1000 feet Cat6 Solid STP Bulk Ethernet 23AWG Cable (Blue)
TR4-560SH-BL
Micro Connectors' Bulk CAT6 Shielded Cable comes conveniently packaged in a pull box,
providing you with 1000 feet of high quality, shielded, 4-pair, solid, 550 MHz Cat6 Cable,
ready for termination and routing.
The Mylar foil shielding protects your data as it travels through the four twisted pairs of 23
gauge solid copper wires by wrapping it in a thin metal sleeve thus keeping electrical
interference from things like fluorescent lights and electrical lines found in a drop ceiling or
inside walls at a minimum.
Simply pull the length required for your installation straight from the box and terminate at
your leisure.
These boxes are a great aid in large scale network installations and other long distance cable
runs.
And like all of our bulk networking cables, these are constructed with only high-quality
components that can be counted on for high performance.
Need to use CAT 6A connectors, cat 5E and CAT6 connectors will not fit this cable, outside
diameter of the cable is 6.9 mm.
We have CAT6A / CAT7 metal shielded connectors that will fit perfectly our CAT6 solid STP
bulk cable, the part# for our connectors is (C20-088L7S-20).
Features:
• Shielded cables designed to prevent EMI Interference and ensuring best signal possible
• 23AWG (American wire gauge) individual solid pure copper conductors for permanent
installation
• Meets ANSI/TIA-568-C specifications
• Comes on a convenient spool inside a pull box for easy access
• RoHS compliant
很抱歉,暂时无法提供与“TR4-560SH-BL”相匹配的价格&库存,您可以联系我们找货
