RAS-PCS14PWR-BK
RAS-PCS14PWR-BK
    MICROCONNECTORS
    ALUM PI 4 MOD B CASE W/FAN USB-
RAS-PCS14PWR-BK 数据手册
Aluminum Raspberry Pi 4 Model B Case (Kit with Fan: RAS-PCS14-BK) (Kit with Fan, USB-C On/Off Power Adapter: RAS-PCS14PWR-BK) Micro Connectors’ Aluminum Raspberry Pi 4 Model B Case is a high-quality durable aluminum case that’s designed to help to deal with the high temperatures of your Pi and dissipate its heat. The precision-cut casing allows easy access to all ports. With kits including heatsinks and an active cooling fan to actively draw out heat from your Pi, and optionally, a USB-C power supply with an easy-to-use on/off switch, these kits have all the essentials to get keep your Pi project started today! o o FEATURES • • • • Compatible with Raspberry Pi 4 Model B Wall-mount compatible 40mm low noise cooling fan with one-to-two wire connector pins (3.3V or 5V) to provide optimal fan speed and air flow 47in/3.9ft USB-C power adapter: o UL and FCC approved o DoE Level VI efficiency o Input: AC100-240V/50-60Hz Output: DC 5V/3A Over voltage and short circuit protection INCLUDES • • • • • • Aluminum case Micro USB power adapter (RAS-PCS14PWR-BK only) (3) Heatsinks Cooling fan Anti-slip rubber feet pads Screws and screwdriver
RAS-PCS14PWR-BK 价格&库存
很抱歉,暂时无法提供与“RAS-PCS14PWR-BK”相匹配的价格&库存,您可以联系我们找货
