MCCOG21605B6W-FPTLWI 数据手册
Electra House, 32 Southtown Road
Great Yarmouth, Norfolk
NR31 0DU, England
2 x 16
5mm Character Height
Specification
Version:
Telephone +44 (0)1493 602602
Fax +44 (0)1493 665111
Email:sales@midasdisplays.com
www.midasdisplays.com
1
LCD Module
Date: 19/10/2016
Revision
Display Features
Character Count
2 x 16
Black on White
Appearance
Logic Voltage
5V
I2C
Interface
Font Set
English / Japanese
Transflective
Display Mode
Character Height
3.79mm
LC Type
FSTN
Module Size
51.20 x 20.70 x 6.30 mm
Operating Temperature
-20°C ~ +70°C
Construction
COG
LED Backlight
White
Box Quantity
Weight / Display
* - For full design functionality, please use this
specification in conjunction with the ST7032I
specification. (Provided Separately)
Display Accessories
Part Number
MCCOG-I2C-I-8
Description
Fine pitch(1.27mm) COG I2C
interface board. Compatible
with both Arduino and UC32
controller boards.
Optional Variants
Fonts
Appearances
Black on
Yellow/Green
White on Blue
Voltage
Mechanical Specifications
51.20 x 20.70 x 6.30 ( With Backlight)
Module Size
W x H x D mm
Viewing Area
40.00 x 10.00
W x H mm
Hole-to-Hole
W x H mm
Character Size
Dot Size
2.00 x 3.79
0.36 x 0.43
W x H mm
W x H mm
Character Pitch
Dot Pitch
2.40 x 4.19
0.41 x 0.48
W x H mm
W x H mm
K
6.8
A
6.3
0.3
2.8MAX
1.1
1.1
3.0
2.0
9.3
10.0
0.6
1.15
2.0
0.41
0.36
P1.27*7=8.89
3.79
0.48
0.43
1
0.4
ST7032i
43.0
VA40.0
AA38.0
51.2
8
0.40
2.00
DOT SIZE
SCALE 5/1
0.40
17.2
2 x 16
5.5
20.7
18.5
13.0
VA10.0
AA8.0 3.6
1.1
2.6
3.6
18.155
±5°
0.7
1.1
2.6
Specification
Version:
1
Revision
Date: 19/10/2016
LCD Module
Pin Layout
PI
1
2
3
4
5
6
7
8
SYMBOL
VOUT
CAP1N
CAP1P
VDD
VSS
SDA
SCL
RST
DESCRIPTION
DC/DC Voltage Converter
Voltage booster Circuit (VDD-VSS)
5.0V
Power Supply
Ground
Input Data
Clock Input Data
Reset
2 x 16
Specification
Version:
REMARKS
1
Revision
Date: 19/10/2016
LCD Module
Font Map
Upper
4bit
Lower
4bit
LLLL LLLH LLHL LLHH LHLL LHLH LHHL LHHH HLLL HLLH HLHL HLHH HHLL HHLH HHHL HHHH
LLLL
CG
RAM
(1)
LLLH
(2)
LLHL
(3)
LLHH
(4)
LHLL
(5)
LHLH
(6)
LHHL
(7)
LHHH
(8)
HLLL
(1)
HLLH
(2)
HLHL
(3)
HLHH
(4)
HHLL
(5)
HHLH
(6)
HHHL
(7)
HHHH
(8)
2 x 16
Specification
Version:
1
Revision
Date: 19/10/2016
LCD Module
Absolute Maximums Ratings
Item
Symbol
Minimum
Typical
Maximum
Unit
Power Supply (Logic)
Vdd
-0.3
6.0
V
Power Supply (LCD)
V0
7.0 -Vss
-0.3 +Vss
V
TOP
TST
-20°C
-30°C
70°C
80°C
°C
°C
--Operating Temperature
Storage temperature
Electronic Characteristics
Item
Input Voltage High
Input Voltage Low
Output Voltage High
Output Voltage Low
Supply Voltage Logic
Supply Voltage LCD
Supply Current
Symbol
Condition
VIH
VIL
VOH
VOL
VDD ~ VSS
VDD ~ V0
IDD
----------Ta=25°C
Minimum
0.70
--0.80
--3.00
Typical
Maximum
Unit
--------3.30
4.50
0.17
VDD
0.20
VDD
0.20
5.00
V
V
V
V
V
V
mA
LCD Characteristics
For STN/FSTN LCD Panel Types
Item
Symbol
Condition
Viewing Angle
Contrast Ratio
Response Time
(Rise)
Response Time
(Fall)
Φ2 – Φ1
Θ
CR
Minimum
CR ≥ 2
Typical
Maximum
3
40
30
Unit
ψ=180°
TR
250
400
ms
TF
100
250
ms
Maximum
Unit
LED Characteristics
Item
Symbol
Condition
Supply Current
Supply Voltage
Reverse Voltage
Luminance (Without
LCD)
--LED Life Time
ILED
V
VR
V=3.5V
Minimum
28.80
3.40
Typical
IV
ILED=32mA
468.80
586
Cd/m2
--ILED=32mA
--50K
--Hour
32
3.50
50
3.60
5
mA
V
V
Attention: It is constant current, not constant voltage, which should be applied when driving
the LED backlight, please ensure you adhere to this rule.
2 x 16
Specification
Version:
1
Revision
Date: 19/10/2016
LCD Module
MCCOG21605B6W-FPTLWI 价格&库存
很抱歉,暂时无法提供与“MCCOG21605B6W-FPTLWI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+101.79531
- 13+99.54592
- 25+97.40067
