RAS-PWR13-PI
RAS-PWR13-PI
    MICROCONNECTORS
    AC/DC DSKTP/WALL MT ADAPTER 5V
RAS-PWR13-PI 数据手册
UL Approved USB-C Power Adapter with On/Off Switch for Raspberry Pi (RAS-PWR13-PI) Micro Connectors’ USB-C power supply cable makes it convenient to control your power supply for your raspberry Pi. The Raspberry Pi has no switch, so it's hard to control its power supply except manually plugging and unplugging the power cord, which can be very inconvenient—especially in the process of preliminary debugging. This 47 inch (3.9ft) cable features an easy-to-use on/off switch, which is not only necessary for your Pi, or other single board computers, but can also be used for your mobile phone and other USB-C compatible devices. FEATURES • • • • • • Compatible with: o Raspberry Pi 4 Model B o Other single board computers (SBCs) with USB-C port UL and FCC approved DoE Level VI efficiency Over voltage and short circuit protection Input: AC100-240V/50-60Hz Output: DC 5V/3A
RAS-PWR13-PI 价格&库存
很抱歉,暂时无法提供与“RAS-PWR13-PI”相匹配的价格&库存,您可以联系我们找货
