2 4 2,5 12.5 10.1 10.1 3+ 2.5 HOW TO ORDER 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Switch 5 G Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 See colour codes on our website: www.mec.dk Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2 Ordering example: 5GSH96535 mec Industriparken 23 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s dec. 2009 5 E LED 01 blue / 22 green / 42 yellow / 61 white / 82 red / 2242 green/yellow / 8222 red/green / 8242 red/yellow 1A/1H/1M/1ZA 1A/1H/1M/1ZA series caps have a hinge-type retention system which gives a rocker-action actuation when mounted on Multimec 5G switch. Illumination can be provided with 1A in transparent colours or 1H with different colour lenses. 1A/1H, 1ZA and 1M caps offer three different dimensions, many solid and transparent colours as well as lens colours. 1A has many legend options in its standard offering; however, all caps can be provided with custom legends. *Letter legends on the picture are not standard Distributor: www.mec.dk multimec® 5G + 1A/1H/1M/1ZA Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+65°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N +3 12,5 8 - 10 12,2 8 - 10 12,2 10,1 4 18,65 3 7,62 10,1 4 2 1 3 Ø 0,9 Ø 0,9 4 25,0 1 1,2 2,5 2 1 7,62 10,1 1,2 10,1 7,62 4 12,50 10,16 2 12,50 PCB layout PCB layout 10,16 1 7,62 7,62 PCB layout 12,50 -2 Min. 10,16 Max. 12,5 7,62 PCB layout 0,8 14,0 7,62 Min. 10,16 Max. 12,5 0,8 0,3 0,8 7,62 Dimensions (SMD) 1M 0,3 0,3 0,8 14,0 Dimensions (through-hole) 1ZA 8 - 10 12,2 Dimensions (TH w/LED) 1H 8 - 10 0,3 12,2 Dimensions (SMD w/LED) 1A 2,5 3 HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q** LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap 1H 1A Colour code 00 blue 06 02 green 08 03 grey 09 04 yellow 1H white red black Lens 1H 1 transparent 2 green 4 yellow 6 frosted white 8 red Colour code 1A 10 frosted blue 16 frosted white 12 frosted green 18 frosted red 14 frosted yellow HOW TO ORDER non-illuminated + Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q** Cap **Quiet version is only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. 1A 1ZA 1M Colour code 30*ultra blue 00 blue 40*dusty blue 02 green 42*aqua blue 03*grey 32 mint green 04 yellow 33 tele grey 06*white 34 melon 08 red 38 noble red 09*black 50*metal dark blue 53*metal light grey 57*metal dark grey 58 metal bordeaux * Colours for 1ZA Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 Ordering example: 5GSH93582 + 1H068 with illumination 5GTH965 + 1ZA57 without illumination **5GTH92001Q with illumination or 5GSH920Q (quiet version) For updates of products and/or changes of specifications please see www.mec.dk See colour codes on our website: www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S September 2011 5 G 1B/1C+2C/2D 1B/1C cap and 2C/2D bezel series have a award-winning design. The cap is connected to the bezel with a hinge-type retention system and the bezel snaps on to the switch. The series provides many design options with its solid and transparent colour range as well as different illumination option. Illumination can be achieved by using 1B cap in transparent colour, 1C cap with a lens or 2D bezel with a lens where LED is placed on the PCB. Distributor: www.mec.dk multimec® 5G + 1B/1C + 2C/2D Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+65°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N 12,2 Dimensions (SMD w/LED) 1B+2D -2 4 7,62 9,5 7,62 3 Ø 0,9 3 Ø 0,9 12,6 1 1 15,1 2 15,1 4 12,6 12,5 10,16 1 7,62 9,5 15,1 1,2 7,62 9,5 3,81 15,1 10,16 2 15,1 PCB layout 15,1 12,5 7,62 PCB layout 15,1 2,5 0,8 14,0 7,62 PCB layout PCB layout 15,1 12,6 0,8 Min. 10,16 Max. 12,5 7,62 3,81 Min. 10,16 Max. 12,5 4 1,2 0,3 0,8 0,3 7,62 0,3 0,8 14,0 9,5 0,3 8 8 12,2 Dimensions (TH w/LED) 1C+2C 8 8 12,2 Dimensions (through-hole) 1B+2C 12,2 Dimensions (SMD) 1B+2D +3 2,5 12,6 HOW TO ORDER illuminated 5 G Switch 1 C Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* LED 01 blue + 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow 2 C Cap solid colour Bezel Colour Lens code Colour code + 1 B 2 D Bezel Cap Colour code transparent Colour Lens code HOW TO ORDER non-illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* 1 B Cap solid colour + Colour code or 2 C Bezel Colour code 2 D Bezel Colour Lens code *Quiet version only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the orde- Solid caps 00 blue 06 white 02 green 08 red 03 grey 09 black 04 yellow For 1B and 2C only: 30 ultra blue 33 tele grey 40 dusty blue 34 melon 42 aqua blue 38 noble red 32 mint green Ordering example: 5GTH93561+1C001+2C09 with illumination 5GSH954+1B08+2D081 without illumination **5GSH92001Q or 5GTH920Q (quiet version) For updates of products and/or changes of specifications please see www.mec.dk 50 53 57 58 metal dark blue metal light grey metal dark grey metal bordeaux Lenses 1 transparent 2 green 4 yellow 6 frosted white 8 red Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 See colour codes on our website: www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S September 2011 COLOUR CODES Transparent caps 10 frosted blue 16 frosted white 11 transparent 18 frosted red 12 frosted green 14 frosted yellow 1DS /1ES /1FS The new caps for the Multimec switches 1DS / 1ES / 1FS is optimized with a “snap on” system to ensure the cap to stay on the switch actuator even under heavy vibrations or similar scenarios. - - The 1DS cap is a solid cap which can be supplied in different colours The 1ES cap is a solid cap like 1DS, but with a small round lens for intensive or smooth illumination The 1FS cap is a solid cap like 1DS, but with a large round lens for intensive or smooth illumination Distributor: www.mec.dk multimec® 5G + 1DS/1ES/1FS Technical Data  through-hole or SMD  50mA/24VDC  single pole/momentary  10.000.000 operations life time  IP67 sealing  temperature range: LED:-40/+85°C solid cap +65°C transparent +85°C  actuation force: 2.0, 3.5, 6.5 N 0.8 Min 10.16 Max 12.5 7.62 0.3 14.9 8.2 0.8 0.8 7.62 PCB layout PCB layout 10.16 12.5 1 -2 1 7,62 7.62 10.1 PCB layout 10,16 4 +3 10.3 1.2 ø 0.9 4 10.1 7.62 -2 7.62 14.0 10.1 0.3 ø 11.0 ø 9.6 0.8 14.9 8.2 0.8 14.9 Min 10.16 Max 12.5 ø 11.0 ø 9.6 8.2 ø 11.0 ø 9.6 Dimensions (SMD) Dimensions (w. LED) 0.8 Dimensions (through-hole) +3 Ø0,9 10.1 2.5 HOW TO ORDER 5 G Switch Mounting TH9 through -hole SH9 surface mount Actuation force 20 35 65 LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap 1ES with lens 1FS with lens Colour code 00 blue 03 grey 08 red 09 black Lens 1 transparent 6 frosted white 1DS 11 transparent 16 frosted white Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Cap 1DS solid colour Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2 Ordering example: 5GTH935 + 1DS08 mec See colour codes on our website: www.mec.dk Industriparken 23 .DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s dec. 2009 5 G 1GAS/1GCS The 1GAS/1GCS caps are optimised for use with foil overlays. Compared to conventional membrane panels it provides an extremely rugged and a long-term cost-effective solution with increased reliability, enhanced product life and improved tactile feel. The new caps have 9 standard colour options: blue, green, grey, yellow, white, red, black, transparent and frosted white. Even more, the under part of the new cap series has been cleared, so the caps in transparent and frosted white can provide excellent illumination. When used with the 2SS variable height extender, the 1GAS/1GCS caps can be to any required operating height between 17.5-22.5mm. Distributor: www.mec.dk multimec® 5G + 1GAS/1GCS Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+160°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N Dimensions (SMD w/LED) + 1GAS P11 7,62 0,8 14,0 PCB layout 12,50 10,16 3 7,62 10,3 1,2 7,62 2,5 2 1 4 2,5 10,16 1 4 +3 7,62 PCB layout 2 7,62 -2 1 1,2 12,50 2 7,62 PCB layout 10,3 0,8 Min. 10,16 Max. 12,5 1 7,62 PCB layout 10,1 0,3 0,8 0,3 7,62 Min. 10,16 Max. 12,5 10,1 4 12,5 12,5 0,8 14,0 P15 P15 12,5 0,3 0,3 12,5 P11 Dimensions (TH w/LED) + 1GCS Dimensions (through-hole) + 1GCS 12,5 Dimensions (SMD) + 1GAS 3 4 3 Ø 0,9 Ø 0,9 HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap transparent colour 1GAS Colour code 11 transparent 16 frosted white 1GCS HOW TO ORDER non-illuminated + Switch Mounting TH9 through-hole SH9 surface mount Cap solid colour Actuation force 20 35 65 Q* *Only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. 1GAS 1GCS Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 Ordering example: 5GSH935 + 1GAS09 without illumination 5GTH96501 + 1GCS16 with illumination *5GSH920Q or 5GTH92061Q (quiet version) See colour codes on our website: www.mec.dk For updates of products and/or changes of specifications please see www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk MEC A/S May 2012 5 G 1JS MEC’s exclusive snap-on keycap in 10.4 mm total height. Optimized for use with foil overlays. The 1JS keycaps are available in nine standard colours: 00 blue/02 green/03 grey/04 yellow/06 white/08 red/09 black/11 transparent/16 frosted white. In combination with the switch the 1JS becomes the lowest illuminated keycap possible; especially designed for foil overlays and featuring soft edges for extended foil overlay lifetime. The 1JS 11 transparent/16 frosted white has superior illumination potential when combined with the newest Multimec 5G switch. The switch can be either surface mount or throughhole. Cap retention is optimized with an innovative “snap-on” system. Distributor: www.mec.dk multimec® 5G + 1JS Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temperature range: LED: -30/+85°C solid cap: +65°C transparent: +85°C „ actuation force: 2.0, 3.5, 6.5 N 12,50 2,4 2 7,62 10,4 10,4 0,7 2,4 2 0,3 Min. 10,16 Max. 12,5 PCB Layout SMD Dimensions (SMD w/LED) R 0,7 R 14,0 0,8 1,20 Dimensions (through-hole) 7,62 2,50 7,62 PCB Layout TH 10,16 1,2 7,62 7,62 P9,6 0,8 Max 10,0 P9,6 10,0 12,50 Max 10,0 10,0 2,5 HOW TO ORDER Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 5 G Switch Mounting TH9 through-hole SH9 surface mount 1 J S LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green Cap 1JS transparent + 1 J S Actuation force 20 35 65 Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 Ordering example: 5GTH935+1JS08 without illumination Cap 1JS solid colour Colour code 11 transparent 16 frosted white Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black See colour codes on our website: www.mec.dk 5GTH93501+1JS16 with illumination For product updates and/or changes of specifications please see www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S Feb 2011 + 5 G 1KS/KBS/KCS The 1KS series is square caps with measurements of 14.3 x 14.3 mm and can be used with the 2K bezel, which snaps into the front panel, or alone without the bezel. The 1KS is with a flat top, the 1KBS with a convex top and 1KCS with a concave top. All three versions are designed for illumination with a nice distribution of the illumination to the whole cap surface. The caps also offer the designer the option of using interchangeable legends or standard printed graphics. A legend can be printed on the top lid surface or a foil with the legend is placed between the transparent lid and the lens. When used with the 2SS variable height extender, the 1KS/1KBS/1KCS caps can be to any required operating height between 24.1-29.1mm. Distributor: www.mec.dk multimec® 5G + 1KS/1KBS/1KCS Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+65°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N Dimensions (SMD w/LED) + 1KCS 0,8 14,3 -2 4 3 17,75 4 Ø 0,9 14,3 14,3 1 1,2 3 1 7,62 14,3 1,2 7,62 2,5 12,50 2 7,62 1 14,6 PCB layout 10,16 2 2,1 7,62 PCB layout 12,50 14,6 0,8 14,0 7,62 PCB layout 14,3 20,1 0,3 0,3 16,4 11,6 11,6 7,62 Min. 10,16 Max. 12,5 4 19,1 20,2 19,1 11,6 19,1 0,3 0,8 14,0 R25 Dimensions (Bezel) (optional) 17,75 Dimensions (TH w/LED) + 1KBS R18,7 5 Dimensions (SMD) + 1KS 2,5 +3 14,3 HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* 1 1 1 6 LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap frosted white lens and transparent lid + 1 K S + 2 K Bezel 03 grey 06 white 08 red 09 black 1KS 1KBS 1KCS HOW TO ORDER non-illuminated Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* *Quiet version only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. Ordering example: 5GTH93501+1KCS1116+2K09 with illumination 5GSH965+1KS09+2K03 without illumination *5GTH92082Q or 5GSH920Q (quiet version) For updates of products and/or changes of specifications please see www.mec.dk Cap 1KS 1 6 Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black + 2 K Bezel 03 grey 06 white 08 red 09 black See colour codes on our website: www.mec.dk Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S October 2011 5 G 1PS /1QS /1RS The new caps for the Multimec switches 1PS / 1QS / 1RS is optimized with a “snap on” system to ensure the cap to stay on the switch actuator even under heavy vibrations or similar scenarios. - The 1PS cap is a solid cap which can be supplied in different colours - The 1QS cap is a solid cap like 1PS, but with a rectangular lens for intensive or smooth illumination - The 1RS cap is a solid cap like 1PS, but with a round lens for intensive or smooth illumination Distributor: www.mec.dk multimec® 5E/5G + 1PS/1QS/1RS Technical Data  through-hole or SMD  50mA/24VDC  single pole/momentary  10.000.000 operations life time  IP67 sealing  temperature range: LED:-40/+85°C solid cap +65°C transparent +85°C  actuation force: 2.0, 3.5, 6.5 N 6.5 Max 12.5 Min 10.16 Max 12.5 7.62 Min 10.16 Max 12.5 Dimensions (SMD) Max 12.5 6.5 0.3 0.8 0.3 0.8 0.3 6.5 10.4 10.4 15.7 10.4 15.7 Max 12.5 Dimensions (w/LED) 15.7 Dimensions (through-hole) 0.8 7.62 7.62 PCB layout 12.5 1 10.3 -2 7.62 Max 10.1 10,16 1 1RS ø 0.9 4 7.62 10.3 -2 1.2 10.16 PCB layout 10.1 1QS PCB layout Max 10.1 10.3 10.1 +3 2.5 4 +3 10.3 Ø0,9 HOW TO ORDER 5 G Switch Mounting TH9 through -hole SH9 surface mount Actuation force 20 35 65 LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap 1QS with lens 1RS with lens Colour code 00 blue 03 grey 08 red 09 black Lens 1 transparent 6 frosted white 1PS 11 transparent 16 frosted white 5 E 5 G Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2 Ordering example: 5ETH935+1PS08 mec Cap 1PS solid colour Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black See colour codes on our website: www.mec.dk Industriparken 23 . P.o. Box 26 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s dec. 2009 Switch to be used: 5E or 5G 1SS/1LS/1IS The new caps for the Multimec switches 1SS/1LS/1IS are optimised with a “snap-on” system to ensure the cap to stay on the switch actuator even under heavy vibrations or similar scenarios. - The 1SS cap is solid cap which can be supplied in different colours - The 1LS cap is a solid cap like 1SS, but with a small round lens for intensive or smooth illumination - The 1IS cap is a transparent or frosted white cap like 1SS, for intensive or smooth illumination Distributor: www.mec.dk multimec® 5E/5G + 1SS/1LS/1IS Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+160°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N Dimensions (SMD w/LED) + 1IS Dimensions (TH w/LED) + 1LS 10,16 10,3 10,3 4 0,8 2,5 P3 3 12,50 -2 1 7,62 10,3 4 1,2 0,8 2 1 PCB layout 10,3 3 Ø 0,9 1 4 1,2 PCB layout 12,50 7,62 10,1 0,3 PCB layout 2 7,62 14 7,62 Min 10,16 Max 12,5 10,1 6,4 12,0 - 22,5 8,0 - 22,5 0,3 0,8 0,3 7,62 14 10,4 - 22,5 P6,5 P6,5 P6,5 7,62 Dimensions (SMD) + 1SS 2,5 +3 HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* . Cap Colour code 1LS with lens 00 blue 03 grey 08 red 09 black 1IS 11 transparent transparent 16 frosted white LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Lens 1 transparent 2 green 4 yellow 6 frosted white 8 red Height/1LS 12.0 19.0 15.0 22.5 16.0 Height/1IS 10.4 16.0 11.0 19.0 12.0 22.5 15.0 HOW TO ORDER non-illuminated + 5 G Mounting Switch TH9 through-hole SH9 surface mount . Actuation force 20 35 65 Q* *Only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. Cap 1SS solid colour Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black Height 16.0 08.0 19.0 09.5 22.5 10.4 11.0 12.0 15.0 Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 Ordering example: 5ETH920+1SS0409.5 without illumination 5GSH93542+1IS1619.0 with illumination *5ESH920Q or 5GTH9208222Q (quiet version) See colour codes on our website: www.mec.dk For updates of products and/or changes of specifications please see www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk MEC A/S February 2012 5 E Panel sealed 1TS/1US/1VS The sealings 1TW/1UW/1VW provide an opportunity of having the 1TS/1US/1VS caps with panel sealing. Level of sealing from front panel: 5G+1TS+1TW = IP67 5G+1US+1UW = IP67 5G+1VS+1VW = IP65 The solution is excellent for rough environment, designed for outdoor, dusty and humid applications. Distributor: www.mec.dk multimec® 5G+1TS/1US/1VS+1TW/1UW/1VW 5G+1TS/1US/1VS+1TW/1UW/1V Technical Data: „ „ „ „ „ „ through-hole or surface mount 50mA/24VDC single pole/momentary 10.000.000 operations lifetime Switch: IP67 sealing temp. range: switch:-40/+160°C LED: -30/+85°C solid keycap: -40/+65°C transparent keycap: -40/+85°C „ actuation force: 2.0, 3.5, 6.5 N Dimensions (TH w/LED) 1US+1UW Dimensions (SMD w/LED) 1VS+1VW Recommended 5,3 panel cut-out PCB layout 14,9 8,2 11 12,50 10,16 7,62 13,25 4 +3 4 12,0 14,65 2,5 Distance between PCB and front panel 3 P22,0 4 P17,5 11 11 11 P21,0 1 Ø 0,9 4 P 13,65 2 10,8 B0,1 3 1 1,2 4 -2 7,62 1 10,4 2 7,62 12,0 10,6 5,5 PCB layout Ø10,6 4 7,62 PCB layout 10,16 10,6 12,0 0,8 14 7,62 Min. 10,16 Max 12,5 1TS - 11x11mm 1US - Ø11mm 1VS 6,7 0,8 0,3 7,62 0,3 0,8 11,8 0,3 Min. 10,16 Max 12,5 0,8 14,9 8,2 0,8 8,2 0,8 14,9 6,7 6,7 Dimensions (TH) 1TS+1TW HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow + Cap 1TS Colour code 16 frosted white Sealing 1TW 1US 1UW 1VS 1VW HOW TO ORDER non-illuminated + Switch Mounting TH9 through-hole SH9 surface mount + Cap 1TS 1US 1VS Actuation force 20 35 65 Q* *Only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. Colour code 00 blue 03 grey 08 red 09 black Sealing 1TW 1UW 1VW Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 Ordering example: 5GSH935 + 1TS03 + 1TW without illumination 5GTH96542 + 1US16 + 1UW with illumination *5GSH920Q or 5GTH92082Q (quiet version) See colour codes on our website: www.mec.dk For updates of products and/or changes of specifications please see www.mec.dk MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S November 2011 5 G 1ZW “with panel seal” Controlmec TM is a five position integrated switch solution, designed for outdoor, dusty and humid applications, to control a unit, navigate in a display, operate auxiliary equipment on a vehicle, boat or similar. The Controlmec is sealed to IP67, and exist of: - One complete solid cap, with recess on the back site for the seal efficiency - The unit panel plate (customers design) - A gasket to seal between the cap, and the panel. - A support ring to ensure the right position of sealing behind the front plate - And then the PCB including the switches The PCB with the switches, shall be assembled according to the MEC datasheet, and mounted to the back side of the front panel by bolts, to ensure the right pressure for the sealing efficiency. The Controlmec is an extension of the Navimec system which includes the Multimec switches, of excellent high quality and long lifetime. Configurations can be made with through hole or SMD switch versions, provided they are accurately positioned. Distributor: www.mec.dk controlmec® 1ZW “sealed” Technical Data  through-hole or SMD  50mA/24VDC  single pole/momentary  10.000.000 operations life time  IP67 sealing  temperature range: LED:-40/+85°C solid cap +65°C transparent +85°C  actuation force: 2.0, 3.5, 6.5 N Dimensions 1ZW Mounting example 1ZW _ 0.20 2.0 + _ 0.05 with panel seal 6.9 + Hole in front plate ø 30,3 +- 0,1 1 ZZ Seal 41.4 5.1 29.5 1ZY Seal support 1 pcs. 5GTH920 (+LEDs) 4 pcs. 5ETH935 Recommented PCB layout PCB 7.62 25.4 10.16 ø 0.9 25.4 Panel seal HOW TO ORDER 5 G Switch Mounting TH9 through -hole SH9 surface mount Actuation force 20 35 65 LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap for seal 1ZW Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black 11 transparent 16 frosted white Seal 1ZZ Seal support 1ZY Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 See colour codes on our website: www.mec.dk Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2 Ordering example (sealed version) 1ZW: 1 x 5GTH920 + 4 x 5ETH935 + 1ZW03 + 1ZZ + 1ZY mec Industriparken 23 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s dec. 2009 5 E 1Z “without panel seal” Controlmec TM is a five position integrated switch solution, designed for easy activations for indoor and non-dusty applications, to control a unit, navigate in a display, operate auxiliary equipment indoor on a vehicle, boat or similar. The Controlmec can also be supplied as an IP67 sealed solution. The Controlmec exist of: - One complete solid cap The unit panel plate (customers design) The PCB including the switches The PCB with the switches, shall be assembled according to the MEC datasheet, and mounted to the back side of the front panel. The Controlmec is an extension of the Navimec system which includes the Multimec switches, of excellent high quality and long lifetime. Configurations can be made with through hole or SMD switch versions, provided they are accurately positioned. Distributor: www.mec.dk controlmec® 1Z “without sealing” Technical Data  through-hole or SMD  50mA/24VDC  single pole/momentary  10.000.000 operations life time  IP67 sealing  temperature range: LED:-40/+85°C solid cap +65°C transparent +85°C  actuation force: 2.0, 3.5, 6.5 N 29.5 _ 0.10 7.2 + Recommented PCB layout 5.1 _ 0.20 2.0 + Dimensions 1Z 1Z 7.62 25.4 11.85 10.16 ø 0.9 10.16 7.6 25.4 Hole in Front Plate ø 30.3 +- 0.1 4 pcs. 5ETH935 35.4 25.4 1 pcs. 5GTH920 (+LEDs) 25.4 35.4 HOW TO ORDER 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow Cap 1Z Colour code 00 blue 02 green 03 grey 04 yellow 06 white 08 red 09 black 11 transparent 16 frosted white Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 See colour codes on our website: www.mec.dk Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2 Ordering example (unsealed version)1Z: 1 x 5GTH920 + 4 x 5ETH935 + 1Z03 mec Industriparken 23 . DK-2750 Ballerup . Denmark Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk. mec a/s dec. 2009 5 E Navimec Navimec Module Technical Data: standard and illuminated „ module should be attached to the front plate with bolts (bolts not supplied by MEC) „ 50mA/24VDC „ single pole/momentary „ 10.000.000 operations lifetime „ switches sealed to IP67 „ temperature range: switch body:-40/+160°C LED: -30/+85°C „ actuation force: 2.0, 3.5, 6.5 N Dimensions illuminated Navimec module Ø3,2 (x4) PCB 1,5 8-10 mm 40 32 Recommended panel cut-out: ø = 35,0 - 35,5 Depending on application PCB layout for Navimec solution Ø3,2 (x4) PCB 1,5 SMD 20 25,00 4,7 9,6 (incl. housing) 25,00 33 46 33 50 Ø34,25 TH 25,00 7 25,00 40 32 3,5 8-10 mm 20 3,5 Dimensions Standard Navimec module 4,6 Ø34,25 *When the 1ZB is activated the diameter changes from 34,25mm to 35,0mm HOW TO ORDER Navimec Module ordering options: • Navimec Module excl. keycaps • Navimec Module incl. keycaps • Navimec Module incl. keycaps with legends • illuminated Navimec Module excl. keycaps • illuminated Navimec Module incl. keycaps with legends Circuit diagram Navimec module illuminated CON20 SW3 17 19 SW4 SW2 SW1 3 2 1 4 3 2 1 4 3 2 1 4 20 18 Part no. for switches and caps: Navimec Module has many customisation options regarding actuation force, cap and LED colours and legends. Because of that ordering is based on part numbers of separate parts instead of one specific part number. MEC has the switches mounted on the module before delivery, which is included in the module price. See the other side for information on switch and cap options as well as the examples below. SW4-1 16 SW5 14 13 Part no. 9810120 - PCB and connector for Navimec Module Part no. 9810125 - PCB and connector for illuminated Navimec Module SW4-2 15 SW3-2 SW3-1 10 Standard 12 1 11 2 9 SW4 10 9 8 7 6 5 4 3 2 1 SW5-2 SW5-1 8 1 6 2 7 1 2 1 2 2 4 3 2 1 4 SW2-2 SW2-1 4 SW5 2 1 3 SW2 1 3 1 5 SW3 SW1-2 SW1-1 J1 2 SW1 For example: 9810120 + 4x 5GTH920 + 1x 5GTH920 (without caps) 9810120 + 4x 5GTH965+1ZB42 + 1x 5GTH965+1ZCS42 (with caps) 9810125 + 4x 5GTH93501+1ZB16LM136 + 1x 5GTH93501 +1ZCS16LM118 (painted caps with laser engraved legends) The connector on the standard Navimec module is JST SMT S108-PH-SM3-TB or similar. We recommend using: Cable socket: JST PHR-10 or similar Contact: JST SPH-002T-P0.5S or similar The connector on the illuminated Navimec module is CI1120M1H or similar. We recommend using: Cable socket: Cvilux CI1120S0000 or similar Contact: Cvilux CI11T011PP0 or similar Distributor: www.mec.dk multimec® 5G + 1ZB/1ZCS Technical Data: „ „ „ „ „ „ through-hole or SMD 50mA/24VDC single pole/momentary 10.000.000 operations lifetime IP67 sealing temperature range: switch body:-40/+160°C LED: -30/+85°C „ actuation force: 2.0, 3.5, 6.5 N PCB layout bicolour SMD PCB layout SMD Dimensions (SMD w/LED) + 1ZCS R1 1,5 12,50 Min 10,16 Max 12,5 7,62 90° PCB layout PCB layout -2 1 7,62 3 4 +3 3 10,16 2 Ø14,3 4 1 -2 1 4 +3 7,62 7,62 2,5 PCB layout bicolour TH 10,16 1 7,62 4 2,5 PCB layout TH w/LED 12,50 1,2 R=7,4 1 2,50 7,62 R=17,5 (actuated) 4 7,62 10,16 2 1,2 0,8 14 -2 1 7,62 0,3 8 8 11,7 1,8 12,2 0,8 0,3 12,50 2 1,20 Dimensions (through-hole) + 1ZB +3 4 Ø09 3 Ø 0,9 Ø 0,9 HOW TO ORDER illuminated + 5 G Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* LED 01 blue 22 green 42 yellow 61 white 82 red 2242 green/yellow 8222 red/green 8242 red/yellow 1 Z B 1 6 L M Cap frosted white with black soft touch paint and laser marking Legend code 136 1 Z C S 1 6 L M Legend code 118 OK 123 Cap HOW TO ORDER non-illuminated Switch Mounting TH9 through-hole SH9 surface mount Actuation force 20 35 65 Q* 1 Z B Cap 1 Z C S Cap *Quiet version only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the ordering example. Ordering example: 4x 5GTH93561+1ZB16LM136 + 1x 5GTH93561+1ZCS16LM118 (with illumination) 4x 5GSH920+1ZB09 + 1x 5GSH920+1ZCS09 (without illumination) Colour code 02 green 03 grey 06 white 08 red 09 black 30 ultra blue 40 dusty blue 42 aqua blue 50 metal dark blue 53 metal light grey 57 metal dark grey 58 metal bordeaux Legend code** 136 Legend code** 038 RESET 105 ENTER 118 OK 119 SET 120 MENU 121 FUNC 122 HOME 123 *5GTH92001Q or 5GSH920Q (quiet version) ** White legends on black caps are standard, other options are available but considered custom products. For product updates and further information see our website: www.mec.dk Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2 MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk. MEC A/S July 2011 + 5 G
很抱歉,暂时无法提供与“1TW”相匹配的价格&库存,您可以联系我们找货
