MQF326P25-698.812334-2.5/-30+85 数据手册
Temperature Compensated Crystal Oscillators
[ TCXO " M " and VCTCXO " VM " ]
TCXO
VCTCXO
Min.
Max.
MQF _ T
MQF _ P
MQF _ D
VMQF _ T
VMQF _ P
VMQF _ D
10
1,500
CMOS
PECL
LVDS
CMOS
PECL
LVDS
MHz
MHz
1.5 pS Phase Jitter ( typical )
Features
The (V)MQF326T , (V)MQF326P and (V)MQF326D Series are members of Mercury’s Q-Family Quick-Turn
Temperature Compensated oscillators that can be delivered within days. With low current consumption
(44 mA for PECL 212.500 MHz at 3.3V) and an integrated phase jitter performance of 1.0 pS RMS,
they have gained its precision frequency control market position by providing engineers with next-day
samples for prototypes and low cost, fast delivery for volume production ( ± 2.5 ppm over -30°C to +85°C ) .
General specifications , at Ta=+25°C
Model
(V)MQF326T
Output Logic
(V)MQF326P
(V)MQF326D
CMOS
PECL
LVDS
+ 2.5 V ± 5% ( voltage code " 25 " )
+ 3.3 V ± 5% ( voltage code " 33 " )
10 ~ 250 MHz
10 ~ 1,500 MHz
10 ~ 1,500 MHz
15 pF
50 Ω into Vcc - 2V or
Thevenin equiralent
100 Ω
Output Logic " High " , " 1 "
90 % VDD
VDD - 1.03 ( min.) , VDD - 0.6 ( max.)
1.4 V ( Typ.) , 1.6 V ( max.)
Output Logic " Low " , " 0 "
10 % VDD
VDD - 1.85 ( min.) , VDD - 1.6 ( max.)
1.1 V ( Typ.) , 0.9 V ( min.)
Supply Voltage VDD ( code )
Available Frequency Range
Output Load
( VDD = + 2.5V )
Current Consumption ( max.)
50 MHz : 24 mA
156 MHz : 36 mA
125 MHz : 28 mA
600 MHz : 40 mA
600 MHz : 28 mA
200 MHz : 30 mA
1,000 MHz : 50 mA
1,000 MHz : 34 mA
156 MHz : 25 mA
( VDD = + 3.3V )
50 MHz : 26 mA
156 MHz : 40 mA
125 MHz : 30mA
600 MHz : 45 mA
600 MHz : 30 mA
200 MHz : 34 mA
1,000 MHz : 52 mA
1,000 MHz : 36 mA
Current with Output Disabled
Rise Time / Fall Time
Initial Calibration Tolerance
Frequency Stability Codes
18 mA ( Typ.)
18 mA ( Typ.)
18 mA ( Typ.)
1.5 nsec. ( Typ.) , 3.0 nsec. ( max.)
Tr / Tf : 10% ↔ 90% waveform
0.2 nsec. ( Typ.) , 0.5 nsec. ( max.)
Tr / Tf : 20% ↔ 80% waveform
0.2 nsec. ( Typ.) , 0.4 nsec. ( max.)
±1.0 ppm ( max.) at +25°C±2°C ( at the shipment )
Temperature
( refer to +25°C)
± 2.5 ppm over -30°C to +85°C ( default for Quick - Turn )
Aging at Ta = +25°C
± 2.0 ppm ( max.) first year ; ± 10 ppm ( max.) over 10 years
Voltage Change
± 0.2 ppm ( max.) , for a ±5% input voltage change.
Load Change
± 0.2 ppm ( max.) , for a ±10% load condition change.
Reflow
± 1.0 ppm ( max.) , 1 reflow and measured 24 hours afterwards.
Duty Cycle
50 % ± 5%
Start-up Time
5 msec. ( max.)
Storage Temperature
-55°C to + 150°C
RMS Jitter [ 12 kHz ~ 20 MHz ]
1.5 psec ( typ.)
Phase Noise [ dBc / Hz ( typ.) ]
Storage Temperature
156 MHz : 22 mA
± 1.0 ppm over -40°C to +85°C ( available )
Offset
10 Hz
100 Hz
1K Hz
10K Hz
1M Hz
10M Hz
156.250 MHz
-65
-92
-108
-114
-117
-139
-147
212.500 MHz
-61
-90
-106
-110
-112
-133
-142
312.500 MHz
-51
-79
-97
-102
-103
-125
-134
100K Hz
-55°C to + 150°C
Control Voltage Function on Pad 1
Output Enable Function on pad 2
Control Voltage Center and Range
+1.5V ± 1.0V for both VDD = 2.5V and 3.3V
Frequency Pulling Range
± 8 ppm ( min.)
Linearity
± 1 % ( typ.) ± 10% ( max.)
Transfer Function
Positive Transfer
Absolute Voltage
4.0 V ( max.)
Input Impedance
770 KΩ ( typ.)
Mercury www.mercury-crystal.com
70% of VDD (min.) to enable output.
OE Control on Pad 2
(Open connection prohibit.)
30% of VDD (max.) to disable output.
Output Enable Time
/ Disable Time
200 nsec. ( max.) / 50 nsec. ( max.)
■Taiwan : Tel: (+886)-2-2406-2779 / sales-tw@mercury-crystal.com
■USA : Tel: (+1)-909-466-0427 / sales-us@mercury-crystal.com
■China : Tel: (+86)-512-5763-8100 / sales-cn@mercury-crystal.com
1 of 3
version: a3
Temperature Compensated Crystal Oscillators [ TCXO " M " and VCTCXO " VM " ]
TCXO
VCTCXO
MQF _ T
MQF _ P
MQF _ D
VMQF _ T
VMQF _ P
VMQF _ D
CMOS
PECL
LVDS
CMOS
PECL
LVDS
F
series
SMD
Min.
10
MHz
2.5 V 3.3 V
Max.
1,500
MHz
Part Number Format and Example
Example : VMQF326D33 - 622.080 - 2.0 / -40+85
VMQF
326
Hold Type
Package
T : CMOS
Supply Voltage
" 326 "
P : PECL
" 33 " for 3.3V
( 3.2 * 2.5 mm )
D : LVDS
" 25 " for 2.5V
" MQF "
: TCXO
" VMQF " : VCTCXO
D
33
622.080
2.0
-40+85
Operating
Center Freq. ( MHz )
Freq. Stability
Temperature
Range
Outline Dimensions ( Unit : mm ) , Suggested pad Layout for SMDs
[ (V)MQF326T ] , [ (V)MQF326P ] , [ (V)MQF326D ]
Test Circuits and Output Waveforms
CMOS
PECL
LVDS
2 of 3
version: a3
Emboss Taping and Reel Specifications
[ VCXO ]
[ ( VC )TCXO ]
Carrier Type Dimensions ( unit : mm ) ±0.3mm
A
B
C
D
E
F
G
H
I
pcs / reel
G_324 ( 6 )
8.0
3.4
2.7
4.0
1.4
0.3
4.0
Ø 1.50
1.75
3000
G_534
12.0
5.3
3.6
8.0
1.4
0.3
4.0
Ø 1.55
1.75
1000
G_576
16.0
7.3
5.3
8.0
1.9
0.3
4.0
Ø 1.55
1.75
1000
G_42
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.50
1.75
500
G_43
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
G_62
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
G_63
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
(V)M_22
8.0
2.8
2.3
4.0
1.1
0.3
4.0
Ø 1.50
1.75
3000
(V)M_32
8.0
3.4
2.7
4.0
1.4
0.3
4.0
Ø 1.50
1.75
3000
(V)MQ_326
12.0
3.6
2.9
4.0
1.7
0.3
4.0
Ø 1.50
1.75
3000
(V)M_53
12.0
5.3
3.6
8.0
1.4
0.3
4.0
Ø 1.55
1.75
1000
(V)M_57
16.0
7.4
5.5
8.0
2.8
0.4
4.0
Ø 1.50
1.75
500
(V)M_42
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.50
1.75
500
(V)M_43
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.50
1.75
500
(V)M_62
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.50
1.75
500
(V)M_63
24.0
11.8
10.0
16.0
5.0
0.3
4.0
Ø 1.50
1.75
500
Reel Dimensions ( unit : mm ) ±2mm
J
K
L
P
Q
R
pcs / reel
G_324 ( 6 )
180.0
9.0
12.0
13.2
2.1
3000
G_534
180.0
13.0
16.0
13.2
2.5
1000
G_576
180.0
17.2
19.3
13.3
2.2
22.0
1000
G_42
330.0
24.5
29.1
13.0
2.2
17.3
500
G_43
330.0
24.5
29.1
13.0
2.2
17.3
500
G_62
330.0
24.5
29.1
13.0
2.2
17.3
500
G_63
330.0
24.5
29.1
13.0
2.2
17.3
500
(V)M_22
178.00
8.40
11.40
13.0
2.5
20.5
3000
(V)M_32
180.0
9.0
12.0
13.2
2.1
3000
(V)MQ_326
180.0
13.0
16.0
13.2
2.5
3000
(V)M_53
180.0
13.0
16.0
13.2
2.5
1000
(V)M_57
180.0
17.2
19.3
13.3
2.2
22.0
500
(V)M_42
330.0
24.5
29.1
13.0
2.2
17.3
500
(V)M_43
330.0
24.5
29.1
13.0
2.2
17.3
500
(V)M_62
330.0
24.5
29.1
13.0
2.2
17.3
500
(V)M_63
330.0
24.5
29.1
13.0
2.2
17.3
500
3 of 3
version: a3
MQF326P25-698.812334-2.5/-30+85 价格&库存
很抱歉,暂时无法提供与“MQF326P25-698.812334-2.5/-30+85”相匹配的价格&库存,您可以联系我们找货
