SigFox 2 Click
PID: MIKROE‐3039
Weight: 30 g
SigFox 2 click is a device which carries the SN10-12, a fully integrated
Sigfox™ certified module by InnoComm, allowing connection to a low power
wide area network (LPWAN) that enables communication utilizing the
Industrial, Scientific, and Medical (ISM) radio frequency band. The Sigfox
network is a star topology network, specifically designed for the Internet of
Things (IoT) applications. It uses an ultra-narrow frequency band, able to
penetrate through the objects and cover large distances, making it a perfect
choice for various industry-specific applications, such as the sensors
networking in agriculture.
Note: Sigfox 2 click is intended to be used in the RCZ2 (North
America)and RCZ4 (Asia).
More information about the Sigfox network coverage, and other related
information can be found at the official Sigfox site.
Also, if you are looking for a Sigfox click that covers other regions, please
check out our other Sigfox click products.
This Click board™ offers all that is needed to integrate a Sigfox network
connectivity into a design. Besides the SN10-12 module itself, it offers the
industry-standard SPI communication protocol and an onboard SMA
connector, used to connect the appropriate 868MHz antenna. With its low
power consumption, SigFox 2 click can be used on a battery-operated
platform for a very long time, without replacing the battery.
How does it work?
The Click board™ is equipped with the SN10-12 Sigfox™ certified module,
manufactured by InnoComm Mobile Technology Corporation. The hearth of this
module is the OL2385, a sub-GHz wireless transceiver System-on-Chip (SoC).
The communication between the module and the host MCU is performed
over the SPI. An additional AK pin is used to signal the command
acknowledgment. There is a number of commands available, which are all
sent in a specific format. Each data packet transferred via the SPI bus
contains the number of bytes to be sent, the command itself, and the data
payload (if there is one). Upon the successful command, the AK pin will
indicate the response. This pin is routed to the mikroBUS™ AN pin.
In addition, commands return the status over the SPI. If a command is
successful, a status of 0 is returned, for example. Different status responses
have different meaning. Some commands may return various error codes,
indicating a certain condition of the signal chain. For example, a command
might get accepted by the module, but refused by the remote base station
(station not reachable, and similar). All the commands are a part of the
firmware API offered by the module, over the SPI interface. However, the
library which comes with the SigFox click contains functions that encapsulate
all the necessary commands and handle the responses, offering simplified
programming interface, in the familiar MikroElektronika compilers
environment.
The module can be reset over the RST pin of the mikroBUS™. This pin is
pulled to a HIGH logic level internally. Setting it to a LOW logic level will
perform a hardware reset of the SN10-11 module.
The Sigfox network operates using a public frequency bandwidth, defined by
the regional radio regulations, such as the FCC regulations for the North
American region, carrying the FCC ID: YAISN10-12T. In the RCZ2 region,
the Sigfox network operates at 902.1375MHz to 904.6625MHz, and in the
RCZ4, it operates at 920.1375MHz to 922.6625MHz This network is a star
topology type of network and requires a base station which collects the data
from the connected nodes and sends it to the Sigfox cloud for further
processing and distribution.
The nodes can be as far as 1000m from the base station, depending on the
regional Sigfox network frequency (the official information about the
network coverage can be found on the Sigfox site). Node objects can be
various temperature and humidity sensors, parking lot sensors, etc. The
node objects communicate with the base using the Differential Phase Shift
Keying (DPSK) communication method. Small messages with the data
payload as low as 12 bytes are transmitted several times per day, allowing
conservative power consumption. The ultra-narrow frequency band allows
the TX power to stay really low, saving even more power and allowing
batteries to last a few years. This is very well suited for various industrial
applications, such as the agriculture industry, where many sensor nodes are
often scattered over a wide area and are hard to reach for a frequent battery
replacement.
Once it collects the data, a base station will decode it and send it to the
Sigfox cloud. The data is processed and pushed back to the user application.
While the uplink (information transfer from the node to the cloud) is
performed using the more robust and efficient DPSK communication method,
the downlink (information transfer from the cloud to the application) uses
the Frequency Shift Keying (FSK), which is less robust than the DFSK and
uses broader frequency range. Typically, the interference is not a big
concern for the downlink. The key difference between similar, cellular
network based IoT network solutions, is that all stations in range will pick up
the node signal and forward it to the cloud, not just a single station.
The Sigfox cloud is unique and all the base stations are connected to it. This
type of centralized approach can have some inherited benefits. For example,
it is possible to track goods, by accessing data sent by another station in a
different part of the country, or even a different country. With its global Low
Power Wide Area network, Sigfox is a true Internet of Things.
Specifications
Type
RF Sub 1GHz
Applications
SigFox 2 click offers connectivity to the SigFox network. It can be
used for a wide range of IoT applications, which require large area
coverage, such as the agriculture industry applications, parking lot
applications, goods tracking applications, and similar
On-board
modules
SN 10-12 Sigfox certified module, by InnoComm
Key Features
Official Sigfox network certified module onboard, simplified software
functions allow rapid development, robust IoT networking with very
wide area coverage, Sigfox cloud allows access to distant base
stations and nodes, and more
Interface
SPI
Input
Voltage
3.3V
Click board
size
L (57.15 x 25.4 mm)
Pinout diagram
This table shows how the pinout on SigFox 2 click corresponds to the pinout
on the mikroBUS™ socket (the latter shown in the two middle columns).
Notes
ACK OUT
Pin
Pin
AK
1
AN
PWM
16
NC
RST
2
RST
INT
15
NC
CS
3
CS
RX
14
NC
SPI Clock
SCK
4
SCK
TX
13
NC
SPI Data OUT
SDO
5
MISO
SCL
12
NC
SPI Data IN
SDI
6
MOSI
SDA
11
NC
Power supply
3.3V
7
3.3V
5V
10
NC
Ground
GND
8
GND
GND
9
GND
Reset
Chip Select
Notes
Ground
Onboard connectors and indicators
Label
Name
Description
PWR
PWR
Power LED indicator
ANT
ANT
SMA antenna connector
Software support
We provide a demo application for SigFox 2 Click on our Libstock page, as
well as a demo application (example), developed using
MikroElektronika compilers. The demo can run on all the main
MikroElektronika development boards.
Library Description
The library contains basic functions for controlling the click board.
Key functions:
int32_t sigfox2_init() - Function for initializing the sensor.
int32_t sigfox2_wakeUp() - Function for waking up the sensor from the sleep mode.
int32_t sigfox2_sleep() - Function for placing sigfox to the low power mode.
Example description
Click board wakes up from sleep. Some tests are performed. After the tests
and after the data has been sent and received from the network the click
board is placed into the sleep mode to its low power mode. All events that
are executed inside of the application task are printed to the serial port.
void applicationTask()
char spiFrameACK = 0;
char rData[20];
uint8_t sendPayload[12] = "Test msg";
_status = sigfox2_wakeUp();
if(_status == _SIGFOX2_STATUS_SUCCESS)
mikrobus_logWrite("Wakeup succesfull",_LOG_LINE);
_status = sigfox2_testSpicon(&spiFrameACK);
if(spiFrameACK == 1)
mikrobus_logWrite("SPI test finished succesfully",_LOG_LINE);
mikrobus_logWrite("Sending data to sigfox network",_LOG_LINE);
_status = sigfox2_receiveMessage(&sendPayload[0],&rData[0]);
mikrobus_logWrite("Data received",_LOG_LINE);
mikrobus_logWrite(&rData[0],_LOG_LINE);
else
mikrobus_logWrite("Network error",_LOG_LINE);
else
mikrobus_logWrite("Error in echo frame",_LOG_LINE);
else
mikrobus_logWrite("Error in wakeup",_LOG_LINE);
_status = sigfox2_sleep();
mikrobus_logWrite("Sleep entered",_LOG_LINE);
else
mikrobus_logWrite("Error entering sleep",_LOG_LINE);
Delay_ms(5000);
The full application code, and ready to use projects can be found on
our Libstock page.
Other MikroElektronika libraries used in the example:
SPI Library
UART Library
Conversions Library
C_String Library
Additional notes and information
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development
systems with no UART to USB interface available on the board. The terminal
available in all MikroElektronika compilers, or any other terminal application
of your choice, can be used to read the message.
mikroSDK
This click board is supported with mikroSDK - MikroElektronika Software
Development Kit. To ensure proper operation of mikroSDK compliant click
board demo applications, mikroSDK should be downloaded from
the LibStock and installed for the compiler you are using.
For more information about mikroSDK, visit the official page.
https://www.mikroe.com/sigfox2-click 9-20-18
