Lithium Grease
Hydrophobic, Corrosion Inhibiting Lubricant
8461 Technical Data Sheet
8461
Description
The 8461 Lithium Grease is a multi-purpose lubricant that provides long superior lubrication and
protection against corrosion. As a lubricant, it reduces metal-to-metal friction and wear while retaining it
consistency over a wide temperature range. As a corrosion inhibitor, it prevents water and external
contaminants from oxidizing metals.
Features and Benefits
Corrosion inhibitor
Heat resistant
Easy to use and apply: Smooth buttery cream texture
Long lasting
ENVIRONMENT
Usage Parameters
Properties
Shelf Life a)
RoHS Compliant
Zero-VOC
Temperature Ranges
Value
5y
a) Reported shelf life assumes room
temperature storage and unopened container.
Properties
Constant Service
Temperature
Storage Temperature
Limits
Value
-40 to 180 °C
[-40 to 356 °F]
25 ±5 °C
[77 ±9 °F]
Principal Components
Name
Lithium Soap
Mineral Oils
Zinc Oxide
CAS Number
7620-77-1
64741-88-4
1314-13-2
Properties
Physical Properties
Color
Odor
Density @25 °C [77 °F]
Viscosity
Flash Point
Boiling Point
Auto-ignition Temperature
Corrosion Resistant
Solubility
Filler
Base Material
Electrical Class
Method
Visual
ASTM D 1475
Cleveland Closed Cup
Page 1 of 3
Date: 01 February 2017 / Ver. 1.01
Value
White
Odorless
0.89 g/mL
Cream, semi-solid
185 °C
[365 °F]
≥371 °C
[≥700 °F]
210 °C
[410 °F]
Yes
Insoluble
Lithium Soap
Mineral oils
Insulator
Lithium Grease
8461
Compatibility
Chemical—It is compatible with a wide variety of metal, rubber, and plastic substances.
Storage
Store within 25 ±5 °C [77 ±9 °F] in dry area.
Health, Safety, and Environmental Awareness
Please see the 8461 Safety Data Sheet (SDS) for greater details on transportation, storage, handling
and other security guidelines.
Environmental Impact: The VOC (Volatile Organic Compound) content is 0% by WHMIS and European
standards.
Health and Safety: The 8461 may cause a mild skin or eye irritation. Wear safety glasses and disposable
gloves to avoid exposures.
HMIS® RATING
NFPA® 704 CODES
HEALTH:
1
FLAMMABILITY:
1
PHYSICAL HAZARD:
1
PERSONAL PROTECTION:
Approximate HMIS and NFPA Risk Ratings Legend:
0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe)
Application Instructions
The performance of the 8461 Lithium Grease depends on surface preparation. Improperly prepared
contact surfaces can degrade the oxidation protection, dielectric properties, and lubrication characteristics
by trapping contaminants between the surface and the grease. The thickness and coverage should be
adjusted to meet your needs.
Prerequisites
(Optional) Wear gloves to avoid contaminating the surface and to avoid possible skin irritation.
(see 8461 SDS).
Clean and dry the surface of the substrate to remove other oils, greases, dust, water, solvents, or
any other contaminants.
Recommendations: Use MG 824 Isopropyl Alcohol or MG 401B Nu-trol Control Cleaner
Equipment
Lint free cloth (for cleaning contact and for wiping excess residue)
Spatula or stick application tools (sized appropriately for your application)
Isopropyl alcohol or other residue-free organic solvents
Page 2 of 3
Lithium Grease
8461
To apply the grease
1. Wipe the contact with a lint-free cloth.
2. Clean the contacts with isopropyl alcohol or other non-oil based cleaner.
3. Once dry, apply the paste with the application tool to the contact, ensuring adequate coverage and
desired thickness.
Packaging and Supporting Products
Cat. No.
8461-85ML
8461-1P
Packaging
Tube
Tub
Net Volume
85 mL
2.9 fl oz
487 mL
1.0 pt
Net Weight
85 g
3 oz
487 g
16 oz
Packaging Weight
0.9 kg
2.0 lb
0.9 kg
2.0 lb
Contact MG Chemicals if custom packaging or sizes are required
Supporting Products
Isopropyl Alcohol: Cat. No.824
Technical Support
Contact us regarding any questions, improvement suggestions, or problems with this product. Application
notes, instructions, and FAQs are located at www.mgchemicals.com.
Email: support@mgchemicals.com
Phone: +(1) 800-340-0772 (Canada, Mexico & USA)
+(1) 905-331-1396 (International)
Fax: +(1) 905-331-2862 or +(1) 800-340-0773
Mailing address:
Manufacturing & Support
1210 Corporate Drive
Burlington, Ontario, Canada
L7L 5R6
Head Office
9347–193rd Street
Surrey, British Columbia, Canada
V4N 4E7
Warranty
M.G. Chemicals Ltd. warranties this product for 12 months from the date of purchase by the end user.
M.G. Chemicals Ltd. makes no claims as to shelf life of this product for the warranty. The liability of
M.G. Chemicals Ltd. whether based on its warranty, contracts, or otherwise shall in no case include
incidental or consequential damage.
Disclaimer
This information is believed to be accurate. It is intended for professional end users having the skills to
evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and
assumes no liability in connection with damages incurred while using it.
Page 3 of 3
很抱歉,暂时无法提供与“8461-1P”相匹配的价格&库存,您可以联系我们找货
