MMC5983MA-B
MMC5983MA-B
    MEMSIC(美新)
    MMC5983 - 磁性,磁力计 评估板 - 传感器
MMC5983MA-B 数据手册
MMC5983-B Prototyping Board MMC5983 -B re vi ew GENERAL DESCRIPTION The MMC5983-B provides a convenient and easy way to evaluate and prototype with MMC5983 the three axes magnetic sensor. The magnetic sensor and passive components needed for operations are SMT mounted on the board. Communication, power and ground pins of the MMC5983 SMT device are brought out to standard 0.10 inch on center connections on the sides of the prototyping board. Wires can either be soldered directly to the prototyping board or DIP pins can be used with widely available breadboard kits. For complete performance specifications of MMC5983 refer to MMC5983 datasheet. Description SPI CS NOT CONNECTED Power Ground SPI SDO I2C SDA / SPI SDI I2C SCL / SPI SCK Interrupt Output PCB OUTLINE AND CONNECTION DIMENSIONS ME MS I C in SCHEMATIC OF THE MMC5983-B MMC5983-B rn Name SPI_CS NC VDD GND SPI_SDO SDA/SPI_SDI SCL/SPI_SCK INT te Pin P1-1 P1-2 P1-3 P1-4 P2-1 P2-2 P2-3 P2-4 al PIN DESCRIPTION MMC5983-B MMC5983-B Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, nor for any infringements of patents or other rights of third parties, which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. MEMSIC MMC5983-B Prototyping Board User's Guide MEMSIC Semiconductor (Wuxi) Co., Ltd. No.2 Xinhuihuan Road, Xinwu District, Wuxi, Jiangsu, China Tel: +86-510-66616668 Fax: +86-510-66616669 www.memsic.com Page 1of 1 Rev A
MMC5983MA-B 价格&库存
很抱歉,暂时无法提供与“MMC5983MA-B”相匹配的价格&库存,您可以联系我们找货
