MDT0700A12SSR-HDMI
MDT0700A12SSR-HDMI
    MIDAS
    LCD DISPLAY TFT 7 800X480
MDT0700A12SSR-HDMI 数据手册
Electra House, 32 Southtown Road Great Yarmouth, Norfolk NR31 0DU, England MDT0700A12SSR-HDMI (MCT070HDMI-A-RTP) Version: 1 LVDS Interface 800 x 480 Specification 1 27/06/2019 Display Accessories Part Number Description MCIB-HDMI/HDMI Male To Male HDMI Connector USB-to-Micro USB interconnect cable. TFT Module Date: 27/06/2019 Revision First issue Display Features Display Size 7.0” Resolution 800 x 480 Orientation Landscape RGB Appearance 5V Logic Voltage Interface LVDS Brightness 250 cd/m2 RTP Touchscreen Module Size 165.00 x 100.00 x 26.40mm Operating Temperature -20°C ~ +70°C Pinout HDMI --Pitch MCIC-USB Telephone +44 (0)1493 602602 Email:sales@midasdisplays.com www.midasdisplays.com Box Quantity --- Weight / Display --- Optional Variants Appearances Voltage Summary TFT 7.0”is a TN transmissive type color active matrix TFT liquid crystal display that use amorphous silicon TFT as switching devices. This module is a composed of a TFT_LCD module, It is usually designed for industrial application and this module follows RoHs. General Specifications  Size: 7.0 inch  Dot Matrix: 800 x RGBx480(TFT) dots  Module dimension: 165.0(W) x 100(H) x 26.4(D)max mm  Active area: 154.08 x 85.92 mm  Dot pitch: 0.0642 x 0.179mm  LCD type: TFT, Normally White, Transmissive  View Direction: 12 o’clock  Gray Scale Inversion Direction: 6 o’clock  Aspect Ratio: 16:9  Backlight Type: LED,Normally White  Interface: HDMI  RTP Interface:USB  With /Without TP: With RTP  Surface: Anti- Glare *Color tone slight changed by temperature and driving voltage. Interface CON5 Pin No. Symbol Function TFT Module Power limit can only output 3.3V,100mA Raspberry Pi:Power 5V 1 3.3V 2 5V 3 GPIO02 4 5V 5 GPIO03 6 GND 7 GPIO04 Raspberry Pi:GPIO04 8 GPIO14 Raspberry Pi:GPIO14 9 GND 10 GPIO15 Raspberry Pi:GPIO15 11 GPIO17 Raspberry Pi:GPIO17 12 GPIO18 Raspberry Pi:GPIO18 (Backlight Enable) 13 GPIO27 Raspberry Pi:GPIO27 14 GND 15 GPIO22 Raspberry Pi:GPIO22 16 GPIO23 17 3.3V 18 GPIO24 Raspberry Pi:GPIO23 TFT Module Power limit can only output 3.3V,100mA Raspberry Pi:GPIO24 19 GPIO10 Raspberry Pi:GPIO10 20 GND 21 GPIO09 Raspberry Pi:GPIO09 22 GPIO25 Raspberry Pi:GPIO25 23 GPIO11 Raspberry Pi:GPIO11 24 GPIO08 Raspberry Pi:GPIO08 25 GND 26 GPIO07 27 ID_SD Raspberry Pi:ID_SD 28 ID_SC Raspberry Pi:ID_SC 29 GPIO05 30 GND Remark Note1 Raspberry Pi:GPIO02 Raspberry Pi:Power 5V Raspberry Pi:GPIO03 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO07 Raspberry Pi:GPIO05 Raspberry Pi:GND Note1 31 GPIO06 Raspberry Pi:GPIO06 32 GPIO12 Raspberry Pi:GPIO12 33 GPIO13 Raspberry Pi:GPIO13 34 GND 35 GPIO19 Raspberry Pi:GPIO19 36 GPIO16 Raspberry Pi:GPIO16 37 GPIO26 Raspberry Pi:GPIO26 38 GPIO20 Raspberry Pi:GPIO20 39 GND 40 GPIO21 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO21 Note1: The 3.3V supply current is limited; please pay special attention to use CON6 Pin No. 1 Symbol Function NC No Connection 2 5V Raspberry Pi:Power 5V 3 GPIO02 4 5V 5 GPIO03 6 GND 7 GPIO04 Raspberry Pi:GPIO04 8 GPIO14 Raspberry Pi:GPIO14 9 GND 10 GPIO15 Raspberry Pi:GPIO15 11 GPIO17 Raspberry Pi:GPIO17 12 GPIO18 Raspberry Pi:GPIO18 (Backlight Enable) 13 GPIO27 Raspberry Pi:GPIO27 14 GND 15 GPIO22 Raspberry Pi:GPIO22 16 GPIO23 Raspberry Pi:GPIO23 17 NC 18 GPIO24 Raspberry Pi:GPIO24 19 GPIO10 Raspberry Pi:GPIO10 20 GND 21 GPIO09 Raspberry Pi:GPIO09 22 GPIO25 Raspberry Pi:GPIO25 23 GPIO11 Raspberry Pi:GPIO11 24 GPIO08 Raspberry Pi:GPIO08 25 GND 26 GPIO07 27 ID_SD Raspberry Pi:ID_SD 28 ID_SC Raspberry Pi:ID_SC 29 GPIO05 30 GND 31 GPIO06 Raspberry Pi:GPIO06 32 GPIO12 Raspberry Pi:GPIO12 Raspberry Pi:GPIO02 Raspberry Pi:Power 5V Raspberry Pi:GPIO03 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GND No Connection Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO07 Raspberry Pi:GPIO05 Raspberry Pi:GND Remark 33 GPIO13 Raspberry Pi:GPIO13 34 GND 35 GPIO19 Raspberry Pi:GPIO19 36 GPIO16 Raspberry Pi:GPIO16 37 GPIO26 Raspberry Pi:GPIO26 38 GPIO20 Raspberry Pi:GPIO20 39 GND 40 GPIO21 Raspberry Pi:GND Raspberry Pi:GND Raspberry Pi:GPIO21 HDMI Pin No. Symbol I/O 1 Rx2+ I +LVDS Differential Data Input 2 GND P Ground 3 Rx2- I -LVDS Differential Data Input 4 Rx1+ I +LVDS Differential Data Input 5 GND P Ground 6 Rx1- I -LVDS Differential Data Input 7 Rx0+ I +LVDS Differential Data Input 8 GND P Ground 9 Rx0- I -LVDS Differential Data Input 10 RxC+ I +LVDS Differential Clock Input 11 GND P Ground 12 RxC- I -LVDS Differential Clock Input 13-14 NC - No connection 15 SCL I/O DDC(Data Display Channel) Clock 16 SDA I/O DDC(Data Display Channel) Data 17 GND P Ground 18 5V P Power Supply Function 19 Detect I/O Hot plug detect I: input, O: output, P: Power Remark POWER JACK Pin No. Symbol I/O 1 5V P Power Supply 2 GND P Ground 3 NC USB Pin No. Function Remark Function Remark No connection Symbol I/O 1 5V P 2 D- I/O USB Data - 3 D+ I/O USB Data + 4 NC - No connection 5 GND P Ground Power Supply Contour Drawing 3.27¡ À 0.5 (4.33) (4.52) TFT&TP Outline 165.00¡ À 0.5 TP VA 156.60 TP AA 154.48 TFT AA 154.08 5.74¡ À 0.5 (6.80) (7.045) 26.4MAX 7.20¡ À 0.5 5.70¡ À 0.3 163.60¡ À 0.5 (PCB) 0.60¡ À 0.5 156.60 3.50 13.58¡ À 0.5 CON6 40 2 CON5 1 2 1 39 TFT Outline 100.00 TP Outline 99.00 TP VA 89.10 TP AA 86.98 TFT AA 85.92 CON4 91.60 800 X RGB X 480 ± íà æ Ô ª¼ þ ½û Ö¹ 98.60¡ À 0.5 (PCB) 1 19 6.8MAX CON1 50 4 1 1 CON2 HDMI 11.7MAX 39 40 6.0MAX 2.8MAX 1 USB 5 component area Pin Symbol Pin Symbol POWER-JACK RX2+ GND RX2RX1+ GND RX1RX0+ GND RX0RXC+ GND RXCNC NC SCL SDA GND 5V Detect 1 2 3 4 5 5V DD+ NC GND 1 2 3 5V GND NC 8- 2.75PTH 8- 6.20PAD 3.50 0.60¡ À 0.5 1.60(PCB) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Pin Symbol Pin Symbol 1 NC 21 GPIO09 1 3.3V 21 GPIO09 2 5V 22 GPIO25 2 5V 22 GPIO25 3 GPIO02 23 GPIO11 3 GPIO02 23 GPIO11 4 5V 24 GPIO08 4 5V 24 GPIO08 5 GPIO03 25 GND 5 GPIO03 25 GND 6 GND 26 GPIO07 6 GND 26 GPIO07 7 GPIO04 27 ID_SD 7 GPIO04 27 ID_SD 8 GPIO14 28 ID_SC 8 GPIO14 28 ID_SC 9 GND 29 GPIO05 9 GND 29 GPIO05 10 GPIO15 30 GND 10 GPIO15 30 GND 11 GPIO17 31 GPIO06 11 GPIO17 31 GPIO06 12 GPIO18 32 GPIO12 12 GPIO18 32 GPIO12 13 GPIO27 33 GPIO13 13 GPIO27 33 GPIO13 14 GND 34 GND 14 GND 34 GND 15 GPIO22 35 GPIO19 15 GPIO22 35 GPIO19 16 GPIO23 36 GPIO16 16 GPIO23 36 GPIO16 17 NC 37 GPIO26 17 3.3V 37 GPIO26 18 GPIO24 38 GPIO20 18 GPIO24 38 GPIO20 19 GPIO10 39 GND 19 GPIO10 39 GND 20 GND 40 GPIO21 20 GND 40 GPIO21 2 (GND) 1 (5V) The non-specified tolerance of dimension is ¡ À 0.3 mm . Absolute Maximum Ratings Item Symbol Min Typ Max Unit Operating Temperature TOP -20 - +70 Storage Temperature TST -30 - +80 ℃ ℃ Note: Device is subject to be damaged permanently if stresses beyond those absolute maximum ratings listed above 1. Temp. ≦60℃, 90% RH MAX. Temp.>60℃, Absolute humidity shall be less than 90% RH at 60℃ Electrical Characteristics Operating conditions: Item Symbol Condition Min Typ Max Unit Remark Supply Voltage For LCM VDD - 4.9 5 5.1 V - Supply Current For LCM IDD - - 760 1140 mA Note 1 - - - 50,000 - Hr Note 4 LED Life Time Note 1 : This value is test for VDD =5.0V , Ta=25℃ only Note 2 : Display with Raspberry pi the driver power is over USB , first make sure you have a 2A power supply, with a good quality USB cable, a thin wire power cable is no good. Make sure its 24AWG or smaller, shorter USB cables are better too. Note3 : Touch Panel driver is base on the mouse driver program and through USB port connect to PC or embedded board.Can only support the single touch. Note 4: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =180mA. The LED lifetime could be decreased if operating IL is lager than 180mA. Optical Characteristics Item Symbol Condition. Response time Tr+Tf θ=0°、Φ=0° Contrast ratio CR At optimized viewing angle Color Chromaticity Viewing angle (Gray Scale Inversion Direction) White Hor. Ver. Wx Wy θ=0°、Φ=0 ΘR ΘL ΦT CR≧10 ΦB Min Typ. Max. 25 50 500 800 - - Note 4 0.26 0.31 0.36 - 0.28 0.33 0.38 - Note 2,6,7 60 70 - 60 70 - 50 60 - Deg. Note 1 60 70 Center of display Note 5 - Unit .ms .ms Brightness - - 200 250 - cd/m2 Uniformity (U) - 70 - - % Remark Note 3 Ta=25±2℃, IL=180mA Note 1: Definition of viewing angle range Fig.8.1. Definition of viewing angle Note 2: Test equipment setup: After stabilizing and leaving the panel alone at a driven temperature for 10 minutes, the measurement should be executed. Measurement should be executed in a stable, windless, and dark room. Optical specifications are measured by Topcon BM-7orBM-5 luminance meter 1.0° field of view at a distance of 50cm and normal direction. Fig. 8.2. Optical measurement system setup Note 3: Definition of Response time: The response time is defined as the LCD optical switching time interval between “White” state and “Black” state. Rise time, Tr, is the time between photo detector output intensity changed from 90%to 10%. And fall time, Tf, is the time between photo detector output intensity changed from 10%to 90% Display Data White(TFT OFF) Black(TFT ON) White(TFT OFF) 100% 90% 10% 0% Note 4: Definition of contrast ratio: The contrast ratio is defined as the following expression. Contrast ratio (CR) = Luminance measured when LCD on the "White" state Luminance measured when LCD on the "Black" state Note 5: Definition of Luminance Uniformity Active area is divided into 9 measuring areas (reference the picture in below). Every measuring point is placed at the center of each measuring area. Luminance Uniformity (U) = Lmin/Lmax x100% L = Active area length W = Active area width Fig8.3. . Definition of uniformity Note 6: Definition of color chromaticity (CIE 1931) Color coordinates measured at the center point of LCD Note 7: Measured at the center area of the panel when all the input terminals of LCD panel are electrically opened. Reliability Content of Reliability Test (Wide temperature, -20℃~70℃) Environmental Test Test Item High Temperature storage Low Temperature storage High Temperature Operation Low Temperature Operation High Temperature/ Humidity Operation Thermal shock resistance Content of Test Endurance test applying the high storage temperature for a long time. Endurance test applying the low storage temperature for a long time. Endurance test applying the electric stress (Voltage & Current) and the thermal stress to the element for a long time. Endurance test applying the electric stress under low temperature for a long time. The module should be allowed to stand at 60℃,90%RH max The sample should be allowed stand the following 10 cycles of operation -20℃ 25℃ 70℃ Note 2 -20℃ 200hrs 60℃,90%RH 96hrs -20℃/70℃ 10 cycles 1 1,2 —— 1,2 —— 30min Vibration test Static electricity test 5min 30min 1 cycle Endurance test applying the vibration during transportation and using. Test Condition 80℃ 200hrs -30℃ 200hrs 70℃ 200hrs Endurance test applying the electric stress to the terminal. Total fixed 3 amplitude : 1.5mm Vibration Frequency : 10~55Hz One cycle 60 seconds to 3 directions of X,Y,Z for Each 15 minutes VS=±600V(contact) —— ,±800v(air), RS=330Ω CS=150pF 10 times Note1: No dew condensation to be observed. Note2: The function test shall be conducted after 4 hours storage at the normal Temperature and humidity after remove from the test chamber. Note3: The packing have to including into the vibration testing.
MDT0700A12SSR-HDMI 价格&库存
很抱歉,暂时无法提供与“MDT0700A12SSR-HDMI”相匹配的价格&库存,您可以联系我们找货
