MMC56xxNJX-B User Guide
MMC56xxNJX-B
GENERAL DESCRIPTION
The MMC56xxNJX-B provides a convenient and easy way
to evaluate and prototype with the MMC56xxNJX three axes
magnetic sensor. The magnetic sensor and passive
components needed for operations are SMT mounted on the
board. Communication, power and ground pins of the
MMC56xxNJX SMT device are brought out to standard
0.10 inch on center connections on the sides of the
prototyping board. Wires can either be soldered directly to
the prototyping board or DIP pins can be used with widely
available breadboard kits.
For complete performance specifications of
MMC56xxNJX refer to MMC56xxNJX datasheet.
MMC56xxNJX-B
PIN DESCRIPTION
Pin
P1-1
P1-2
P1-3
P2-1
P2-2
P2-3
Name
VDDIO
VDD3V
GND
SDA
SCL
NC
Description
I2C Supply Voltage
Power
Ground
I2C SDA
I2C SCL
NOT CONNECTED
PCB OUTLINE AND CONNECTION DIMENSIONS
SCHEMATIC OF THE MMC56xxNJX-B
MMC56xxNJX-B
MMC56xxNJX-B
Information furnished by MEMSIC is believed to be accurate and reliable.
However, no responsibility is assumed by MEMSIC for its use, nor for any
infringements of patents or other rights of third parties, which may result from
its use. No license is granted by implication or otherwise under any patent or
patent rights of MEMSIC.
MEMSIC MMC56xxNJX-B User's Guide
MEMSIC Semiconductor (Wuxi) Co., Ltd.
No.2 Xinhuihuan Road, Xinwu District, Wuxi, Jiangsu, China
Tel: +86-510-66616668
Fax: +86-510-66616669
www.memsic.com
Page 1of 1
Rev B
很抱歉,暂时无法提供与“MMC5633NJL-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+179.518701+21.70730
- 5+176.743205+21.37170
